Changes in Medwatch Reporting Requirements
Bunny
Can anyone shed some light on what types of medical device complaints need to be reported? Years ago we used to only report adverse incidents that was caused or contributed by our medical device. Now that I am working for a different company, this company's policy is to report any incident that could possibly cause or contribute to an adverse event. They said that the FDA has become much more strict yet cannot show me a regulation that states this. Here are a couple of examples of incidents that I would not think are reportable and they do.
1. A sterilizer has a leak and water gets on the floor. The amount of water on the floor extends past the footprint of the machine. Even though no one slipped and fell, this would be reported.
2. A display monitor looses the image due to a power failure, unplugged cord, or another reason. Even though a secondary monitor continues to display the image, this would be considered reportable.
I would appreciate any advice on this topic.
L
lfrost
Bunny,
On the FDA Website, there is a summary of who and what needs to be reported to the FDA and the time frames for each incident. By your examples, both would not need to be reported as they are only malfunctions of the device. See the summary here http://www.fda.gov/MedicalDevices/D...quirements/ReportingAdverseEvents/default.htm
Using the summary tables contained in this summary, you can determine that what you describe would not need to be reported to the FDA as the incidents did not contribute to an adverse event nor death.
Hope this helps..
Bunny
Thank you, I am aware of that and pointed that out. But, they say that that was changed but not documented. So, I am asking what does the FDA expect? Do they expect to follow the written guidance or did they really tighten the definition and expect of to know? Is my new company correct?
L
lfrost
Bunny,
There really isn't a change in thinking. Manufacturers do not have to report malfunctions of devices if the malfunction did not contribute to or cause an adverse event, serious injury or death. FDA defines serious injury as when professional medical assistance is needed. So, in your two examples, because there was no adverse event, there is no need to report the malfunctions. If you would like further information, 21CFR803.50 is the part of the Code of Federal Regulations which govern medical device manufacturers as to what is to be reported. In that subpart, it states that the only time a malfunction needs to be reported is if the malfunction contributes to or causes a death or serious injury. Because your examples do not state that no one was injured, or died, due to the malfunction, then you do not need to report the event as it is not a medical device report (MDR).
:topic:
I would most likely explain that it would also be better not to make such a report to a public database as it would state that there is a possibility that a problem might exist with your device and cause a design change. I would suggest that instead of making a report, I would state that there should be a design review to ensure that the design of the device did not cause the malfunction to occur. I would feel better if a device design could be changed to reduce the risk, than submit a report that stated that we should have made a design change to let the public know that a design change, or some other change, could have prevented the malfunction from occurring again.
Just some off topic thoughts....
L
Laura Halper
Sorry for this delayed response to Bunny's question. I only just saw this thread.
I believe that the earlier responses were incomplete and may be a little misleading. Even if the device malfunction did not cause or contribute to a death or serious injury, the FDA requires that the malfunction be reported if the malfunction "would be likely to cause or contribute to a death or serious injury, if the malfunction were to recur" (21CFR 803.50(2)).
The regulation as written has an inherent assumption that if a malfunction has occurred, it could occur again (unless, of course, some corrective action was taken that eliminated the cause for the malfunction.) And I have seen a shift in FDA's expectations in this area. It used to be that if a malfunction did not recur for at least 2 years, the manufacturer could consider that the malfunction would not recur. But recently I saw a statement from FDA (unfortunately I don't have the citation handy) where they no longer accept this informal "two-year rule". This shift may be what Bunny's company has seen as FDA becoming more strict.
I have seen Warning Letters for not reporting malfunctions that did not result in death or serious injury, but that could result in death or serious injury if they recurred.
Hope this helps.
Bunny
Thank you Laura. I have since heard from a well respected regulatory consultant that that indeed is the current shift I was asking about. Maybe one day the regulations will be revised to be more clear as to the current thinking of the FDA.
R Changes vs CMO - How can we simplify this process? Supplier Quality Assurance and other Supplier Issues 3
Ed Panek What are the limits on manufacturing changes and substantial changes? EU Medical Device Regulations 6
F Hospital Rebrand & Name changes Document Control Systems, Procedures, Forms and Templates 4
M IEC 62304 Software changes - Minor labeling changes on the GUI IEC 62304 - Medical Device Software Life Cycle Processes 3
Aymaneh ISO 11607-1: 2019 main changes Other Medical Device Related Standards 2
L Process changes and biocompatibility (ISO 10993-1) Other Medical Device Related Standards 1
E ASTM F2118 - Fatigue testing of bone cement - Changes between the 2003 and the 2014? Other Medical Device Related Standards 1
qualprod Documented actions and changes in the QMS by COVID 19 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
B ASTM E18-2020 - Rockwell testing standard changes? General Measurement Device and Calibration Topics 2
D Recent changes to ISO 14971 - SOP required for managing standard revisions ISO 13485:2016 - Medical Device Quality Management Systems 1
I Dating controlled documents after changes - Revision History Document Control Systems, Procedures, Forms and Templates 13
F Medical Devices - Hong Kong - Post approval changes regulation (China's MOH) Other Medical Device Regulations World-Wide 3
F Medical Devices-South Africa _Post approval changes and Software Other Medical Device Regulations World-Wide 0
K Changes in process dispersion, and location hypotheses tests Using Minitab Software 3
NDesouza When Customers Make Changes to Orders Contract Review Process 24
S Managing specification changes on standard parts purchased through trading companies Document Control Systems, Procedures, Forms and Templates 2
I MSA requirement for 5 Micrometers + CP changes need customer approval? IATF 16949 - Automotive Quality Systems Standard 2
A ISO13485:2016 name and ownership changes questions ISO 13485:2016 - Medical Device Quality Management Systems 3
R What are the changes in 5th Edition of FMEA manual? FMEA and Control Plans 6
S Examples of software changes that required a 510k US Food and Drug Administration (FDA) 2
D 510K and Changes to Verification and Validation US Food and Drug Administration (FDA) 2
V IATF 16949 9.2.2.1 Internal Audit Program - "Process Changes" IATF 16949 - Automotive Quality Systems Standard 11
M What are the changes in supervising according to ISO17025? ISO 17025 related Discussions 7
U Changes to Internal Processes and Risk Evaluation - Mitigations Risk Management Principles and Generic Guidelines 10
M Informational New Zealand – Changes to Medical Device Adverse Event Reporting process Medical Device and FDA Regulations and Standards News 0
R Rationale for changes to ISO Standards Other Medical Device Related Standards 4
M Informational TGA Consultation: Proposed changes to medical device essential principles for safety and performance Medical Device and FDA Regulations and Standards News 0
A Changes to an already certified product (IIb, MDR) EU Medical Device Regulations 1
I Tracking Protoype Changes; 8D or simple document revision? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
C What if the foreign manufacturer of a medical device changes the Authorized Representative in Saudi Arabia? Other Medical Device Regulations World-Wide 0
A The latest revision number and changes in automotive core tools IATF 16949 - Automotive Quality Systems Standard 1
M Informational EU – MDCG 2018-1 v2 Guidance on basic UDI-DI and changes to UDI-DI Medical Device and FDA Regulations and Standards News 0
J Ethicon suture box design changes - 2019 Other Medical Device Regulations World-Wide 2
E Changes to medical device submitted through a variation? EU Medical Device Regulations 1
T AS9100 Maintain Approval When Business Ownership Changes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Informational TGA – Several proposed changes to classification to better align with the EU MDR Medical Device and FDA Regulations and Standards News 0
S ISO9001:2015 6.3 - Planning of Changes - OFI from auditor ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
M Medical Device News TGA Consultation: Changes to a number of definitions and the scope of the medical device regulatory framework in Australia Medical Device and FDA Regulations and Standards News 0
F Device Standards - Managing Changes to existing standards that apply to our devices Other Medical Device Related Standards 1
S Ballooned Drawings and Engineering Changes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
supadrai Changes to QMS - Contract Term ISO 13485:2016 - Medical Device Quality Management Systems 4
R ISO 9001:2015 6.2 - Planning Changes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Significant Organizational Changes - Documented Responsibilities Document Control Systems, Procedures, Forms and Templates 4
M Medical Device News Health Canada - Proposed Changes - List of Recognized Standards for Medical Devices Canada Medical Device Regulations 3
Marc 9 September 2018 - Upcoming User Group Changes Forum News and General Information 1
J Class 1 Medical Device ECR (Engineering Change Request) Changes 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
Douglas E. Purdy ISO/IEC 17025:2017 3rd Ed. Changes from 2nd Ed. ISO 17025 related Discussions 6
M Notifying Registrar of Significant QMS changes ISO 13485:2016 - Medical Device Quality Management Systems 2
S Medical Device Changes and How to Assess Their Impacts to Essential Requirements EU Medical Device Regulations 2
S Design changes a week after regulatory submission 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
