Changing Quality Objectives
L
lostmanager
I am proposing that we change our quality objectives,(it was a hit on a recent internal audit). Here is what our policy and objectives is now.
WE will meet or exceed customer expectations for quality, timely delivery, and responsive service. We will continually upgrade our knowledge, skills, and capabilities.
To aid us in meeting these objectives, the company and its employees recognize the following to be matters of policy:
1. Adherence to a documented quality and production system which addresses ISO 9001:2008 and ASME Section VIII Division 1 requirements.
2. Periodic audits of the quality and production system.
3. Continuously improving processes, including tracking on-time delivery, customer feedback, and customer returns.
4. Formal employee training programs.
5. All employees are responsible for the quality of their work.
6. All employees are responsible for ensuring that we do not pass defective materials or erroneous information on to the next operation, employee, or user.
Here is what I am going to propose:
The following quality objectives are examples of what we can measure and provide real results of their status.
1. Customers for example, increasing customer satisfaction, choice, and value.
2. Internal results – for example, increase the number of products developed or speeding up the delivery time to customers.
3. Providing High Quality Products- record of material input and output (scrapped parts, shipping/receiving errors, etc.)
4. Profitability- for example improving profit, sales or reducing costs or losses.
I will make numbers and percentages that we can achieve on each one. Management wanted me to just incorporate the new objectives into the old but I think just keep the first part of the quality policy abd delete the rest with the new objectives. Opinions please.
insect warfare
QA=Question Authority
What was the exact wording of the finding? Was it against your quality manual/written procedures, or was it against ISO 9001 or ASME requirements?
Objectives are to be measurable and consistent with the quality policy, but the policy itself is a framework and does not have to be measurable, just relatable to the objectives, and are usually separate from them as well. I'm failing to see why your current quality objectives were inadequate to begin with.
Brian :rolleyes:
L
lostmanager
He just wrote that our quality objectives are not objectives and referenced 5.4.1 of the ISO.
insect warfare
Without more information from your auditor, that judgment seems to be subjective at best....did he/she not provide better reasoning for the finding than just "they are not objectives"? This response sounds kind of "5th-grade-ish" unless it is properly put into context. For example, were the objectives not related to "quality"? That would provide some context.
This post contains a link to a Quality Digest article (written by one of our own Covers) that gives good direction on setting and managing quality objectives, and provides the context that you are missing out on. It should, at the very least, make room for debate.
Brian :rolleyes:
AndyN
Moved On
I would bring to your attention that if it's your policy to "exceed expectations", you might want to rethink that... How will you know?
AndyN
Moved On
You may wish to revisit your auditor's competency requirements... This is not the audit report of anyone who is competent in reporting the findings of an internal audit and is, what I frequently fear, more like the auditor becoming a "Philadelphia Lawyer"...
L
lostmanager
The quality policy is fine, but the objectives are not something we can measure, as per the auditor.
insect warfare
OK - I just wanted to be sure that is what the auditor actually stated - it was evident in your first post.
Having said that, I think what you have proposed is a good first step - defining just a few key objectives that (I hope) are strategic in nature and not just there to appease an auditor (internal or otherwise). From there, you should be able to drill it down to more function-specific objectives for each area that are measurable. Doing it this way will provide you with a means of establishing value-added goals across the board and collecting the appropriate data to evaluate if 1) you're meeting those goals, or 2) you need to take action to improve in lackluster areas. The last thing you want to do is create a non-value added exercise in data analysis - see paragraph 8.4 in ISO 9001 for ideas on what "quality" objectives should be based on.
At the end of this "yellow brick road" should be continual improvement. You are stepping in the right direction so far....
Brian :rolleyes:
AndyN
Moved On
The objectives come from the policy...(per ISO 9001) Your policy sets a frame work for setting objectives. You may need to rethink this as there's little room for improvement with a policy which sets out your aim as the stars!
I'd still put it to you that, if your policy is to "exceed expectations"...what will you use to objectively determine that you have done this? Expectations are, by their very nature, often unstated. When you go to McDonalds, you never say "I'd like Hot, Safe, fries"...but that's what you expect...
:popcorn:
L
lostmanager
Brian :rolleyes:
Thanks for the reply. I chose these objectives because it gives us a start on how to observe them and offer us ways to improve. These are areas we are struggling in and it needs to be brought to everyone attention. The goals that will be set will be reachable and hopefully we can continually improve. I do not want to set us up for failure.
L Promoting (Changing to) a Quality Culture Quality Manager and Management Related Issues 14
A Management changes - Changing the apex manual of the company and Quality Plans Document Control Systems, Procedures, Forms and Templates 6
P One page quality procedure - Changing format of our quality procedures Document Control Systems, Procedures, Forms and Templates 1
T Changing Existing Quality Culture/Program - Where to Begin? Misc. Quality Assurance and Business Systems Related Topics 5
Z ISO / TS16949 Quality Manual needed - Changing from QS9000 to ISO / TS16949 IATF 16949 - Automotive Quality Systems Standard 17
M Changing Positions: System Quality Assurance vs. Internal Quality Auditor Career and Occupation Discussions 20
Z Quality Manual Revision - Update - Changing our company name Quality Management System (QMS) Manuals 4
V Changing the structure or the format of the Quality Manual - Indentions Quality Management System (QMS) Manuals 3
P Changing Revision Numbers - Quality Manual and Forms Quality Management System (QMS) Manuals 9
L Changing the Culture of an organisation where quality is a dirty word ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 91
R Changing our DMS/ECM to a Wiki. Advice on best practices and changes of paradigm? Document Control Systems, Procedures, Forms and Templates 0
T New process capability analysis required when changing a product on the same line? IATF 16949 - Automotive Quality Systems Standard 6
N Changing PRRC in Eudamed EU Medical Device Regulations 1
S Changing UK Responsible Person UK Medical Device Regulations 0
S Changing PCB Assembler and impact on QMS and MDD CE Certificate EU Medical Device Regulations 2
B How to change hour format to text but not changing the number ? Excel .xls Spreadsheet Templates and Tools 1
A Changing Notified Body EU Medical Device Regulations 6
H Traceability after changing the machine IATF 16949 - Automotive Quality Systems Standard 13
M Changing Investigational Device from Non-Sterile to Sterile - what are the implications? Other Medical Device and Orthopedic Related Topics 3
Q Changing calibration frequency Calibration and Metrology Software and Hardware 18
S Changing revision status of a reviewed document Manufacturing and Related Processes 12
S Sterilization validation after changing sterilization process provider Qualification and Validation (including 21 CFR Part 11) 3
R Impact of changing manufacturer post clinical investigation CE Marking (Conformité Européene) / CB Scheme 3
D Clothes changing in pharmaceutical factory Manufacturing and Related Processes 8
M Changing supplier of critical raw material (III class device) Other Medical Device and Orthopedic Related Topics 1
K Changing the Address in 510(K) Approved Product 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
T AS9100 - Changing PEARs target AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 41
C FDA on changing acceptance criteria re: analytical method validation US Food and Drug Administration (FDA) 1
V Statistical basis and justification while comparing / changing sampling plans Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
K Changing from Procedure based to Process based Competency Evaluations General Auditing Discussions 5
J Steps when changing material for class 1 medical device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Marc Email Addresses - Changing your email address Elsmar Xenforo Forum Software Instructions and Help 0
supadrai OEM Changing the name of the manufacturer - length of process? Is 1-3 months correct? Other Medical Device Regulations World-Wide 0
R Changing Document Control software. Must I transfer EVERYTHING? Document Control Systems, Procedures, Forms and Templates 3
A IMDS - Changing the Locked Weight Value RoHS, REACH, ELV, IMDS and Restricted Substances 1
D Changing Templates Approval Field Document Control Systems, Procedures, Forms and Templates 5
P Romer Arm - Profile of a Surface Changing General Measurement Device and Calibration Topics 4
D Changing software classification via software - IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 3
L MINITAB 17 - Changing Data Using Minitab Software 3
S Process validation when changing location ISO 13485:2016 - Medical Device Quality Management Systems 10
Don Fardie CAPA vs. Risk Assessment - Changing a product material for better performance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Changing Registrars Registrars and Notified Bodies 15
MDD_QNA Changing the Layout of Medical Device Label(s) CE Marking (Conformité Européene) / CB Scheme 3
S Keeping track of the changing Medical Device Standards Other Medical Device Related Standards 3
J Changing of our New Hire Orientation Training Records Training - Internal, External, Online and Distance Learning 12
A Changing a Form Template & Updating Records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
D Is anyone changing their ISO 14001:2004 EMS Policy? ISO 14001:2015 Specific Discussions 8
Q Changing Terminology in ISO 9001:2015 - Documentation Content ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
V Changing Indication of Use for a Class IIa Medical Device EU Medical Device Regulations 2
B Changing out Thermocouple - Is new calibration required? General Measurement Device and Calibration Topics 1
