Choosing Nonconformities to Report
QualiTEE
Our current procedure calls for reporting/recording all nonconformities so we can capture our scrap costs and to watch for trends. Current management is looking to only record nonconformities that will cost >=$x to fix. Editing to add: and exclude certain categories from being eligible to formally reject (i.e.: tooling broke, part needs to be remade).
Just curious to see how common this is. How are your companies handling the decision on when to write a nonconformity?
Jean_B
Sage advice:
Don't when there's not a specification, but have a system that can sort out such candidates for making into specification.
If there's a specification there's an NC. Else you would have to differentiate must (spec) and should (guideline).
Avoid formalizing prescient selection like costing >= to fix, the 'important' ones, the dangerous ones. You will only know after the fact whether its true, or you'll convince yourself through confirmation bias that the only NC's worth it are the ones you're registering, because those are the only ones you have data for to show its true.
Do allow for an NC guide into a won't do further work for somesuch reason, but ensure it is trendable as death by a thousand cuts does exist.
Auto opt-ins (common sense) that don't need further rule-selection because their obviously important regardless of nitty picky details are not a bad thing, if they save cost and don't lose you resolution in analysis.
Tagin
That seems like a really bad idea. It's one thing to make a decision to absorb the cost of occasional low-value nonconformities; it's another to make a decision to not classify them as nonconformities at all when the standard says you shall control nonconforming outputs.
yodon
I think both @Jean_B and @Tagin have given excellent advice, but my curiosity is piqued: what's management rationale for only recording the NCs > $x? Is the NC process overly burdensome? Is it not so burdensome but you have so many they're looking to pare the number down?
QualiTEE
I agree with everything you all said. I'm not on board with what management is suggesting.
Management claims the rejection-writing is a burden and takes too much time (costs too much money), plus they are looking to reduce high scrap rate. Editing to add: We have some issues with customer supplied material coming in out of spec. Our procedure states we write rejections up in these cases so we can track repair costs and watch for potential trends. Management does not think we should write anything up for this because the error is not ours and in some cases we won't be doing a charge-back to the customer.
QualiTEE
But how do you absorb the costs on occasional low-value nonconformities without technically classifying them as an exception?
Tagin
That's part of the disposition of NC material. First, you identify it as NC, then segregate it, then decide what to do with it (i.e., it's disposition). One of the disposition options, depending on your documented process, could be to scrap NC material (and absorb the cost) that is less than X$ unit cost (or similar criteria).
For that kind of low-value scrap, you might decide that your analysis is limited to monitoring that, for example, total scrap$/month is less than XX$. If its more than than XX$ then you do a deeper dive to see what's happening.
But it needs to be founded on risk: low cost does not always equal low risk; a circuit breaker in a product might be low-cost but high-risk if they are NC.
All of this starts, though, with identifying these items as NC, and then giving yourself choices in your NC process that are risk-appropriate.
Ninja
Looking for Reality
Reading the above, it sounds like all are agreeing but somehow not...
If a NC is identified, you shall control NC outputs.
Mgmt is asking to report (assumed "to us") only those of high enough value to do something about.
Both are easily done...control them all, report only those meeting X criteria, disposition the rest without bothering mgmt. Everyone (including the standard) get what they want...
QualiTEE
We're a small company of 24 people: 11 mfg personnel, 1 Mfg Mgmt, 1 QC, 1 sales, etc.
Instead of saying "report", maybe I should say "document". Management does not want to document the nonconformity; no formal rejection written to document the nonconformity itself or the disposition. Mfg labor would go to the original job or to an indirect scrap code with no traceability. Maybe that's "control" in a way, but I fail to understand the effectiveness of that method.
Ninja
Looking for Reality
A curiosity...I don't think it's "playing word games" ...
How are you declaring the NC on product? Is it really a NC, or is it a process that simply doesn't run at 100% (none of them do)?
0.5% scrap from a process can simply be "yield loss"...I wouldn't call it a NC in the first place...
It was normal for us to trash the first 50' and last 75' of the process...it was not an NC, it's just the process...
A process with yield loss costs over a certain amount...call it what you want, but fix it before picking a name...
Just thinking out loud...
S Help needed in choosing the method of calculating the minimum sample size Internal Auditing 12
T Choosing a Notified Body for MDR - SGS/BSI/DNV/DQS-MED Registrars and Notified Bodies 0
E Choosing correct MOPs IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
C Quantifying risk in choosing the number of parts, operators and replicates in a GR&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Q Old products new class - Dental Devices - Choosing tests EU Medical Device Regulations 2
M Choosing Auditors - ISO 9001 / ISO 27001 (UK) IEC 27001 - Information Security Management Systems (ISMS) 2
T AS9100D - Scope of QMS for New Company - Only Choosing a Function Subset Due to Management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
E Choosing an ISO 9001 registrar with auditors familiar with our industry Registrars and Notified Bodies 10
M Dilemma about choosing the most applicable clause related to Risk ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
J Choosing QMS Software for Aerospace Company Quality Assurance and Compliance Software Tools and Solutions 5
B Choosing not to calibrate (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 6
Q Choosing between ISO 9001 (2015) & TL 9000 certifications ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
H On choosing touchscreen displays and ensuring IEC 60601 compliance IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
Q Choosing In-Process Inspection Characteristics Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Choosing the correct Distribution for Acceptance Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 19
S Choosing a suitable type of Elisa to Test my Sample Misc. Quality Assurance and Business Systems Related Topics 3
S Choosing the correct Elisa Test Food Safety - ISO 22000, HACCP (21 CFR 120) 1
K Choosing a Six Sigma training organization Six Sigma 4
H Choosing between RABQSA Lead Auditor or ASQ CQA Certification Professional Certifications and Degrees 2
S Choosing ISO 9001 Training and if I need the training for work ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S CE Marking choosing between module A, B CE Marking (Conformité Européene) / CB Scheme 2
A Getting Stuck Choosing a Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Choosing the right Industry Financial Report Manufacturing and Related Processes 1
M Advice for choosing Rechargeable Lithium Batteries to be used in a Medical Device Other Medical Device Related Standards 16
L Choosing a Statistical Test for dissertation results! Statistical Analysis Tools, Techniques and SPC 4
I Choosing a X-Ray Fluorescence Measuring Device for Chrome Coating Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J Choosing the Best Standard - ISO 9001 or ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 14
B Choosing Inspection Level and AQL AQL - Acceptable Quality Level 1
I Choosing the alpha level in an ANOVA Study Statistical Analysis Tools, Techniques and SPC 3
M Tolerance vs. Study Variation - Choosing the right one Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Choosing a Higher EER Air Conditioner After Work and Weekend Discussion Topics 7
T Choosing a Mentor Career and Occupation Discussions 3
K Selection Criteria for choosing a Management Representative for QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
A Choosing Document Control Software Document Control Systems, Procedures, Forms and Templates 13
S Choosing Parts for Attribute MSA (Measurement System Analysis) in 4th Edition, pg 132 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Difference between softwares in choosing correct Taguchi designs Using Minitab Software 16
bio_subbu Choosing a laboratory for biocompatibility test ISO 13485:2016 - Medical Device Quality Management Systems 8
M Choosing a Laser Micrometer - Your recommendations? General Measurement Device and Calibration Topics 8
G Short TQM training - Choosing of most important points Training - Internal, External, Online and Distance Learning 3
B Choosing number of subgroups and subgroup size Statistical Analysis Tools, Techniques and SPC 4
D Choosing a Vision System - Recommendations for a User Friendlier System Quality Tools, Improvement and Analysis 3
D Need Help on choosing dimensional standards / equipment General Measurement Device and Calibration Topics 2
J Choosing Samples for Gage R&R - Randomly picked samples show very little variation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
Tim Folkerts DOE: Choosing a Design - Factors that affect the choice of design The Reading Room 0
B ISO10012:2003 Question - Choosing or assessing the capability of a piece of equipment Other ISO and International Standards and European Regulations 1
G Choosing a Sampling plan for Start Up Fabless IC Company - Guarantee a 200 DPM limit Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
gard2372 Choosing between a Small Company or a Large Company Career and Occupation Discussions 17
D Choosing a notified body for a new start up company in the UK - Medical Device area Registrars and Notified Bodies 6
G Choosing Supplier Evaluation Methods - Determining what a Critical Supplier is Supplier Quality Assurance and other Supplier Issues 31
Steve Prevette Choosing Performance Indicators Registered Visitor Articles Archive 0
