Change in our SharePoint Document Control Process - Is this ok?
james_r
We're considering a change to our document control process to much simplify and streamline it. I'd like to get some feedback on the idea.
Our documents are maintained on an software system (SharePoint) which provides us a mechanism for reviewing and approval of changes - as you'd expect.
we maintain two list of documents, a 'live' one and one for documents being modified, it all works well but is slow and employees are 'put off' making changes by the effort required.
I'd like to change the process so that changes can be made directly to the 'live' set of documents, the change details would be logged automaticly and report to me immediately. I can then review the change and undo it or accept it. this would only be permitted for two scenarios:
-where the change is for a minor modification (typo's etc)
-where the change is to reflect current practices only (i.e. process or policy out of date etc)
not to be used for introduction of new working practices.
Is there anything here which stands out as being contrary to iso9001 ?
qusys
No, there is not.
You as an organization shall have a documented procedure for document control where the organization establish what it does to meet requirements of 4.2.3 clause of ISO 9001, independently from the used system. The important factor is related to the effectiveness of this process/activity.
blueboat
Hi James, you raised a very good idea for the documents management. Don't worry about the standard, there is no such limitation on what you want to do.
I
isoalchemist
:2cents:You are on a possible slippery slope with at approach. Typo?s are no big deal, but 4.2.4a ?to approve documents for adequacy prior to issue? becomes problematic if you allow changes to the ?live? documents without your review or others that may need to approve it. If a practice isn?t being followed or out of date correcting it is only one part of the problem, the other question is how did it occur without being caught.
Additionally you may have some cross departmental procedures that one group may change, but affect other groups in that process and they would be live without proper approval. Yes, your intent is that you will act upon the changes immediately, but life and work tend to interfere with even the best intentions.
I?m sure you could devise something to be meet the intent of the standard, but be prepared to defend it to auditors because they will be skeptical and start digging into the change being made and revised by the proper individual and where the determination for re-training/communication falls, because you will have a ?live? procedure that you may need to have training on even though it is just a revision.
deanbell
Completely agree with isoalchemist here.
The company I work for also uses SharePoint for document control. Whilst I've found it to be a decent tool for document control, I found a lack of restrictions over change control to procedural documents in the corporate document library. Virtually anyone had the ability to 'check-out' a document, edit its content and the check it back in without any formal review for authorization or cross-departmental approval.
The first thing that I did was have our IT gurus lock down edit control of all SharePoint document libraries to myself (as corporate HSEQ Manager). Each document in the library was then assigned an 'owner', usually a department manager, who was provided access to the master copy of the document when they wished to make a change. Any changes to cross-departmental procedures must be reviewed by all relevant internal stakeholders.
Once document content changes have been made and reviewed, the document is emailed to myself for quality review (i.e. formatting, document numbering, version control, updating the organisational document register), and then uploaded into SharePoint.
I'll admit that there was some initial resistance, as some had a view that this would slow down the procedural review process and introduce unnecessary bureaucratic control. However, it didn't take too long before the new process caught on and was accepted. Further, during the following ISO9001 surveillance audit this change in process was noticed and commented on favourably.
As iloalchemist has said "life and work tend to interfere with even the best of intentions". If you loosen the controls over the document change process, people will find ways to circumvent your intentions, and it is very likely that you'll have to backtrack and try to restore previous controls.
As other posters have said, there is nothing in ISO9001 that prevents you from doing what you wish, though before doing so you should anticipate human behavior.
Good luck :)
st2323
I also am in the process of switching our Document Control over to a Google Site/Wiki type system as well. The simplicity and revision control is really easy to control as well as going back to previous revisions if needed.
I think keeping the document live is OK as long as you review the change and can roll back to the previous revision. There is another discussion which details a Company using a Wiki and any employee can make a change. If that change is reviewed and accepted the document is left as is. If there is an issue, that document can be rolled back to the previous revision and corrected.
I wonder as well if this is OK according to the Standard.
mguilbert
We also use Sharepoint. You can determine each individual employees level of control by using edit permissions. ie Full Control, Design, Contribute, and Read Only. At my company we allow managers to change documents that are used solely in their departments. As far as upper level documents they are read only for all except a very few. Make sure that your IT department has given you full control so that you can edit permissions.
st2323
Yep, permissions are another great way to control your documentation. Email notifications when a document is changed is great too.
We even created our Forms in Google Docs where it populates a spreadsheet with the responses entered, such as our CAPA's, Non Conforming Products, etc. Just print out that spreadsheet when you have a Management Review meeting and everything is right there. Or just share the spreadsheet with your MR team and your all set.
Sure beats paying for a license for some Document Management software that does the same exact thing.
M Change Orders in SharePoint Document Control Systems, Procedures, Forms and Templates 3
JoCam Change of Legal Manufacturer EU Medical Device Regulations 0
Sidney Vianna Informational ISO/TS 10020:2022 Quality management systems — Organizational change management — Processes Other ISO and International Standards and European Regulations 0
0 Complaints time series significant change Customer Complaints 41
N Malaysia Shelf Life Change Other Medical Device Regulations World-Wide 2
P Self Certified Class 1 MDR 2017/745 Design Change CE Marking (Conformité Européene) / CB Scheme 2
O Article 120 - significant change interpretation EU Medical Device Regulations 4
V Would the customer drawing change necessitate re-PPAP of the Product? APQP and PPAP 3
S Do we have to create a new PPAP to our customer if our Sub Contractor had to change? APQP and PPAP 10
M PMA submission change Medical Device and FDA Regulations and Standards News 0
U Change to the manufacturing Date for a device in the field US Medical Device Regulations 0
F Change in address for critical supplier - does NB need to be informed? CE Marking (Conformité Européene) / CB Scheme 20
K Change in address on ERLM US FDA: Implications to import US Medical Device Regulations 0
N Change our Registrar? Pros and Cons ? Registrars and Notified Bodies 8
F Using non-randomized clinical study for change in existing 510(k) device? US Food and Drug Administration (FDA) 1
FuzzyD ISO 13485 change in process ISO 13485:2016 - Medical Device Quality Management Systems 3
R IVD Label Change China Medical Device Regulations 1
Judy Abbott Change of PVC stabilizer Japan Medical Device Regulations 6
R IVD Label Change Requirements Other Medical Device Regulations World-Wide 0
M EE's - Laptops/Printer Change and Emissions Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
D Document Change Approval ISO 13485:2016 - Medical Device Quality Management Systems 6
mtmt70a Change\ my MTBF Prediction SW Tool from the RELEX tool with yearly Lic. access Telecordia database to another solution. Recommendations? Reliability Analysis - Predictions, Testing and Standards 0
S Can a product option change the product class? CE Marking (Conformité Européene) / CB Scheme 2
M Regulatory Change assessment US Food and Drug Administration (FDA) 3
G Software change management Design and Development of Products and Processes 3
J Changes to OS - Significant change under MDR EU Medical Device Regulations 8
A If document coding is change will there be a revision Document Control Systems, Procedures, Forms and Templates 1
G Change Control for Test Samples Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Z Change color or shape of individual data point in control chart Using Minitab Software 6
J Medical Device Component Change - Testing, Sampling Criteria ISO 14971 - Medical Device Risk Management 3
S When to change the status of a GTIN from "Premarket" to "In Use" ? US Medical Device Regulations 2
Y Is there any EU Significant change guidance issued? EU Medical Device Regulations 5
B How to change hour format to text but not changing the number ? Excel .xls Spreadsheet Templates and Tools 1
N API Q1, Management of Change & Document Change Request Oil and Gas Industry Standards and Regulations 4
adir88 Substantial Change to QMS (Annex IX, Chapter I) EU Medical Device Regulations 0
A Eudamed actor registrations if you change AR for MDR product EU Medical Device Regulations 0
C Change Management Process ISO 14971 - Medical Device Risk Management 8
S ISO13485:2016 7.3.9 design and development change ISO 13485:2016 - Medical Device Quality Management Systems 3
N Change Control for processes & products Manufacturing and Related Processes 7
Quality Specialist Change Control Numbering system Document Control Systems, Procedures, Forms and Templates 7
D Laboratories listed in the Declaration of Conformity change Canada Medical Device Regulations 1
M Change control on Tracking Sheet ISO 13485:2016 - Medical Device Quality Management Systems 11
D EU MDR - Change of device name (legacy device) EU Medical Device Regulations 17
L Change Log in (controlled) Forms? (ISO 9001:2015) Document Control Systems, Procedures, Forms and Templates 6
H Control of Change i.e. process and WI IATF 16949 - Automotive Quality Systems Standard 9
dgrainger Informational MHRA's Software and AI as a Medical Device Change Programme UK Medical Device Regulations 0
K Is implementing Electronic Signatures a Significant Change to the QMS? ISO 13485:2016 - Medical Device Quality Management Systems 10
A Management of change procedure for ISO 45001 Occupational Health & Safety Management Standards 5
N Cleanroom Classification Change Other Medical Device Related Standards 7
D Engineering Change order vs. Change Control ISO 13485:2016 - Medical Device Quality Management Systems 3
