Checking for Oversize Hole - Dimensioning question
V
vardar3
for a hole, 15.85 +/- .03 gives a tolerance boundary of 15.82 – 15.88 mm. Would a part measuring 15.88000… be within these tolerance limits, or is it out?
In checking for oversize hole, should the 15.88 mm gage pin be able to go in the hole?
P
PaulJSmith
Re: Easy Dimensioning question:
If you've measured it more than once and keep getting 15.88, then it is within the stated tolerance. That +/- is inclusive.
Of course, if you're getting accurate measurements out to 5 decimal places, you need to share your calibration lab with the rest of us.
Michael_M
for a hole, 15.85 +/- .03 gives a tolerance boundary of 15.82 ? 15.88 mm. Would a part measuring 15.88000? be within these tolerance limits, or is it out?
Technically speaking, yes it is within tolerance. Where I have run into problems with issues this close to the tolerance zone is when someone else checks the part. Temperature, humidity, and how the part is held in warm hands can affect this dimension when the customer gets it. Depending on the pin you use, it too can be off. Deltronic pins have a tolerance of +.000040/-.000000 (+.0010mm/-.0000mm). That may come into play as well.
It depends on the pins you're using. A 15.88 pin at exact size won't fit into a 15.88 hole at exact size. The ID of the hole and the OD of the pin can't occupy the same plane simultaneously.
This is why there are "plus" and "minus" pins. The former are slightly larger than their nominal size and the latter are slightly smaller. Which pin to use depends on whom you're trying to protect. If you use a plus pin, you could conceivably reject parts that are at the top of the tolerance range, thus protecting the customer. On the other hand, if you use minus pins, you could accept parts that are below the bottom of the tolerance range, which would be in favor of the producer.
bobdoering
Stop X-bar/R Madness!!
That is the difference between CMM and gage pins: fit. You can not have line-to-line fit - that is called press fit, and the pin will never come out. So, if a 15.88 pin goes in, the hole is already too big.
On top of fit, pins measure MMC. So, a CMM will find diameters even larger based on roundness.
The only way it works out is of the customer agrees to that measurement technique - then you are on the same page and all is well (until they get a new quality engineer.)
V
vardar3
Haha, no I’m speaking theoretically. If the part measures on the high limit, 15.88, is it in?
Here is why I ask. I’m having a discussion about what pin should be able to fit in the hole. I’m saying that the hole can be 15.88, so the 15.88 gage pin should be able to fit. My partner is saying the 15.88 is the no go. 15.88 should not go. Who is correct???
Michael_M
Haha, no I?m speaking theoretically. If the part measures on the high limit, 15.88, is it in?
Here is why I ask. I?m having a discussion about what pin should be able to fit in the hole. I?m saying that the hole can be 15.88, so the 15.88 gage pin should be able to fit. My partner is saying the 15.88 is the no go. 15.88 should not go. Who is correct???
In a perfect world, your partner is correct, as Jim pointed out, two objects cannot occupy the same space. However if the pin used is a negative pin, than technically speaking, you are as the pin is undersized.
P
PaulJSmith
Theoretically, or realistically?
If the hole measures 15.88, then it is within the stated tolerance.
If you can fit a 15.88 pin in the hole, then the reality is that it's larger than the pin ... which makes it OOT.
As pointed out already, it depends on the pin itself.
R Through-Hole Electronics - Checking Lead Length Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
G Supplier Checking With Gauge Pin Problem Solving, Root Cause Fault and Failure Analysis 2
B Design of fixture checking including Position of hole and slot General Measurement Device and Calibration Topics 5
S Checking status of Medical device Other Medical Device and Orthopedic Related Topics 2
O Clamps in checking fixtures used to drive datum features. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
KyloDen Checking Threads - Discrepancy in threads that are machined In-House vs. Outsourced General Measurement Device and Calibration Topics 11
P Checking flatness with Go and No Go Jig Manufacturing and Related Processes 2
M Checking Fixture for Stamping Parts Manufacturing and Related Processes 2
F Checking Gages In and Out and Verifying Calibration Status Calibration and Metrology Software and Hardware 8
R Weight Sets for Checking Table Balances Quality Assurance and Compliance Software Tools and Solutions 5
E Methods in Measuring Angles or Checking Angles for tools? General Measurement Device and Calibration Topics 10
E PPAP Checking aids, what to do exactly? APQP and PPAP 5
N Survey about Attribute Gage and Sight Checking R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J Micro Tubing Concentricity Checking using Crosshairs Manufacturing and Related Processes 1
F Checking runout in reference to 2 datums Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
F Besides using the CMM - Checking perpendicularity between a plane and an OD Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L GD&T Bonus Tolerance - Checking True Position of a Pierced Hole Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
C Checking True Position with Pin Gage Measurement Uncertainty (MU) 3
D Checking my organization's current Quality Policy Quality Manager and Management Related Issues 9
J Checking Variance/Normality of my two Samples (question) Using Minitab Software 2
F Calibration Reports for Wood Checking Fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
K Verification, Validation or Checking? Definition of the word "Checked" Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
Z Error of 30 microns checking a Ring Gauge on a CMM Machine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
D Laser Micrometer for checking Thickness of Steel - Any Recommendations or Comments General Measurement Device and Calibration Topics 3
K True Position Checking such as Bolt Hole Position w.r.t Center Bore on Wheels Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
A Can we reduce documents checking percentage on supplier certificates? Supplier Quality Assurance and other Supplier Issues 3
J Checking the Theoretical Sharp of a Flush Head Bolt on an Optical Comparator Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Inspection Equipment for Checking Serrated Steel Tubing Depths Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
D Checking Rib Thickness on a Part and Necessary Process Controls Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
D Checking the Homogeneity of the Variance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Ajit Basrur Checking in on Saturn - Good pictures ! Coffee Break and Water Cooler Discussions 0
T AQL Difference in Checking LCD Pins AQL - Acceptable Quality Level 4
G Dispute - Checking a thin walled, round, hollow part with micrometer Inspection, Prints (Drawings), Testing, Sampling and Related Topics 25
L PPAP List Requirements - Molds, Tools or the Checking Tools? APQP and PPAP 5
D Good source for Checking and Evaluating Control Plans needed FMEA and Control Plans 4
J Surprise - And Hello - Just Checking In Coffee Break and Water Cooler Discussions 20
A Optical Magnification Checking Graticule - Starrett 400-360 (P-10089) General Measurement Device and Calibration Topics 2
S Go/No-go Length Gauges - Length checking of beam assemblies General Measurement Device and Calibration Topics 2
J Why control of records in checking section? Miscellaneous Environmental Standards and EMS Related Discussions 3
M Checking a male taper using a female air gage fixture - Air Gaging question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
Jim Wynne Virus Hoaxes or, What Ever Happened to Fact-Checking? After Work and Weekend Discussion Topics 5
R Checking (Calibrating) Truncated Thread Set Plugs General Measurement Device and Calibration Topics 11
J Checking work question - How do you check your work? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Tolerance Stacking or Tolerance Chart - Checking manufacturing print tolerances Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A Checking Profile Tolerance on CMM's Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
C How long does it take to clear back ground checking? Career and Occupation Discussions 7
T Checking Contractors for Charity Organisation Service Industry Specific Topics 5
L Asking for AQL for checking 5 liters can AQL - Acceptable Quality Level 5
Y PFMEA detection value for checking C of C in receiving inspection FMEA and Control Plans 2
T Gage R&R for Checking Fixture with multiple check points Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
