Choosing Document Control Software
AliInMo
I've been assigned the task of finding a software program to use for document control. My company is a fairly small manufacturing company (ISO 9001 certified) with about 200 employees, maybe up to 20 would need access to the document control software (for some document changes, for document reviews and approvals). There would be only one administrator. Right now we have a document master log in excel (bare, no hyperlinks or anything), documents are MS Word (protected, authorized access) for the most part and PDFs are available on the intranet for view. There are hard copies of many of the documents distributed throughout the plant and locations are noted in the master log. We need something that will ease the burden of me having to manually check for expired documents and doing all the revisions myself. What I'm looking for is a program that includes a comprehensive document log, automatic expiration notification (via email), document check in/out, workflow for approvals of revisions, change mark-up and/or archive of older revisions, easy to search and link documents (hyperlinks, meta tags?), and my existing documents need to be linked in, not a pre-existing template for me to transfer the documents into (because we still use hard copies and they are standardized). And price is a very real issue as we have almost no budget to implement such a system. I've looked through posts on here and researched many that I've found, but I was really hoping someone could point me in the right direction if I gave specifics on what I need, maybe someone is already doing something similar. Thank you.
mpbarr538
Hi I'm a Document Control Specialist and have been in the industry over 14 years. I have used various Document Control System. I have not found a perfect one but one software I will referral is Quadrite RitePro specializing in small to medium companies. The best features of the product is that it is very easy to implement and use. Also the customer service is great. Check them out they aren't expensive either.
AliInMo
Thank you. I'll check that one out ASAP. It's a bit overwhelming trying to sift through all the suggestions I've seen on the forums. Especially trying to find one that fits my pre-existing criteria. Most have bits and pieces. Maybe my bar is set a little high...especially for my budget. lol
tsmith7858
Check the threads below and do a search for QMS software or Document Control Software. There are a lot of options some include more than just document control and can help you manage CAPA, Audits, customer feedback, etc.
I used Q-Pulse in the past. Many people are also using Sharepoint based system.
JaneB
AliInMo,
As with any software program, I strongly urge you to focus very hard on defining your user requirements as accurately as possible. This is the step that most people gloss over or don't do very well, and it's the step that will trip you up later if you don't.
List what you absolutely must have and also list what would be a 'nice to have' but not essential.
Then use your list when shopping around and be strict about comparing software with your criteria.
Lots of people will tell you X is nice and they used Y and so on and so forth, and gosh, you can get one that will do all that plus this stuff as well... but they're not you and you should aim to get something that works for you.
Also, don't underestimate the time and effort required to learn how to use it and configure it (structure it/set it up right) in the first place. That also matters. A Lot.
Sharepoint, for example, will work well... but only provided that you have someone who has or can acquire the skills & knowledge required to use it well & set it up intelligently. Left in the hands of someone with little/no understanding, it quickly becomes big bucket of documents and links all over the place, which no one can find anything on.
Randy
What's wrong with using an exel spreadsheet? I've seen ton's of org's use them successfully and save themsleves a bundle of money that could be better used elsewhere.
You say you're a small organization and what you're going to wind up purchasing may very well be a 12 lb sledgehammer to drive a 10 penny nail
Dudes
The problem with an excel spreadsheet (as far as I'm concerned, being in a similar position as the OP) is that after a while, it gets difficult to keep an overview of the interconnections between your documents (which document is referenced where...) Hence, it increases the risk of mistakes by changes...
JaneB
And it cannot be used by multiple users - only one person can update it at a time.
And yes, the 'flat file' is very hard to make connections between. But yes, it IS a good option where there aren't very large numbers of documents/changes. If there are, it's not.
AnaMariaVR2
:bigwave:Welcome AliInMo:bigwave:
Not sure what is your industry...so I'm not sure if you need to be Part 11 or J2EE compliant.
Here is a recent ELSMAR discussion: Part 11 Compliant Document Control Software recommendations
Always check at the bottom of the page for recommendations on the topic under "Similar Discussion Threads"...there is more relevant info there.
Why spend the $$$ if you can find an affordable still functional and reliable solution?
Now, between the Excel spreadsheet option and other "Cadillac-type" Document Management System (DMS) like Documentum & Sharepoint...there is Open Source DMS.
Here I list some free DMS software to start with:
  1. OpenDocMan
  2. OpenKM
  3. Alfresco
  4. Epiware
  5. Knowledge Tree
  6. KnowledgeTree Open Source Community Website
  7. LogicalDOC
  8. Cynapse
[slideshare] Total Cost Of Ownership For ECM - Compares Documentum, SharePoint, OpenText and Alfresco
Something else to consider are wikis. Some companies have use the wiki system to implement a Quality Management System (QMS) because of its DMS features.
ELSMAR threads Tagged with wiki
If you take a look at these resources, then look at your gap analysis & risk assessment, you probably can find a solution that meets your compliance & business needs.:agree1:
Good luck!
JaneB
Q Choosing Nonconformities to Report ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
C Quantifying risk in choosing the number of parts, operators and replicates in a GR&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Q Old products new class - Dental Devices - Choosing tests EU Medical Device Regulations 2
M Choosing Auditors - ISO 9001 / ISO 27001 (UK) IEC 27001 - Information Security Management Systems (ISMS) 2
T AS9100D - Scope of QMS for New Company - Only Choosing a Function Subset Due to Management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
E Choosing an ISO 9001 registrar with auditors familiar with our industry Registrars and Notified Bodies 10
M Dilemma about choosing the most applicable clause related to Risk ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
J Choosing QMS Software for Aerospace Company Quality Assurance and Compliance Software Tools and Solutions 5
B Choosing not to calibrate (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 6
Q Choosing between ISO 9001 (2015) & TL 9000 certifications ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
H On choosing touchscreen displays and ensuring IEC 60601 compliance IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
Q Choosing In-Process Inspection Characteristics Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Choosing the correct Distribution for Acceptance Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 19
S Choosing a suitable type of Elisa to Test my Sample Misc. Quality Assurance and Business Systems Related Topics 3
S Choosing the correct Elisa Test Food Safety - ISO 22000, HACCP (21 CFR 120) 1
K Choosing a Six Sigma training organization Six Sigma 4
H Choosing between RABQSA Lead Auditor or ASQ CQA Certification Professional Certifications and Degrees 2
S Choosing ISO 9001 Training and if I need the training for work ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S CE Marking choosing between module A, B CE Marking (Conformité Européene) / CB Scheme 2
A Getting Stuck Choosing a Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Choosing the right Industry Financial Report Manufacturing and Related Processes 1
M Advice for choosing Rechargeable Lithium Batteries to be used in a Medical Device Other Medical Device Related Standards 16
L Choosing a Statistical Test for dissertation results! Statistical Analysis Tools, Techniques and SPC 4
I Choosing a X-Ray Fluorescence Measuring Device for Chrome Coating Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J Choosing the Best Standard - ISO 9001 or ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 14
B Choosing Inspection Level and AQL AQL - Acceptable Quality Level 1
I Choosing the alpha level in an ANOVA Study Statistical Analysis Tools, Techniques and SPC 3
M Tolerance vs. Study Variation - Choosing the right one Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Choosing a Higher EER Air Conditioner After Work and Weekend Discussion Topics 7
T Choosing a Mentor Career and Occupation Discussions 3
K Selection Criteria for choosing a Management Representative for QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
S Choosing Parts for Attribute MSA (Measurement System Analysis) in 4th Edition, pg 132 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Difference between softwares in choosing correct Taguchi designs Using Minitab Software 16
bio_subbu Choosing a laboratory for biocompatibility test ISO 13485:2016 - Medical Device Quality Management Systems 8
M Choosing a Laser Micrometer - Your recommendations? General Measurement Device and Calibration Topics 8
Marc Forum User Name - Choosing a forum User Name (aka 'handle' or 'screen name') Elsmar Cove Forum ToS and Forum Policies 0
G Short TQM training - Choosing of most important points Training - Internal, External, Online and Distance Learning 3
B Choosing number of subgroups and subgroup size Statistical Analysis Tools, Techniques and SPC 4
D Choosing a Vision System - Recommendations for a User Friendlier System Quality Tools, Improvement and Analysis 3
D Need Help on choosing dimensional standards / equipment General Measurement Device and Calibration Topics 2
J Choosing Samples for Gage R&R - Randomly picked samples show very little variation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
Tim Folkerts DOE: Choosing a Design - Factors that affect the choice of design The Reading Room 0
B ISO10012:2003 Question - Choosing or assessing the capability of a piece of equipment Other ISO and International Standards and European Regulations 1
G Choosing a Sampling plan for Start Up Fabless IC Company - Guarantee a 200 DPM limit Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
gard2372 Choosing between a Small Company or a Large Company Career and Occupation Discussions 17
D Choosing a notified body for a new start up company in the UK - Medical Device area Registrars and Notified Bodies 6
G Choosing Supplier Evaluation Methods - Determining what a Critical Supplier is Supplier Quality Assurance and other Supplier Issues 31
Steve Prevette Choosing Performance Indicators Registered Visitor Articles Archive 0
C Questions to Ask Prospective Registrars Before Choosing Registrars and Notified Bodies 3
L Choosing a Registrar - Need registrar selection advice Registrars and Notified Bodies 6
