Check Fixture Costs - Simple check fixture (go/no go) that checks 3-4 points
P
patrick_1446
Can anybody tell me what a reasonable price for a simple check fixture (go/no go) that checks 3-4 points around a part approximately 3"X4"X1"? I'm getting a cost back of close to $5000 which seems absolutely ridiculous to me. All I want to do is check perimeter and thickness in a couple places.
True Position
Re: Check Fixture costs
Why does that price seem so ridiculous? How much time do you figure it would take? I could easily see a fixture like you're describing take 40+ hours to make(design, machine, assemble, test) and cost $1500+ in materials.
The devil is always in the details, can you post a picture of the part and the dimensions you are interested in having a fixture check?
DrM2u
The price is a function of many variables:
- the accuracy you are specifying on your prints or requirements
- whether the gage needs to be certified or not by the supplier
- the design of the gage; intricate machining and grinding can get expensive
- the materials specified; high carbon steels are more expensive than low carbon
- the components specified; what type, how many, what brand, certifications, etc
What I am getting at is that I would not be able to estimate a price without seeing what the fixture look like. As a general rule of thumb, you can budget about $100/hr of labor time (if you can estimate it) plus the market price of any components and certifications. My suggestions:
- get more prices from local tooling & fixture manufacturers
- refer to the device as a fixture not as a gage
- try to validate/verify it in house if possible
- use standard size components as much as possible
- review the design to simplify manufacturing and assembly
Ron Rompen
Without knowing the specifics of the fixture, it is very difficult to determine what is a 'correct' cost for it.
With that being said, my ballpark cost for any type of attribute fixture (when doing budgetary quotes for new business) was always at LEAST $15000. Good quality fixtures are not cheap.
I would suggest getting some competitive quotes from other suppliers. Make sure you are very explicit in what you require, as many gauge shops have a 'standard design' which may incorporate elements (and costs) that are not necessary for your fixture.
cpbraun
My company is in turbine component machining and grinding. We contract with several tooling builders for custom inspection fixtures and holding nests. The "rule of thumb" to remember is "Precision costs money!" The least expensive holding fixtures we buy generally start at 5K. As a comparison, look at the Fowler, Starrett, or Mitutoyo catalogs. Price comparison of measuring devices reveals that adding an order of magnitude (.001 to .0001) will generally double the cost (approx). That is for mass produced gauging. Now consider that you are requiring a custom, one off job and your gage build precision should follow the 10:1 rule where it will affect part measurement. All that considered, I think the price you were quoted is pretty reasonable. Depending on your cost/part and the volume of production, you may want to consider finding a measurement solution with existing gages that can be purchased off the shelf. I hope that helps somewhat.
J Check Fixture Design For Sheet Metal Part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
T Gage R&R for Checking Fixture with multiple check points Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J Proper way to calibrate a check fixture General Measurement Device and Calibration Topics 7
D Procedure for Fixture Gages that check True Position of holes General Measurement Device and Calibration Topics 4
P Audit check for IT company (ISO 9001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Management review check-list Management Review Meetings and related Processes 3
M Documents to be included in 1.3 Material check in PPA report APQP and PPAP 4
D FAA inspection at my repair station - Rating Check Federal Aviation Administration (FAA) Standards and Requirements 0
G MSA check list to audit IATF 16949 - Automotive Quality Systems Standard 10
M How Supplier Capacity check is done by competitors Manufacturing and Related Processes 0
M IATF 16949 8.5.1.3 Verification of job set-ups - Do we need secondary check? IATF 16949 - Automotive Quality Systems Standard 7
M MDR requires the NB to perform "tests in order to check that the quality management system" EU Medical Device Regulations 3
G Is it common to do a repeatability check during calibration of an instrument? General Measurement Device and Calibration Topics 5
V CAPA effectiveness check Nonconformance and Corrective Action 3
A Statistical Analysis - Check if these organisms at different concentrations affect the growth of wheat seedlings Using Minitab Software 4
G Oversized Threads - What sized stab pin would be best to quickly check for oversized thread holes General Measurement Device and Calibration Topics 5
G Stab Pin Size For Check Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
B AS9110 Audit Check Sheet wanted Excel or Word Document AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J AQL for Effectiveness Check - What AQL tiers to use on this type of sampling? Nonconformance and Corrective Action 9
G From an ISO 17025 auditor perspective must micrometer calibration check anvil flatness? General Measurement Device and Calibration Topics 4
F Position tolerance check gage manufacturing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
S The procedure for replicate check in calibration lab as per ISO 17025 General Measurement Device and Calibration Topics 2
F Design check list for Cable and Wiring Harnesses Manufacturing and Related Processes 6
R Mass production handover check sheet (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 1
bobdoering Handy training tip for SPC - the Check Engine Light Analogy Statistical Analysis Tools, Techniques and SPC 0
R Please help me with attached copy of AS 9100D internal audit check sheet AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
G What to Check - Set Up vs. In Process Inspections Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
B FDA Philippines has no check or balance outside the health department Supplier Quality Assurance and other Supplier Issues 3
Crusader Product Completion, Birth Cert, Product Check sheet - packaged with product Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
C Serialization at Final Quality Check ISO 13485:2016 - Medical Device Quality Management Systems 3
T Example System & Process Audit Check Sheet for IATF 16949 IATF 16949 - Automotive Quality Systems Standard 1
L Signal-to-Noise (S/N) Ratio formula check Design and Development of Products and Processes 2
M AS9100 7.6 - Check Method - PO Information AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
S GR&R for a Stopwatch used to check a built-in Machine Timer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
R ISO 13485:2016 Clause 6.2 - Effectiveness Check ISO 13485:2016 - Medical Device Quality Management Systems 1
P Looking for a company local in Wyandotte, Mi, to come in check noise levels Manufacturing and Related Processes 2
M Difference between a "check" and a "test" Manufacturing and Related Processes 7
M Proper Gauging - GD&T - Attribute gage to check true positioning on the shop floor Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
S How to check runout on Id to ID diameters Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Y Is it possible to check the authenticity of a CFDA registration certificate? China Medical Device Regulations 7
M More than canned audit check-sheets? Auditing the Engineering Department Process Audits and Layered Process Audits 5
P Searching for a complete audit check list based on ISO14001:2004 ISO 14001:2015 Specific Discussions 1
V Internal Audit using Plan, Do, Check, Act - Way to go? Internal Auditing 11
S Elisa kits for poultry disease check up companies US Food and Drug Administration (FDA) 3
F Check List and Questions for Auditing Monitoring and Measuring Devices General Measurement Device and Calibration Topics 1
E How to perform Discrimination check for Dial Indicator? General Measurement Device and Calibration Topics 2
B How to check the parallelism error of v axis w.r.t to lateral surfaces General Measurement Device and Calibration Topics 1
L Most appropriate Auditor to check the FMEA & PCP of a Manufacturing Process IATF 16949 - Automotive Quality Systems Standard 5
K Too Simple an Internal Audit Check Sheet? Internal Auditing 10
