Changing dimensional tolerances to approve rejected product
BaconLikeItsHot
First timer here.
At my company we manufacture shaped products via hydraulic pressing. Pressed parts then eventually make their way to the final inspection department, where they are subject to dimensional analysis against a part drawing as well as a visual inspection for various defects, regulated by a controlled inspection document specific to the product line. Nonconforming parts are identified with reject codes and segregated from the acceptable parts, and they are placed in a containment area where they are then reviewed by a process engineer. If there is subjectivity in a rejection criterion and the engineer disagrees with the inspector's evaluation, the engineer may overrule the inspector and approve the part. Both the initial rejection and the overruling approval are recorded in our ERP system.
One of the many issues I'm facing as the quality supervisor (I have the functions of the quality management rep without being senior management) is that it's by no means a rare occurrence to see parts that are rejected for dimensional reasons to receive the overruling approval from the engineer following a tolerance change to the drawing. For example the parts were rejected under Revision A of the drawing, but then the engineer initiates Revision B, the parts are reinspected by the engineer, they pass (obviously) and they are approved. It's easy enough for me to discover these occurrences by running a scrap report for dimensional reject codes, then looking for re-approvals of those rejects, and finally checking the drawings for revisions to the tolerances on that dimension over the date range in question. I see this as an ISO 9001 issue for how we handle nonconforming product (we simply say it's not really nonconforming because the new tolerances make it acceptable), and moreover it strikes be as being a lack of process control. When this was brought to management's attention, the response was generally along the lines of "so you're saying if the tolerance is +/- 0.030 and it's only +0.035, then we need to reject it?" Their argument is that in most cases it won't affect performance for the customer, so why throw away all that "good" product? To me, it's obvious that process improvement is more profitable in the long run, but I'm having a hard time convincing the good ol' boys of this.
If anyone has any advice, I'm all ears.
John Broomfield
First timer here.
Bacon,
It seems that you have an incapable measurement system and unauthorized design changes.
The engineer and inspector do not reach the same conclusion on conformity to the acceptance criteria. This measurement system has to be corrected.
Use-as-is dispositioning of nonconforming product is a design change.
Is the engineer authorized to make product design changes? Are these design changes documented? And is the customer kept informed?
Or is the design not yet verified and validated and are these prototype parts?
John
P
PaulJSmith
What you are experiencing is not an uncommon practice. And honestly, there's really nothing wrong with it, so long as the end result is a usable part for the customer. I suppose that's the rationale used by your upper management. If your tolerances are tighter than they need to be, there is nothing wrong with loosening them ... again, so long as it results in usable parts.
I don't know what you make, but I have, in the past, seen this done for parts that were destined for military fighter aircraft. In those cases, though, the NCs were dispositioned as "Use-As-Is" by the customer and approved by a government inspector.
As long as your procedures allow for this - or don't specifically prohibit it, I don't know that there's anything amiss.
S Changing UK Responsible Person UK Medical Device Regulations 0
S Changing PCB Assembler and impact on QMS and MDD CE Certificate EU Medical Device Regulations 2
B How to change hour format to text but not changing the number ? Excel .xls Spreadsheet Templates and Tools 1
A Changing Notified Body EU Medical Device Regulations 6
H Traceability after changing the machine IATF 16949 - Automotive Quality Systems Standard 13
M Changing Investigational Device from Non-Sterile to Sterile - what are the implications? Other Medical Device and Orthopedic Related Topics 3
Q Changing calibration frequency Calibration and Metrology Software and Hardware 18
S Changing revision status of a reviewed document Manufacturing and Related Processes 12
S Sterilization validation after changing sterilization process provider Qualification and Validation (including 21 CFR Part 11) 3
R Impact of changing manufacturer post clinical investigation CE Marking (Conformité Européene) / CB Scheme 3
D Clothes changing in pharmaceutical factory Manufacturing and Related Processes 8
M Changing supplier of critical raw material (III class device) Other Medical Device and Orthopedic Related Topics 1
K Changing the Address in 510(K) Approved Product 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
T AS9100 - Changing PEARs target AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 41
C FDA on changing acceptance criteria re: analytical method validation US Food and Drug Administration (FDA) 1
V Statistical basis and justification while comparing / changing sampling plans Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
K Changing from Procedure based to Process based Competency Evaluations General Auditing Discussions 5
J Steps when changing material for class 1 medical device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Marc Email Addresses - Changing your email address Elsmar Xenforo Forum Software Instructions and Help 0
supadrai OEM Changing the name of the manufacturer - length of process? Is 1-3 months correct? Other Medical Device Regulations World-Wide 0
R Changing Document Control software. Must I transfer EVERYTHING? Document Control Systems, Procedures, Forms and Templates 3
A IMDS - Changing the Locked Weight Value RoHS, REACH, ELV, IMDS and Restricted Substances 1
D Changing Templates Approval Field Document Control Systems, Procedures, Forms and Templates 5
P Romer Arm - Profile of a Surface Changing General Measurement Device and Calibration Topics 4
D Changing software classification via software - IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 3
L MINITAB 17 - Changing Data Using Minitab Software 3
S Process validation when changing location ISO 13485:2016 - Medical Device Quality Management Systems 10
Don Fardie CAPA vs. Risk Assessment - Changing a product material for better performance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Changing Registrars Registrars and Notified Bodies 15
MDD_QNA Changing the Layout of Medical Device Label(s) CE Marking (Conformité Européene) / CB Scheme 3
S Keeping track of the changing Medical Device Standards Other Medical Device Related Standards 3
J Changing of our New Hire Orientation Training Records Training - Internal, External, Online and Distance Learning 12
A Changing a Form Template & Updating Records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
D Is anyone changing their ISO 14001:2004 EMS Policy? ISO 14001:2015 Specific Discussions 8
Q Changing Terminology in ISO 9001:2015 - Documentation Content ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
V Changing Indication of Use for a Class IIa Medical Device EU Medical Device Regulations 2
B Changing out Thermocouple - Is new calibration required? General Measurement Device and Calibration Topics 1
F Rules to respect when changing from Certification Body ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
MDD_QNA Clinical data requirements - Changing a Class I Medical Device to Class II EU Medical Device Regulations 5
shimonv Changing the Label of a Medical Device product in the field Other US Medical Device Regulations 5
E Information required about changing an off shelf part 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Changing FMEA template to include Detection Ranking for the PFMEA FMEA and Control Plans 2
WCHorn Changing Sampling Accept Number to Zero, Arbitrarily AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
M Amending CFDA Registration for changing site of shipment China Medical Device Regulations 2
S Gage R&R on Potentially Changing Parts - Guidance Needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
R Re-registration of medical device in Russia - "changing holder" Other Medical Device Regulations World-Wide 1
R Changing CE Mark on Documentation ISO 13485:2016 - Medical Device Quality Management Systems 2
K Changing the Auditor within a Notified Body ISO 13485:2016 - Medical Device Quality Management Systems 4
B Process Capability - Changing Limits to Improve Cpk or find Root Causes? Capability, Accuracy and Stability - Processes, Machines, etc. 8
M Changing Notified Body - Anyone have stories to share CE Marking (Conformité Européene) / CB Scheme 3
