Change Control Form - Approval process for cross departmental communication
mhunter - 2009
I have a question regading control of documentation. I am in the process of putting together a procedure for change control. I have created a document to help the approval process to incorporate cross departmental communication if need be. My question is, if this form is not used for all offical document changes, then a rev block must be used for history purposes correct?:bonk: Thanks for any assistance you can provide!!
Jen Kirley
Quality and Auditing Expert
Welcome to The Cove!
I am not sure I completely understand you, but I will try to give you a straight answer.
At minimum, controlled documents need to have some way for the reader to know their version is the most recent available. That usually happens with a revision number, but a date might serve too. The archived old copy should be plainly marked "Obsolete" or some such.
These documents will, according to their sensitivity, need change approvals from authorized people who represent the people who use, or will be affected by the process being changed.
If a change form is separate from the document itself, it needs to identify which revision it is for. So, one could argue that both have a revision number. But if a change form is separate from the document it is collecting approvals for, its revision number isn't adequate. The document itself needs this revision information. I like to see it on the front page, as well as the header or footer of every page.
There will be some documents that arguably don't need this kind of change control. Equipment manuals from the manufacturer might not need revision controls if a performance check is done after each repair/PM. A blank requisition form might not need any revision control unless it was getting a critical change and you want to be sure the old version never gets used again.
I hope this helps!
mhunter - 2009
Thanks for the reply. I guess I should of explained it a little better. Sorry!! I understand the revision on every official doc but, my question pertains to the history of the doc. When you rev up a document, do you have to have the "rev history box"? To specify who, what, when? I can see if you have a seperate form for the approval process, you have your history. However, if you don't have a seperate form for the approval process, it appears you would be lacking the revision history??? Thanks for any help you can provide.:)
Roland Cooke
The issued document needs a revision number, to enable doc control. The details of the revision, and any previous histories, do not need to be explained on the actual issued document (though they can be). As long as they are detailed somewhere, that's the only requirement IMO.
Usually a Doc change notice is used, which when signed off by all related process heads will authorise the release of the next version of pertinent document. This Doc change notice captures the history (what led to the change and where) like audit CA / Customer complaint / CAPA / Any other related process modification and such things .... The Doc change notice number is captured in the new release of the document in question. One such notice could be a lead to several document changes. (Very similar to an ECR ECN process) This works well and is a proof for good process interactions too.
Somashekar
INDIA
R SaMD - Software as a Medical Device - Software change control form ISO 13485:2016 - Medical Device Quality Management Systems 3
S Change Control Form vs. Document Change Notification ISO 13485:2016 - Medical Device Quality Management Systems 3
S Is it possible to have a General Change Control SOP and Form? Document Control Systems, Procedures, Forms and Templates 6
D Design/Change Control Form Example and Advice Design and Development of Products and Processes 13
D Form Change Control - Should forms be cosigned? Document Control Systems, Procedures, Forms and Templates 3
D Change Control Procedure and form / template - TS 16949 Clause 7.1.4 IATF 16949 - Automotive Quality Systems Standard 1
G Change Control for Test Samples Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Z Change color or shape of individual data point in control chart Using Minitab Software 6
N Change Control for processes & products Manufacturing and Related Processes 7
Quality Specialist Change Control Numbering system Document Control Systems, Procedures, Forms and Templates 7
M Change control on Tracking Sheet ISO 13485:2016 - Medical Device Quality Management Systems 11
H Control of Change i.e. process and WI IATF 16949 - Automotive Quality Systems Standard 9
D Engineering Change order vs. Change Control ISO 13485:2016 - Medical Device Quality Management Systems 3
D GAMP CAT 5 Change Control Qualification and Validation (including 21 CFR Part 11) 9
J Need Change Control Yes/No Decision Tree Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A UDI and Design Controls - Labeling change via the Design Control process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D Change Control - Product Name Change and its associated labeling EU Medical Device Regulations 7
U Change Management vs Change Control? Design and Development of Products and Processes 4
R Software change control process and defect tracking ISO 13485:2016 - Medical Device Quality Management Systems 1
Y Informational Change control process - Major vs Minor change - Active class III medical devices ISO 13485:2016 - Medical Device Quality Management Systems 13
T Change control and configuration management - When to create a new model/part number? Other Medical Device and Orthopedic Related Topics 0
JoshuaFroud Change Control - Minimum Requirements and Unhappy Staff ISO 13485:2016 - Medical Device Quality Management Systems 16
N Change Control - Compliance with FDA 21 CFR Part 820 Document Control Systems, Procedures, Forms and Templates 3
A Can change control can be closed if the CAPA is still open? Nonconformance and Corrective Action 3
S DHF File Change Control Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C Medical Device Website Change Control ISO 13485:2016 - Medical Device Quality Management Systems 3
Y Change Control - General Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
B IATF 16949 Clause 8.5.6.1.1 (Temporary Process Control Change) IATF 16949 - Automotive Quality Systems Standard 25
R Does anyone have any experience on change control? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
E Challenges in document control, revisional control, and change control Document Control Systems, Procedures, Forms and Templates 8
E Control Plan Contents - Part Number / Latest Change Level FMEA and Control Plans 2
M Document Change Control for a Very Small Business Document Control Systems, Procedures, Forms and Templates 12
S How to connect NCMR, Deviations and Change Control ? Nonconformance and Corrective Action 2
V Can Regulatory Head Initiate/Trigger the Change Control for Quality Procedures US Food and Drug Administration (FDA) 9
T Change Control Requirements when changing Suppliers IATF 16949 - Automotive Quality Systems Standard 4
drgnrider How to control documents that most likely won't change ever ? Document Control Systems, Procedures, Forms and Templates 5
T Paper Quality Manual Change Control Methods Quality Management System (QMS) Manuals 5
A Company Name Change & Control of Documents Document Control Systems, Procedures, Forms and Templates 9
L Use of checksum(s) to control product change(s) Misc. Quality Assurance and Business Systems Related Topics 1
C Change Control Forms Post Software Validation Medical Information Technology, Medical Software and Health Informatics 2
T Searching for books which have content of 7.1.4. Change Control topics Book, Video, Blog and Web Site Reviews and Recommendations 2
C Change Control in a SCRUM World Misc. Quality Assurance and Business Systems Related Topics 3
J Change in our SharePoint Document Control Process - Is this ok? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
H Blood Banking (CFR 21 PART 606) Change Control Requirements US Food and Drug Administration (FDA) 8
K Change Control for Software System that Controls Aspects of GMP Quality Assurance and Compliance Software Tools and Solutions 5
E Help with ECR/DCR Document Change Control Software Validation Qualification and Validation (including 21 CFR Part 11) 6
J ECO (Engineering Change Order) Control for Unreleased Products Document Control Systems, Procedures, Forms and Templates 3
A Change Ratio [Guideline in Control Limit Update] Statistical Analysis Tools, Techniques and SPC 3
