Change Ratio [Guideline in Control Limit Update]
Apoch
Hello All,
I'd like to check with you whether you are following a change ratio to serve as guideline in the need for control limit update.
I've seen the mention of change ratio in Intel's training material: pg 53-54 of source:
wenku.baidu.com/view/acb18969a45177232f60a29e.html
Change ratio is to be calculated through the following formula:
CR = abs-value {[CL(old)-CL(new)]/stdev}
A change ratio of > 1.5 is deemed to be a problem while > 1.0 is deemed to be potentially a problem.
Thoughts?
Steve Prevette
Deming Disciple
Seems like there is a circular logic problem. I don't change my control limits unless I have justification to, generally with a trending signal (such as a point outside the control limits). But this seems to suggest that I calculate new control limits, and then use the new control limit as justification to calculate the new control limits. Hmmmm.
Darius
Interesting, I have seen some control charts with changes on control limits but not a word about how it was done.
I have done something similar but as a statistical test :mg:, It has been a topic with some experts, if control charts can be taken as a statistical test, many are against it, but I found it handy for change detection. This approach can be more fast as detection rule..., it may worth have a try, but a point to be addresed is how many points should be taken from the last point, because a change includes more variation and a change of mean, but if you take 10000 points the last few point showing a change may not affect the statistics in a noticeable way.
Any process changes, narrow control limits or not reflecting the same parameters as the process it self (mean and standard deviation) could result on many false alarms because the practitioner didn't saw the change and changed the control limits accordingly. Agree that Donald Wheeler said the same Steve said, sort of "recalculate only if you know something changed", but fixing it just make it sort of specs limits.
Steve Prevette
Deming Disciple
Here is a writeup on the logic I use: http :// www .efcog .org/wg/esh_es/Statistical_Process_Control/SPC_Trending_Primer/daytwo/20 Life Cycle of a Trend Day Two.pdf - DEAD LINK (404) UNLINKED
I am probably more willing to follow a statistical signal in rebaselining than Dr. Wheeler would, in the case of one can't figure out the reason in the process that the change occurred. Certainly it is preferable to BOTH have a SPC signal, and also knowledge that the process indeed did change.
0 Complaints time series significant change Customer Complaints 40
N Malaysia Shelf Life Change Other Medical Device Regulations World-Wide 2
P Self Certified Class 1 MDR 2017/745 Design Change CE Marking (Conformité Européene) / CB Scheme 2
O Article 120 - significant change interpretation EU Medical Device Regulations 4
V Would the customer drawing change necessitate re-PPAP of the Product? APQP and PPAP 3
S Do we have to create a new PPAP to our customer if our Sub Contractor had to change? APQP and PPAP 10
M PMA submission change Medical Device and FDA Regulations and Standards News 0
U Change to the manufacturing Date for a device in the field US Medical Device Regulations 0
F Change in address for critical supplier - does NB need to be informed? CE Marking (Conformité Européene) / CB Scheme 20
K Change in address on ERLM US FDA: Implications to import US Medical Device Regulations 0
N Change our Registrar? Pros and Cons ? Registrars and Notified Bodies 5
F Using non-randomized clinical study for change in existing 510(k) device? US Food and Drug Administration (FDA) 1
FuzzyD ISO 13485 change in process ISO 13485:2016 - Medical Device Quality Management Systems 3
R IVD Label Change China Medical Device Regulations 1
Judy Abbott Change of PVC stabilizer Japan Medical Device Regulations 6
R IVD Label Change Requirements Other Medical Device Regulations World-Wide 0
M EE's - Laptops/Printer Change and Emissions Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
D Document Change Approval ISO 13485:2016 - Medical Device Quality Management Systems 6
mtmt70a Change\ my MTBF Prediction SW Tool from the RELEX tool with yearly Lic. access Telecordia database to another solution. Recommendations? Reliability Analysis - Predictions, Testing and Standards 0
S Can a product option change the product class? CE Marking (Conformité Européene) / CB Scheme 2
M Regulatory Change assessment US Food and Drug Administration (FDA) 3
G Software change management Design and Development of Products and Processes 3
J Changes to OS - Significant change under MDR EU Medical Device Regulations 8
A If document coding is change will there be a revision Document Control Systems, Procedures, Forms and Templates 1
G Change Control for Test Samples Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Z Change color or shape of individual data point in control chart Using Minitab Software 6
J Medical Device Component Change - Testing, Sampling Criteria ISO 14971 - Medical Device Risk Management 3
S When to change the status of a GTIN from "Premarket" to "In Use" ? US Medical Device Regulations 2
Y Is there any EU Significant change guidance issued? EU Medical Device Regulations 5
B How to change hour format to text but not changing the number ? Excel .xls Spreadsheet Templates and Tools 1
N API Q1, Management of Change & Document Change Request Oil and Gas Industry Standards and Regulations 4
adir88 Substantial Change to QMS (Annex IX, Chapter I) EU Medical Device Regulations 0
A Eudamed actor registrations if you change AR for MDR product EU Medical Device Regulations 0
C Change Management Process ISO 14971 - Medical Device Risk Management 8
S ISO13485:2016 7.3.9 design and development change ISO 13485:2016 - Medical Device Quality Management Systems 3
N Change Control for processes & products Manufacturing and Related Processes 7
Quality Specialist Change Control Numbering system Document Control Systems, Procedures, Forms and Templates 7
D Laboratories listed in the Declaration of Conformity change Canada Medical Device Regulations 1
M Change control on Tracking Sheet ISO 13485:2016 - Medical Device Quality Management Systems 11
D EU MDR - Change of device name (legacy device) EU Medical Device Regulations 17
L Change Log in (controlled) Forms? (ISO 9001:2015) Document Control Systems, Procedures, Forms and Templates 6
H Control of Change i.e. process and WI IATF 16949 - Automotive Quality Systems Standard 9
dgrainger Informational MHRA's Software and AI as a Medical Device Change Programme UK Medical Device Regulations 0
K Is implementing Electronic Signatures a Significant Change to the QMS? ISO 13485:2016 - Medical Device Quality Management Systems 10
A Management of change procedure for ISO 45001 Occupational Health & Safety Management Standards 5
N Cleanroom Classification Change Other Medical Device Related Standards 7
D Engineering Change order vs. Change Control ISO 13485:2016 - Medical Device Quality Management Systems 3
Watchcat Change Request Documents - What's Typical These Days? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 14
NDesouza Management of Change (MOC) Manufacturing and Related Processes 11
H Customer Specific Change in a SaaS SAMD IEC 62304 - Medical Device Software Life Cycle Processes 1
