Change Control Systems - How much is too much?
Should a small company with a single product have multiple Change Control Systems?
  • Total voters
    9
4
4LeanDocs
How many Change Control systems are too Many?
My company is starting to put together the quality system for an FDA regulated device. The current plan is for 3 different change control systems, meaning 3 different forms, 3 different rule sets, 3 different procedures, 3 different databases (we have also established 2 different part number schemes):
1. Quality System
2. Minor part changes
3. Design changes
From my user name you can deduce that I might have a problem with this. I've found with previous experiences that more generally leads to confusion and un-needed bureaucracy. Have any other forum users dealt with this issue and if yes, what has been the outcome?
Too much? Just right? :confused:
Coury Ferguson
Moderator here to help
Re: Change Control - How much is too much?
1. Quality System
3. Design changes
One question: Have you brought this to the attention of your Management Team?
What needs to be done in my opinion, is to use what works best for the Organization. If the organization wants this many, then so be it. But, you could argue the facts exactly how you have stated in your post with Top Management.
tomvehoski
I typically agree with keeping QMS changes under a different process than design changes. In a small place, QMS changes should be pretty quick and may only need one approval after an easy review. Design changes may need much more review, testing, simulation, customer approval, tool design, tool approval, process approval, .........
I don't understand how a "minor part change" is different than a "design change". A minor change can mess things up big time if you don't do the right planning and reviews.
Ajit Basrur
4LeanDocs,
Change Control is required but how many is your organization's call - but by the examples that you cited, one "good" system should be able to address all :)
BTW, I feel the poll is not required for this required
Jen Kirley
Quality and Auditing Expert
4LeanDocs,
I agree. One system can handle different types and "levels" of change. You can have "Level 1/2/3" for the purpose of identifying how much and what type of supporting data is required, as well as groups/authoruty levels of approvers. Make a complex system and people will find reasons not to use it.
arios
4LeanDocs,
I agree with Shirley and Ajit
BTW, it does not have to be electronic, even a paper based system with change forms and section for approvals would work
MIREGMGR
We have a complex mostly-medical-device environment...~2700 active products, products under our name+private name manufacturing+contract manufacturing, Class I & Class II, kit packing, various types of suppliers, subject to three major and several other medical device regulatory systems...and we get by with one change control system.
Ajit Basrur
A single system explains the beauty of handling such a complex system :)
G
George Weiss
Since this is an FDA item, I would pull out my only tool here, the FDA QMS and say, look at them and how they do it. Some big companies stumble when not dealing with changes correctly, and get dinged by the FDA. Different rules for different events.
Likely different forms, and completely different issues, maybe. I suggest you give them a look.
http://www.fda.gov/ScienceResearch/FieldScience/default.htm
sellect volume I II II or IV
L Engineering Change Control Software Systems - Recommendations? Document Control Systems, Procedures, Forms and Templates 2
D GAMP CAT 5 Change Control Qualification and Validation (including 21 CFR Part 11) 0
J Need Change Control Yes/No Decision Tree Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A UDI and Design Controls - Labeling change via the Design Control process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D Change Control - Product Name Change and its associated labeling EU Medical Device Regulations 7
U Change Management vs Change Control? Design and Development of Products and Processes 4
R Software change control process and defect tracking ISO 13485:2016 - Medical Device Quality Management Systems 1
R SaMD - Software as a Medical Device - Software change control form ISO 13485:2016 - Medical Device Quality Management Systems 3
Y Informational Change control process - Major vs Minor change - Active class III medical devices ISO 13485:2016 - Medical Device Quality Management Systems 12
T Change control and configuration management - When to create a new model/part number? Other Medical Device and Orthopedic Related Topics 0
JoshuaFroud Change Control - Minimum Requirements and Unhappy Staff ISO 13485:2016 - Medical Device Quality Management Systems 16
N Change Control - Compliance with FDA 21 CFR Part 820 Document Control Systems, Procedures, Forms and Templates 3
A Can change control can be closed if the CAPA is still open? Nonconformance and Corrective Action 3
S DHF File Change Control Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C Medical Device Website Change Control ISO 13485:2016 - Medical Device Quality Management Systems 3
Y Change Control - General Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Change Control Form vs. Document Change Notification ISO 13485:2016 - Medical Device Quality Management Systems 3
B IATF 16949 Clause 8.5.6.1.1 (Temporary Process Control Change) IATF 16949 - Automotive Quality Systems Standard 24
R Does anyone have any experience on change control? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
E Challenges in document control, revisional control, and change control Document Control Systems, Procedures, Forms and Templates 8
E Control Plan Contents - Part Number / Latest Change Level FMEA and Control Plans 2
M Document Change Control for a Very Small Business Document Control Systems, Procedures, Forms and Templates 12
S How to connect NCMR, Deviations and Change Control ? Nonconformance and Corrective Action 2
V Can Regulatory Head Initiate/Trigger the Change Control for Quality Procedures US Food and Drug Administration (FDA) 9
T Change Control Requirements when changing Suppliers IATF 16949 - Automotive Quality Systems Standard 4
drgnrider How to control documents that most likely won't change ever ? Document Control Systems, Procedures, Forms and Templates 5
T Paper Quality Manual Change Control Methods Quality Management System (QMS) Manuals 5
A Company Name Change & Control of Documents Document Control Systems, Procedures, Forms and Templates 9
L Use of checksum(s) to control product change(s) Misc. Quality Assurance and Business Systems Related Topics 1
C Change Control Forms Post Software Validation Medical Information Technology, Medical Software and Health Informatics 2
T Searching for books which have content of 7.1.4. Change Control topics Book, Video, Blog and Web Site Reviews and Recommendations 2
C Change Control in a SCRUM World Misc. Quality Assurance and Business Systems Related Topics 3
J Change in our SharePoint Document Control Process - Is this ok? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Is it possible to have a General Change Control SOP and Form? Document Control Systems, Procedures, Forms and Templates 6
H Blood Banking (CFR 21 PART 606) Change Control Requirements US Food and Drug Administration (FDA) 8
K Change Control for Software System that Controls Aspects of GMP Quality Assurance and Compliance Software Tools and Solutions 5
E Help with ECR/DCR Document Change Control Software Validation Qualification and Validation (including 21 CFR Part 11) 6
J ECO (Engineering Change Order) Control for Unreleased Products Document Control Systems, Procedures, Forms and Templates 3
A Change Ratio [Guideline in Control Limit Update] Statistical Analysis Tools, Techniques and SPC 3
T TS 16949 compliant Change Control Management Process IATF 16949 - Automotive Quality Systems Standard 3
A Document Control Procedure Change 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M Internal Auditing of Area with Active Change Control Internal Auditing 14
M Change Control Process - Deviation from Standard for Parts Document Control Systems, Procedures, Forms and Templates 1
Q Document Control ECO (Engineering Change Order) or QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
T Living Documents which change every day - Control or Uncontrolled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
A Change Control Review Management Success or Effectiveness Metric Quality Manager and Management Related Issues 3
C Change Control Plan/Procedure for Slickline/Wireline Services (Oil Field) Quality Manager and Management Related Issues 1
A Design/Change Control Procedure - How to cope with Changes during Development? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 26
