Change Control Numbering system
Quality Specialist
Hello, I recently got hired for a small company (12 employees) where I am in control of documents and most of the other QMS system aspects. I do not have much experience regarding Change Control (or whatever you choose to call it i.e., ECO) as far as how to keep track of CO #'s so that no number is reused and doesn't create a filing nightmare. We do not have any software for any QMS processes such as for internal audits, CA's, doc. control and the likes.
How do any of you manage to keep track of CO#'s past a doc/form # and rev? Is it necessary to have an individual number issued for every CO that comes across my desk? If so, what is the best way to do this, say in an excel spreadsheet or other method?
John C. Abnet
Teacher, sensei, kennari
Welcome to the site and the world of QMS @Quality Specialist. There are numerous expert resources on here that will prove helpful to you I'm sure.
Before I/we respond, can you help me understand what you mean by "CO" ??
Thank you.
Quality Specialist
Thank you for the welcome! I actually have been here a long time - went through the loss of Elsmar a bit back in time. I was then called Audit Coordinator. Lost my handle when Elsmar came back and got a new job as well.
Depending on where one works (I'm finding out) it is sometimes called ECO, Engineering Change Order, ECC - Engineering Change Control, CO - Change Order and such. In this case we are using the CO.
Quote from above: 1636586620099.png
Thee Bouyyy
Multiple Personalities
Simply create one excel sheet for all the engineering change orders. Make that as documented information.
Of course, you have to assign individual number issued for every change order. Excel spreadsheet is the best solution if you don't have any other QMS software.
John C. Abnet
Quote from above: View attachment 28380
This can be a complex data base that allows circulation, records signatures, etc...or....as @Thee Bouyyy stated, just a centralized Excel document, or , depending on the size of your organization, it may be as simple as a "revision record" section at the back of each document identifying the rev, approval, description of change, et.c....
There are even options for revision tracking. For example, it is common for organizations to give an original document no revision, and then each subsequent revision an -A; -B, etc...
Or, from my experience, I prefer a change point control tracking/serial number . For example, each change point request is assigned a unique sequential number (e.g. CP-0001; CP-0002; etc..etc....) This way there can be a record maintained per that number even if the change request is rejected. The history, description, approvals can then be kept centrally and the only information that needs applied to the "document" is the relevant change point tracking number (e.g. CP-0002, etc...). Since this number is unique it can also be referenced in regard to action/change taken on corrective actions, as results of audits, etc...
Remember, change control is often more complex than organizations give credit. Consider the following...
My counsel:
Map out (process flow) the entire change point control system, including all potential inputs...
a) If customer requests change. Does finance/sales need involved?? Does engineering need to approve?
b) If supplier requests change, does customer need notified? Does finance/sales need involved? Is a drawing impacted?
c) If someone internal to the organization requests a change. Does it impact a supplier? Does customer need notified? Is a drawing impacted?
Food for thought.
Hope this helps.
Be well.
Mikey324
I say make this as complex as needed to provide value for you. I personally love excel spreadsheets. I have a MOC spreadsheet (management of change). Make columns as you need them. If this is for IATF, there are certain things you need to consider, but they are easy to document if laid out in a simple spreadsheet.
I have an ECO (engineering change order) log for my company in an excel workbook. I have conditional formatting to make sure there are no duplicate numbers assigned.
Our numbering scheme is EC(YY)-001, example: EC21-001. That way each change order has a unique number that can be referenced for additional information. The log has top-level information that is contained in more detail on the ECO form.
  • ECO#
  • Status
  • Request Date
  • Approval Date
  • Training Required
  • CAPA#/Deviation#/Validation#, etc (the document number if the ECO was generated or linked to another QMS process)
  • Description
  • Originator
  • Originator Dept
  • Reason for Change
To build on what John said here:
My counsel:
We use a matrix to determine who needs to sign off for approval, its quite helpful.
A Tool Modification Drawing Change Control and Numbering Document Control Systems, Procedures, Forms and Templates 1
G Change Control for Test Samples Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Z Change color or shape of individual data point in control chart Using Minitab Software 6
N Change Control for processes & products Manufacturing and Related Processes 7
M Change control on Tracking Sheet ISO 13485:2016 - Medical Device Quality Management Systems 11
H Control of Change i.e. process and WI IATF 16949 - Automotive Quality Systems Standard 9
D Engineering Change order vs. Change Control ISO 13485:2016 - Medical Device Quality Management Systems 3
D GAMP CAT 5 Change Control Qualification and Validation (including 21 CFR Part 11) 9
J Need Change Control Yes/No Decision Tree Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A UDI and Design Controls - Labeling change via the Design Control process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D Change Control - Product Name Change and its associated labeling EU Medical Device Regulations 7
U Change Management vs Change Control? Design and Development of Products and Processes 4
R Software change control process and defect tracking ISO 13485:2016 - Medical Device Quality Management Systems 1
R SaMD - Software as a Medical Device - Software change control form ISO 13485:2016 - Medical Device Quality Management Systems 3
Y Informational Change control process - Major vs Minor change - Active class III medical devices ISO 13485:2016 - Medical Device Quality Management Systems 13
T Change control and configuration management - When to create a new model/part number? Other Medical Device and Orthopedic Related Topics 0
JoshuaFroud Change Control - Minimum Requirements and Unhappy Staff ISO 13485:2016 - Medical Device Quality Management Systems 16
N Change Control - Compliance with FDA 21 CFR Part 820 Document Control Systems, Procedures, Forms and Templates 3
A Can change control can be closed if the CAPA is still open? Nonconformance and Corrective Action 3
S DHF File Change Control Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C Medical Device Website Change Control ISO 13485:2016 - Medical Device Quality Management Systems 3
Y Change Control - General Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Change Control Form vs. Document Change Notification ISO 13485:2016 - Medical Device Quality Management Systems 3
B IATF 16949 Clause 8.5.6.1.1 (Temporary Process Control Change) IATF 16949 - Automotive Quality Systems Standard 25
R Does anyone have any experience on change control? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
E Challenges in document control, revisional control, and change control Document Control Systems, Procedures, Forms and Templates 8
E Control Plan Contents - Part Number / Latest Change Level FMEA and Control Plans 2
M Document Change Control for a Very Small Business Document Control Systems, Procedures, Forms and Templates 12
S How to connect NCMR, Deviations and Change Control ? Nonconformance and Corrective Action 2
V Can Regulatory Head Initiate/Trigger the Change Control for Quality Procedures US Food and Drug Administration (FDA) 9
T Change Control Requirements when changing Suppliers IATF 16949 - Automotive Quality Systems Standard 4
drgnrider How to control documents that most likely won't change ever ? Document Control Systems, Procedures, Forms and Templates 5
T Paper Quality Manual Change Control Methods Quality Management System (QMS) Manuals 5
A Company Name Change & Control of Documents Document Control Systems, Procedures, Forms and Templates 9
L Use of checksum(s) to control product change(s) Misc. Quality Assurance and Business Systems Related Topics 1
C Change Control Forms Post Software Validation Medical Information Technology, Medical Software and Health Informatics 2
T Searching for books which have content of 7.1.4. Change Control topics Book, Video, Blog and Web Site Reviews and Recommendations 2
C Change Control in a SCRUM World Misc. Quality Assurance and Business Systems Related Topics 3
J Change in our SharePoint Document Control Process - Is this ok? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Is it possible to have a General Change Control SOP and Form? Document Control Systems, Procedures, Forms and Templates 6
H Blood Banking (CFR 21 PART 606) Change Control Requirements US Food and Drug Administration (FDA) 8
K Change Control for Software System that Controls Aspects of GMP Quality Assurance and Compliance Software Tools and Solutions 5
E Help with ECR/DCR Document Change Control Software Validation Qualification and Validation (including 21 CFR Part 11) 6
J ECO (Engineering Change Order) Control for Unreleased Products Document Control Systems, Procedures, Forms and Templates 3
A Change Ratio [Guideline in Control Limit Update] Statistical Analysis Tools, Techniques and SPC 3
L Engineering Change Control Software Systems - Recommendations? Document Control Systems, Procedures, Forms and Templates 2
T TS 16949 compliant Change Control Management Process IATF 16949 - Automotive Quality Systems Standard 3
A Document Control Procedure Change 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
