Changing the Label of a Medical Device product in the field
shimonv
Hi Fellows,
Have you had a situation were it become possible to upgrade the hardware of a device or accessory in the field to the extent that you needed to change its part number?
If so, did you do over-labeling or removed the existing label and placed a new one in its place? Or is it better to manage tractability via service operations without actually changing the label in the field.
Also, how does UDI regulation address this?
Thanks in advance.
Shimon
Ronen E
Problem Solver
Moderator
Under US regulation a hardware upgrade that would lead to assigning a new PN might be considered remanufacturing.
Remanufacture: Process, condition, renovate, repackage, restore, or any other act done to a finished device that significantly changes the finished device's performance, safety specifications, or intended use.
In that case, labeling wouldn't be your only concern.
As far as UDI goes, a new PN would be considered a new version and require a new UDI.
briesmie671
My company did the same thing - upgraded the external power supply, effectively upgrading the complete system. Since there was a clear difference between the two systems, a new PN was assigned. A notice was sent to all known owners of the V1.0 system that an upgrade was available. If/when the V1.0 device was returned for service (either regular maintenance, or in response to the notice), we re-marked all parts of the system that held the Top Level PN. It was also the company's decision to perform the upgrade across the board, it was not optional. This made it easier for the Service team to manage the Device History Records as the systems are traceable by Serial Number. We did not offer servicing in the field for this system so it was all managed in-house.
shimonv
Thanks briesmie671; It makes sense.
The fact that you were able to do it in-house made all the difference because it was controlled by your QMS.
From what I could read on the Internet, there is growing regulatory concern ,and potential future regulation, when performing activities such as recondition or re-manufacturing by a third party. I am quoting from the federal register [FR Doc. 2016-04700 Filed 3-3-16; 8:45 am]:
"Stakeholders have expressed concerns that some third-party entities who refurbish, recondition, rebuild, remarket, remanufacture, service, and repair medical devices may use unqualified personnel to perform service, maintenance, refurbishment, and device alterations on their equipment and that the work performed may not be adequately documented. Possible public health issues arising from these activities include ineffective recalls, disabled device safety features, and improper or unexpected device operation."
Shimon
MDD_QNA Changing the Layout of Medical Device Label(s) CE Marking (Conformité Européene) / CB Scheme 3
S Changing revision status of a reviewed document Manufacturing and Related Processes 4
S Sterilization validation after changing sterilization process provider Qualification and Validation (including 21 CFR Part 11) 3
R Impact of changing manufacturer post clinical investigation CE Marking (Conformité Européene) / CB Scheme 3
D Clothes changing in pharmaceutical factory Manufacturing and Related Processes 8
M Changing supplier of critical raw material (III class device) Other Medical Device and Orthopedic Related Topics 1
K Changing the Address in 510(K) Approved Product 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T AS9100 - Changing PEARs target AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 41
C FDA on changing acceptance criteria re: analytical method validation US Food and Drug Administration (FDA) 1
V Statistical basis and justification while comparing / changing sampling plans Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
K Changing from Procedure based to Process based Competency Evaluations General Auditing Discussions 5
J Steps when changing material for class 1 medical device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Marc Email Addresses - Changing your email address Elsmar Xenforo Forum Software Instructions and Help 0
supadrai OEM Changing the name of the manufacturer - length of process? Is 1-3 months correct? Other Medical Device Regulations World-Wide 0
R Changing Document Control software. Must I transfer EVERYTHING? Document Control Systems, Procedures, Forms and Templates 3
A IMDS - Changing the Locked Weight Value RoHS, REACH, ELV, IMDS and Restricted Substances 1
D Changing Templates Approval Field Document Control Systems, Procedures, Forms and Templates 5
P Romer Arm - Profile of a Surface Changing General Measurement Device and Calibration Topics 4
D Changing software classification via software - IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 3
L MINITAB 17 - Changing Data Using Minitab Software 3
S Process validation when changing location ISO 13485:2016 - Medical Device Quality Management Systems 10
Don Fardie CAPA vs. Risk Assessment - Changing a product material for better performance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Changing Registrars Registrars and Notified Bodies 15
S Keeping track of the changing Medical Device Standards Other Medical Device Related Standards 3
J Changing of our New Hire Orientation Training Records Training - Internal, External, Online and Distance Learning 12
A Changing a Form Template & Updating Records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
D Is anyone changing their ISO 14001:2004 EMS Policy? ISO 14001:2015 Specific Discussions 8
Q Changing Terminology in ISO 9001:2015 - Documentation Content ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
V Changing Indication of Use for a Class IIa Medical Device EU Medical Device Regulations 2
B Changing out Thermocouple - Is new calibration required? General Measurement Device and Calibration Topics 1
F Rules to respect when changing from Certification Body ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
MDD_QNA Clinical data requirements - Changing a Class I Medical Device to Class II EU Medical Device Regulations 5
E Information required about changing an off shelf part 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Changing FMEA template to include Detection Ranking for the PFMEA FMEA and Control Plans 2
WCHorn Changing Sampling Accept Number to Zero, Arbitrarily AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
M Amending CFDA Registration for changing site of shipment China Medical Device Regulations 2
S Gage R&R on Potentially Changing Parts - Guidance Needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
R Re-registration of medical device in Russia - "changing holder" Other Medical Device Regulations World-Wide 1
R Changing CE Mark on Documentation ISO 13485:2016 - Medical Device Quality Management Systems 2
K Changing the Auditor within a Notified Body ISO 13485:2016 - Medical Device Quality Management Systems 4
B Process Capability - Changing Limits to Improve Cpk or find Root Causes? Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Changing Notified Body - Anyone have stories to share CE Marking (Conformité Européene) / CB Scheme 3
R Changing ISO 9001 Certification Scope Quality Manager and Management Related Issues 4
W Depth Gage Spindle moved when changing Contact Point Calibration and Metrology Software and Hardware 6
M Changing a Chinese Legal Agent China Medical Device Regulations 5
B Changing dimensional tolerances to approve rejected product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q How to handle customer request for changing specifications 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
T Change Control Requirements when changing Suppliers IATF 16949 - Automotive Quality Systems Standard 4
P Changing from contract manufactured to self manufactured 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
N Document Control - Changing Company Logo Document Control Systems, Procedures, Forms and Templates 10
