Change revision number in document when only codification was changed
Q
QAMTY
Hi everybody
I work in a steel manufacturing company and I have to rename about 400 documents comprised of procedures, formats, some other type of documents.
The question is, do I have to change the revision number, if only the codification was changed? nothing changed into the document.
Please feed me back.
Marc
You're wanting to change document numbering, correct? Your problem is going to be with documents which reference other documents within their content. How do plan to address that issue?
Q
QAMTY
Welll the idea it is no to affect other documents for this change, how? doing it all
in one session.
let say to do this at night, when documents are not needed.
The main Issue I face, it is if I have to register the change in the control on each document, one by one
all of them have not changed the content.
Q
QAMTY
Thanks Randy
Specifically in this point says nothing, I mean in the case that only the codification is changed.
L
laila bano
I also face the same problem, i would really like to appreciate if someone help me in this regard.
Like the document Revision Number is 00 so after which type of change we need to update the revision number. It would be a single word or a whole sentence, or it would be some technical change in our documents .
Q
QAMTY
I´d say, what have a real impact in the system.
Sometimes there are "cosmetic" changes which don´t affect anything. A change in a process, in responsibilities, in scope, need a new revision.
Normally cosmetic changes are minimal.
Hope it helps
P
PVMRS
I do not think you need to revise all 400 documents for change in code of the project / product if it does not have any impact on operator safety, product quality and issue of mix ups and customer communication.
Raise a temporary change control and state that whenever these documents are due for revision, will be revised accordingly and as an immediate step, a document ratification / Errata form shall be attached along with all the effected documents. it will help you handle it system wise and will have little impact on the above issues.
D TS 16949 Control Plan and Part Number Revision Change Level FMEA and Control Plans 1
K ECO (Engineering Change Order) Revision - Letter change or part number change? Manufacturing and Related Processes 13
M Is There a Revision History or Change Log for Canadian Regulations? Canada Medical Device Regulations 3
S Customer Part Revision Change IATF 16949 - Automotive Quality Systems Standard 3
T AS9102 FAIR - Customer Drawing Revision Change AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Change and Revision Status Identification for a Document ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
V Do I need dimensionals performed for PPAP for every revision change? APQP and PPAP 2
A SAE J1739 new revision published on Jan 2009 but I can't find a change summary FMEA and Control Plans 7
V What Constitutes a Document Change? Company Logo Revision Miscellaneous Environmental Standards and EMS Related Discussions 12
R Control of Documents - Change history question - Changes from previous revision OK? Document Control Systems, Procedures, Forms and Templates 11
L Revision of procedure - Can't update the procedure before the actual process change Document Control Systems, Procedures, Forms and Templates 13
L AS9102 Part Revision Change Levels AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 18
H Control Plan - "Latest Change Level" vs. Print Revision Level FMEA and Control Plans 16
M Quality Manual Change History - Can I eliminate the revision record from the manual? Quality Management System (QMS) Manuals 33
L Change Notification Requirements for class 1 devices Medical Device and FDA Regulations and Standards News 1
R CB/Auditor Requiring a change in scope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Ed Panek Notified Body Substantial Change MDD EU Medical Device Regulations 1
A Purchasing Controls on Change Management of Literature/Labeling ISO 13485:2016 - Medical Device Quality Management Systems 3
A For software change - New Channel of interoperability CE Marking (Conformité Européene) / CB Scheme 4
JoCam IEC 60601-1 and 60601-1-2 retest after PCBA change IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A ISO 13485 procedure change and reflect to legacy manufacture items ISO 13485:2016 - Medical Device Quality Management Systems 2
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
Q Time change via change of Time Zone Qualification and Validation (including 21 CFR Part 11) 3
T IEC 60601-1-8:2020 Is it necessary to change the alarm melody? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M Change in Constitution / Ownership of firm -------ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 1
U Power supply - Change From 160 to 300 Watts - Significant change? EU Medical Device Regulations 2
N Sterilization Protocol Change in Validation Process and further impacts ISO 13485:2016 - Medical Device Quality Management Systems 1
M Label change - 510(k) Medical Device and FDA Regulations and Standards News 5
M EMS change management ISO 14001:2015 Specific Discussions 2
E Document Change Request forms (or no forms)? ISO 13485:2016 - Medical Device Quality Management Systems 9
J Significant change related to design and intended use EU Medical Device Regulations 3
J Need Change Control Yes/No Decision Tree Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Cleaning process center change ISO 13485:2016 - Medical Device Quality Management Systems 4
U NOC - What is considered a "design change" EU Medical Device Regulations 5
qualprod What do CB´s change when doing a partial moving ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Y Algo change significancy Medical Information Technology, Medical Software and Health Informatics 3
Revision36 Engineering Change Order Industry Standards Other Medical Device and Orthopedic Related Topics 4
Z Iterative development and FDA change requests IEC 62304 - Medical Device Software Life Cycle Processes 12
D ECO (Engineering Change Order) process questions ISO 13485:2016 - Medical Device Quality Management Systems 7
R Medical Device - Change manufacturing plant Design and Development of Products and Processes 6
Tagin Template or Checklist for Process Change Document Control Systems, Procedures, Forms and Templates 5
A What does this line from MDCG 2020-3 (MDR art. 120 substantial change) mean to you? EU Medical Device Regulations 4
M Change management procedure when 7.3 is not applicable ISO 13485:2016 - Medical Device Quality Management Systems 5
Q Change the shape of the raw material FAI AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Engineering Change Order (ECO) metrics to track ISO 13485:2016 - Medical Device Quality Management Systems 6
P Notified Body Approval of Change EU Medical Device Regulations 2
