Changing Text Procedures into Flowcharts
Stijloor
#11
I agree with Jane and the text quoted from the standard. I would like to share an NCR that I am currently responding to for:
4.2.4 - As required by the international standards ISO 9001:2008 and ISO 13485:2003, a documented procedure for Control of Records is not found in evidence.
The evidence provided during the audit was a flowchart titled "Quality Records", but it did not specifically say "procedure".
Since 2005, we have used this flowchart for our procedure and it is listed in the "Process #" Column an our ISO requirement matrix also provided during the audit. We also have additional records that show we are in control of this process.
Right now my corrective action plan is specify "Procedure" on all of the flowcharts. I know it will clarify things, but my opinion is this should have been an observation.
Comments?
Thanks,
If your flowchart addresses the requirements spelled out in Clause 4.2.4, then the Auditor is mistaken. You decide in what form the "procedure" is produced. It can be a flowchart, work instruction, procedure, a video recording, a power point presentation, whatever.... :agree1:
Stijloor.
JaneB
#12
What??
The auditor is splitting hairs, being nitpicky - and is also wrong.
To insist that a flowchart "did not specifically say procedure" is the kind of hairsplitting garbage that gives so-called 'quality auditors' a bad name (and rightly so). If you present something and explain 'this is our procedure' and show the kind of evidence that you did, that should be adequate.
No decent, even reasonably competent auditor would ever raise that as an NC, and nor should they. One of the things they must be is willing to consider alternative points of view and alternative ways of doing things, not dictating how they should think a procedure 'should' look or 'should' be titled!
I'd push back/protest/complain about it - take it up with the auditor's manager "back at the office". The auditor is attempting to foist his own misguided opinion onto you.
As Jan says, a procedure can be in whatever format you decide that works for you.
PS, while you're about it, consider asking for a better auditor to be sent to you next time. This one needs some recalibration, to say the least.
Q
QSMLauren
#13
Thanks for the responses. I totally agree. I did end up having to call the Registrar during the audit for a different potential NCR that had no valid support in the standard (another auditor opinion). I decided not worth my time on this one - The registrar can just read the nonsense themselves on the NCR during their technical review.
It is disappointing that his time and now my time was not being spent on things that matter.
#14
Comments?
Thanks,
4.2.4 of ISO 9001:2008 says, in part, "The organization shall establish a documented procedure to define the controls needed for the identification, storage, protection, retrieval, retention and disposition of records."
If your flowchart defines the requisite controls, your auditor is wrong.
#15
What it is called is meaningless as long as the folks understand what it is. The real questions is: are all of the controls (requirements) found in the standard covered? ISO 9001 and ISO 13485 both have things which must be addressed in the procedure. If all of those are covered in a flowchart, or a pictogram, or a coloring book, they are all covered.
Chris_Anderson
#17
Just to piggyback on what Jane has said, I wonder if all of the text procedures will translate conveniently to a flowchart format.
As an example, (and one I'm familiar with) Calibration is often something that is rather involved and while certainly a very simple outline could be knocked off in a flowchart form, there would still be need for fairly specific instructions etc downstream.
Just something to think about.
Personally, rather than trying to convince management to change hundreds of documents, I would look at making the changes as the need for revisions come up. Or, if there are "down times" in your industry, you could use this as kind of "filler work"
:2cents:
Peace
James
The job of a process map is to describe a process. Procedures are not what is required, even for calibration. Since calibration requires a record then you can put calibration instructions on the record or include the information in your training. If you must then create a work instruction, job aid, or procedure but realize that there are others methods besides always using a procedure. What is important in calibration is that the schedule is followed, the devices get calibrated to a reference, and you have a containment/investigation process when they device is found to be out of calibration. If devices are not getting calibrated correctly then you have a training problem and not a procedure problem.
Chris_Anderson
#18
Re: text procedures into flowchart
Hi
thanks for your kind reply
OK, From your experience, How can I convince my management for such action ( transform hundreds papers of text procedures to flowcharts)? Are there any famous organization do the same?
If you need to produce a lot of process maps then consider having each process owner produce their own process map. It is their process right? Then they should take the next step and produce data about their process. In purchasing they should be looking at how many purchase orders they write, how many are complete and accurate the first time, how many are filled correctly, and looking at supplier performance.
Chris_Anderson
#19
Dawelah,
Good stuff.
You can call it (identify it as) anything you like, whether that be purchasing flowchart, process or procedure.
Is it' acceptable' ?
Depends what you mean. Acceptable to whom?
1. If it's acceptable and useful in your organisation, then that's great - and the most important thing.
2. If you mean 'will an auditor accept it', the answer is yes. No auditor has the right to dictate how or what format documentation is in! #1 is always more important than #2.
Improvement suggestion only - I'd consider trying to keep the flow of the purchasing process itself as the most important thing, and downplay the 'supplier evaluation/feedback' bit - treat any reference to it as you did initially with the 'Approved Supplier?' branch.
When you refer to it after goods received, it tends to detract from the logical flow a bit. (Unless you mean that it really does take place immediately and in every single case.)
PS, I'm not quite sure what reference you are quoting re. 'clause 4.2.1' - can you clarify?
I would not downplay the supplier evaluation bit because it is a required element of ISO 7.4 and requires a supplier evaluation record. In fact, this is one of the most important parts of purchasing, which is to define how you are evaluating suppliers. Are you looking at purchase order performance by supplier? How good are your suppliers at on time delivery, product quality, or response time to quotes or requests for information. One way to do this is to track each purchase order transaction.
I would suggest you add more of the supplier performance information above to the purchasing process to improve the ISO conformance for clause 7.4 and not downplay the evaluation.
S Changing revision status of a reviewed document Manufacturing and Related Processes 4
S Sterilization validation after changing sterilization process provider Qualification and Validation (including 21 CFR Part 11) 3
R Impact of changing manufacturer post clinical investigation CE Marking (Conformité Européene) / CB Scheme 3
D Clothes changing in pharmaceutical factory Manufacturing and Related Processes 8
M Changing supplier of critical raw material (III class device) Other Medical Device and Orthopedic Related Topics 1
K Changing the Address in 510(K) Approved Product 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T AS9100 - Changing PEARs target AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 41
C FDA on changing acceptance criteria re: analytical method validation US Food and Drug Administration (FDA) 1
V Statistical basis and justification while comparing / changing sampling plans Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
K Changing from Procedure based to Process based Competency Evaluations General Auditing Discussions 5
J Steps when changing material for class 1 medical device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Marc Email Addresses - Changing your email address Elsmar Xenforo Forum Software Instructions and Help 0
supadrai OEM Changing the name of the manufacturer - length of process? Is 1-3 months correct? Other Medical Device Regulations World-Wide 0
R Changing Document Control software. Must I transfer EVERYTHING? Document Control Systems, Procedures, Forms and Templates 3
A IMDS - Changing the Locked Weight Value RoHS, REACH, ELV, IMDS and Restricted Substances 1
D Changing Templates Approval Field Document Control Systems, Procedures, Forms and Templates 5
P Romer Arm - Profile of a Surface Changing General Measurement Device and Calibration Topics 4
D Changing software classification via software - IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 3
L MINITAB 17 - Changing Data Using Minitab Software 3
S Process validation when changing location ISO 13485:2016 - Medical Device Quality Management Systems 10
Don Fardie CAPA vs. Risk Assessment - Changing a product material for better performance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Changing Registrars Registrars and Notified Bodies 15
MDD_QNA Changing the Layout of Medical Device Label(s) CE Marking (Conformité Européene) / CB Scheme 3
S Keeping track of the changing Medical Device Standards Other Medical Device Related Standards 3
J Changing of our New Hire Orientation Training Records Training - Internal, External, Online and Distance Learning 12
A Changing a Form Template & Updating Records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
D Is anyone changing their ISO 14001:2004 EMS Policy? ISO 14001:2015 Specific Discussions 8
Q Changing Terminology in ISO 9001:2015 - Documentation Content ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
V Changing Indication of Use for a Class IIa Medical Device EU Medical Device Regulations 2
B Changing out Thermocouple - Is new calibration required? General Measurement Device and Calibration Topics 1
F Rules to respect when changing from Certification Body ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
MDD_QNA Clinical data requirements - Changing a Class I Medical Device to Class II EU Medical Device Regulations 5
shimonv Changing the Label of a Medical Device product in the field Other US Medical Device Regulations 5
E Information required about changing an off shelf part 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Changing FMEA template to include Detection Ranking for the PFMEA FMEA and Control Plans 2
WCHorn Changing Sampling Accept Number to Zero, Arbitrarily AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
M Amending CFDA Registration for changing site of shipment China Medical Device Regulations 2
S Gage R&R on Potentially Changing Parts - Guidance Needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
R Re-registration of medical device in Russia - "changing holder" Other Medical Device Regulations World-Wide 1
R Changing CE Mark on Documentation ISO 13485:2016 - Medical Device Quality Management Systems 2
K Changing the Auditor within a Notified Body ISO 13485:2016 - Medical Device Quality Management Systems 4
B Process Capability - Changing Limits to Improve Cpk or find Root Causes? Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Changing Notified Body - Anyone have stories to share CE Marking (Conformité Européene) / CB Scheme 3
R Changing ISO 9001 Certification Scope Quality Manager and Management Related Issues 4
W Depth Gage Spindle moved when changing Contact Point Calibration and Metrology Software and Hardware 6
M Changing a Chinese Legal Agent China Medical Device Regulations 5
B Changing dimensional tolerances to approve rejected product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q How to handle customer request for changing specifications 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
T Change Control Requirements when changing Suppliers IATF 16949 - Automotive Quality Systems Standard 4
P Changing from contract manufactured to self manufactured 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
