Charting Bi, Tri or More Modal Distributions to combine results from two machines
M Greenaway
Would it be OK to combine results from two machining fixtures into one control chart if the underlying populations would in effect create a bi-modal distribution, but we are using a sample size of 5 in our sub-groups ?
Would combining even more data that would in effect create tri-modal, quatro-modal or penta-modal and above (if those are the correct terms !) ?
I understand that using average and range charts means that no matter the underlying distribution, the sample means will always conform to a normal distribution - is this true and therefore could I apply the above logic ?
If you already know that you will see a multi-modal distribution, you definitely do NOT want to combine them into a single chart. While you are correct, that an Xbar chart will tend to normalize this data, the fact that the process is multi-modal will inflate the average range, which in turn will inflate the control limits making the chart less sensitive to process shifts. Your averages will appear to hug the central line off the Xbar chart.
M Greenaway
Could I do this if I were using purely tolerance based charting ?
I know this isnt great SPC, but would it have any value in controlling a process at all ?
If you have a statistically capable process, you could legitimately use a method such as Pre-control. I do not recommend trend charting within tolerance limits.
jefnik3201028
Agree with Miner...if bi or multi modal distribution exists the results will be inflated average range and worst the overall average may not mean anything. Example is if you have bi modal, in this condition the Xbar is meaningless as it falls on an imaginary area. Say if you have peaks at 3 and 5, the Xbar will show 4 but there are actually few readings on this area.
Separate SPC charting is the best way of approaching this.
duecesevenOS - 2009
I'm curious about this as well. What if you have a customer that is accepting on Cpk of the process. Is it even a valid number to give them if the you know the population is multi-modal.
It doesn't really matter because the multi-modal data actually hurts your Cpk quite significantly but we still mix the populations and pass with an okay Cpk. The problem is we spend a ton of time making the process as tight as it is and I don't think the numbers we supply to our customer mean anything because it's a non-normal distribution.
P.S. Customer is the US Government so there isn't much arguing with them.
A Process Control / Control Charting Procedure Capability, Accuracy and Stability - Processes, Machines, etc. 1
Q Real Time Electronic SPC/Control Charting Statistical Analysis Tools, Techniques and SPC 4
bobdoering SPC Charting frequency calculator for X hi/lo chart Imported Legacy Blogs 0
S Different Standard Deviations used in Control Charting Statistical Analysis Tools, Techniques and SPC 8
U Control Charting a Feature with Bonus Tolerance Quality Tools, Improvement and Analysis 10
M Excel Charting - Graphing each trainee's length of time in training Excel .xls Spreadsheet Templates and Tools 5
M Procedure & Work Instruction Flow Charting vs. Turtle Diagrams AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
Hami812 Minitab and Control Charting Time to Complete each Repair Over Time Using Minitab Software 8
Hami812 Collecting Data for SPC Control Charting Statistical Analysis Tools, Techniques and SPC 7
A Cpk Basics without Charting? Capability, Accuracy and Stability - Processes, Machines, etc. 7
R Control Chart Metrics/KPI - Measuring Effectiveness of Control Charting System Statistical Analysis Tools, Techniques and SPC 4
P Can we use Control Charting to monitor Rejection Rate? Statistical Analysis Tools, Techniques and SPC 3
S Charting Detection Limit Data Statistical Analysis Tools, Techniques and SPC 2
N Which is more appropriate Regular or Short Run control charting? Statistical Analysis Tools, Techniques and SPC 8
S Charting the 4 M's - How to turn these into a process measurement? Lean in Manufacturing and Service Industries 3
M Looking for SPC charting and reporting software Quality Assurance and Compliance Software Tools and Solutions 9
A How to do Process Flow Charting in MS Word Process Maps, Process Mapping and Turtle Diagrams 15
J Continuous Gauge Control Charting Statistical Analysis Tools, Techniques and SPC 1
L Basic SPC Training to Train Assembly Line Operators on SPC Charting Statistical Analysis Tools, Techniques and SPC 12
J Problems with Charting - Access Database Question Quality Assurance and Compliance Software Tools and Solutions 9
R Part to Part vs. Within Part Variation sampling and charting Inspection, Prints (Drawings), Testing, Sampling and Related Topics 19
R Charting, non SC / CC / FF characteristics Statistical Analysis Tools, Techniques and SPC 4
D t2 Hotelling or Chi square Control Charts - How is done - Calculus and charting? Statistical Analysis Tools, Techniques and SPC 2
M Attribute Charting - Where does Cp and Cpk come into the equation? Capability, Accuracy and Stability - Processes, Machines, etc. 5
M Process Charting Symbols - BS 4058:1987, ISO 5807-1985 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
R ISO SYMBOLS - What is the international standard for flow charting Other ISO and International Standards and European Regulations 2
D p charts - My experience with P charting has not been good Statistical Analysis Tools, Techniques and SPC 3
V Quality/Manufacturing/Six Sigma Jobs - Tri State (NJ,NY,CT) Career and Occupation Discussions 1
mr500 Calibration Of Plug gages (G0-No Go Tri lock gages) General Measurement Device and Calibration Topics 11
K Do I need to calibrate inside tri-mics? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G How do I calibrate InterMics (tri-mics) - Is there a standard? General Measurement Device and Calibration Topics 3
C Tri-annual in 2008, auditor changing and thinking of changing CB - advice needed. Registrars and Notified Bodies 10
J Tri-annual TS16949 continuous assessment (3 year cycle) IATF 16949 - Automotive Quality Systems Standard 2
ScottK Reporting of alloys on EPA TRI form R Miscellaneous Environmental Standards and EMS Related Discussions 7
O How to give a score/yield more correctly to my suppliers Supplier Quality Assurance and other Supplier Issues 12
Marc GM says no more tailpipe emissions by 2035, carbon neutrality by 2040 World News 45
O Is hiring more difficult right now? Career and Occupation Discussions 14
K FDA - Can we have more than 1 Initial Importer Medical Device and FDA Regulations and Standards News 4
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
K More than one importer for the same device EU Medical Device Regulations 3
S Two or more predicates suitable? 510K submission US Food and Drug Administration (FDA) 5
E Received a Major finding during IATF Surveillance audit for loss of BIQS Level 3 (more than 6 SPPS in 6 months)...how should we address SYSTEMIC CA? IATF 16949 - Automotive Quality Systems Standard 11
L Which one is more important for FMEA CC or SC, FMEA and Control Plans 6
M UDI-PI on a package that contains more devices EU Medical Device Regulations 3
M Informational Update – MDR and IVDR implementing measures rolling plan – 2 more NBs designated under the new regulations Medical Device and FDA Regulations and Standards News 0
B More than one Risk Report per Medical Device ISO 14971 - Medical Device Risk Management 3
Ed Panek Can a single supplier fit two or more categories for risk? ISO 13485:2016 - Medical Device Quality Management Systems 2
Sidney Vianna More allegations of unethical behavior in the Aerospace Sector AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
N Technical File Reviewer has requested more testing to ISO 10993 Other Medical Device Related Standards 10
M Informational FDA Panel: Too early to pull textured breast implants over cancer risk, need more data Medical Device and FDA Regulations and Standards News 0
