Choosing Nonconformities to Report
#11
Many organizations I have been in also have a ‘’low cost scrap container”. Screws, wires, tubes adn the like that are damaged are just thrown into the low cost scrap containers. We also have bio containers for scrapping our low cost biologicals in my current org. We don’t write up a NC report. These meet the requirements for identifying and controlling non conforming material. We can figure out the cost if we wanted to but these things are so low on the Pareto we don’t waste our time trying to track the cost.
QualiTEE
#12
We technically declare NC "non-fulfillment of a requirement". Generally speaking, any part being manufactured that is not to print spec. Examples: Part damaged when tooling breaks, customer-supplied product arrives out of spec, product machined incorrectly; these all get formal documented rejections. Any instances where the part being manufactured becomes out of the specified tolerance and needs to be corrected/reworked/re-made/scrapped. If tooling breaks but the part is still good, then no NC.
Nonconformities by department (customer, supplier, mfg, etc.) are listed separately when reported to management and some (customer errors) are removed from our metric all together as to not inflate our own reject rate.
And good question, Ninja. We do not NC yield loss. We do also have certain non-inventoried components that do not need to be reported (nuts, bolts, screws, wire).
We're a small shop that averages completing 18 orders per week and shipping 150 parts per week, so we aren't talking 50+ nonconformities here. Probably 15 per month on average.
Ninja
Looking for Reality
#13
A curious metric to look at...
If you remove "accidents" (like tool break) and "we didn't cause it" (like customer sending bad stuff) from the NC list for the last year, what would your average be then?
Perhaps stuff like that is why Mgmt is trying to whittle down the list.
I've been top management, and am again currently...if I got reports every month telling me about tool breaks I'd wonder why I'm paying the quality guy...
If 90% of tool breaks for the last 6mnths, costing a total of $50K in scrap and repairs, all happened by the same person ...but no one else has that issue on the same parts...that's what you report to me. That's something I can action.
Calling a NC when the customer ships the wrong part...that's just a waste of my time...make sense?
...and FWIW, a random tool break ruining a part in machining...that IS yield loss in my eyes...unless by negligence or intent.
qualprod
#14
A curiosity...I don't think it's "playing word games" ...
How are you declaring the NC on product? Is it really a NC, or is it a process that simply doesn't run at 100% (none of them do)?
0.5% scrap from a process can simply be "yield loss"...I wouldn't call it a NC in the first place...
It was normal for us to trash the first 50' and last 75' of the process...it was not an NC, it's just the process...
A process with yield loss costs over a certain amount...call it what you want, but fix it before picking a name...
Just thinking out loud...
Supporting what is said by Ninja
There are processes that for starting a production produce scrap.
At starting, it is needed some tuning, scrapping an amount of raw material, but this works in this way.
After scrap is produced and tuning is finished, the production starts.
If afterwards, bad product is produced, ok, this is a non conforming product.
In this case is good practice to monitor amount of scrap, sometimes is higher than planned.
My two cents.
QualiTEE
#15
I'll go check that metric. We do break the NCs into categories.
And what you say makes sense... minus the part of if you don't record it, how can you track it to ever report the trend to management? You can't track that 90% of tool breaks in the last 6 months costing $50k in scrap is from one guy if you never once document that it happened. It's all from memory at that point. There would be no proof if reprimand were required. I had, however, recommended revising our NC form to indicate things like negligence or intent so we could only write those up, but no bites on that yet.
I can only speculate on why the company requires an NC when customer supplied product is out of tolerance because I inherited this system. We don't NC if they send the wrong part, but do if the part is defective and requires repair. We got ourselves into an expensive situation last year because our customer was consistently sending product that was not to spec, and our old mfg manager claimed he had a verbal okay to go ahead and repair the parts so we could machine them. Never documented any of this. Customer claimed the opposite and charged us for the scrap parts. Our machinists were reprimanded for going ahead with the machining and for applying the extra hours to the end order. I can only assume that happened in the past, which is why the person who designed the system wanted something more formal than an email to document the situation.
My two cents.
We do not NC the setup/starting processes or materials. We NC once actual production has started.
Ninja
Looking for Reality
#16
Looks like we're headed the right way (IMO)...
Recording it, and calling it NC are two different things.
Absolutely DO record a tool break, especially if it is a common thing that ruins a part.
Absolutely DO NOT call it an NC...
Not everything that goes wrong in the world has to be called NC...NC is a special term in ISO that comes with baggage...recording stuff to find trends and improve how you do business is "continuous improvement".
Don't get me wrong...if the tool broke because the machinist refused to follow proper procedure, it is totally NC...but tools break when everything is done right, too...they aren't both NC.
I submit for your consideration that if the customer sends a defective part, when they should have sent an in-spec part...they sent the wrong part. This is not an NC on your end (it is one on THEIR end).
You noting that the part is defective prior to starting work on it is an example of your system working correctly...don't NC it.
QualiTEE
#17
Mfg Management doesn't want to RECORD the event at all. No record of it ever happening.
We currently do consider any occurence of broken tooling an NC as we do not yet classify neglect or intent. I'll push for the new classifications so we can factor those out, yet still have a record of what happened.
Also, I think maybe our confusion comes in because we only have the NC form to document any product errors. The completion of the NC form is in the customer supplied material cases is more for tracking purposes, and those do not factor into our NC count. I'm sure an email to the customer about it would suffice as a formal record of the bad product, but there's no tracking the frequency of occurrence and no way to monitor in case we need corrective action. I do agree, it's not our NC. It's just the only form we have (again, minus email correspondences).
RoxaneB
#18
In my previous life, we had "triggers" - all nonconformances (product and process) were recorded, but defined triggers were how we prioritized our resources on resolving. As an example, a 2 minute unscheduled electrical maintenance downtime would be documented so that we had the data, but it would likely stop there. If that unscheduled downtime was, say, 30 minutes, it would generate a nonconformance - documenting the correction taken. If that unscheduled downtime was over 2 hours, we'd likely be looking a full-blown corrective action. Every year, as part of our planning process, we would analyze all nonconformances to see if we could tighten our triggers.
And, yes, there were some cases where $ was a trigger. Customer complaints was one...if the $ to fix was less than than the $ to investigate, we'd pay out, but it was still documented so that come planning time, we could see if there were patterns (frequent complainers, complaint subjects, etc.).
Ninja
Looking for Reality
#19
If that decision was based on data, I'd sign off on it...
Two data situations that come to mind immediately:
1. I've seen the data or the last two years, and it doesn't happen often enough to bother with anymore...so stop bothering with it.
2. The cost to "fix", or "replace and move on" is less than the cost to document it and track it.
If it is instead "We don't want others to know about it", it does put you in an awkward situation...help the company or help yourself.
Ideally these are aligned...but when mgmt tries to hide something, all accomplices see these two paths part.
Which do you think it is?
QualiTEE
#20
It's the second option as the guy doesn't review the data and the cost (though sometimes minor) is nowhere near less than the cost to document and track it.
But it is what it is, I guess. I do understand, but I don't think they want this for the right reasons.
C Quantifying risk in choosing the number of parts, operators and replicates in a GR&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Q Old products new class - Dental Devices - Choosing tests EU Medical Device Regulations 2
M Choosing Auditors - ISO 9001 / ISO 27001 (UK) IEC 27001 - Information Security Management Systems (ISMS) 2
T AS9100D - Scope of QMS for New Company - Only Choosing a Function Subset Due to Management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
E Choosing an ISO 9001 registrar with auditors familiar with our industry Registrars and Notified Bodies 10
M Dilemma about choosing the most applicable clause related to Risk ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
J Choosing QMS Software for Aerospace Company Quality Assurance and Compliance Software Tools and Solutions 5
B Choosing not to calibrate (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 6
Q Choosing between ISO 9001 (2015) & TL 9000 certifications ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
H On choosing touchscreen displays and ensuring IEC 60601 compliance IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
Q Choosing In-Process Inspection Characteristics Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Choosing the correct Distribution for Acceptance Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 19
S Choosing a suitable type of Elisa to Test my Sample Misc. Quality Assurance and Business Systems Related Topics 3
S Choosing the correct Elisa Test Food Safety - ISO 22000, HACCP (21 CFR 120) 1
K Choosing a Six Sigma training organization Six Sigma 4
H Choosing between RABQSA Lead Auditor or ASQ CQA Certification Professional Certifications and Degrees 2
S Choosing ISO 9001 Training and if I need the training for work ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S CE Marking choosing between module A, B CE Marking (Conformité Européene) / CB Scheme 2
A Getting Stuck Choosing a Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Choosing the right Industry Financial Report Manufacturing and Related Processes 1
M Advice for choosing Rechargeable Lithium Batteries to be used in a Medical Device Other Medical Device Related Standards 16
L Choosing a Statistical Test for dissertation results! Statistical Analysis Tools, Techniques and SPC 4
I Choosing a X-Ray Fluorescence Measuring Device for Chrome Coating Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J Choosing the Best Standard - ISO 9001 or ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 14
B Choosing Inspection Level and AQL AQL - Acceptable Quality Level 1
I Choosing the alpha level in an ANOVA Study Statistical Analysis Tools, Techniques and SPC 3
M Tolerance vs. Study Variation - Choosing the right one Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Choosing a Higher EER Air Conditioner After Work and Weekend Discussion Topics 7
T Choosing a Mentor Career and Occupation Discussions 3
K Selection Criteria for choosing a Management Representative for QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
A Choosing Document Control Software Document Control Systems, Procedures, Forms and Templates 13
S Choosing Parts for Attribute MSA (Measurement System Analysis) in 4th Edition, pg 132 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Difference between softwares in choosing correct Taguchi designs Using Minitab Software 16
bio_subbu Choosing a laboratory for biocompatibility test ISO 13485:2016 - Medical Device Quality Management Systems 8
M Choosing a Laser Micrometer - Your recommendations? General Measurement Device and Calibration Topics 8
Marc Forum User Name - Choosing a forum User Name (aka 'handle' or 'screen name') Elsmar Cove Forum ToS and Forum Policies 0
G Short TQM training - Choosing of most important points Training - Internal, External, Online and Distance Learning 3
B Choosing number of subgroups and subgroup size Statistical Analysis Tools, Techniques and SPC 4
D Choosing a Vision System - Recommendations for a User Friendlier System Quality Tools, Improvement and Analysis 3
D Need Help on choosing dimensional standards / equipment General Measurement Device and Calibration Topics 2
J Choosing Samples for Gage R&R - Randomly picked samples show very little variation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
Tim Folkerts DOE: Choosing a Design - Factors that affect the choice of design The Reading Room 0
B ISO10012:2003 Question - Choosing or assessing the capability of a piece of equipment Other ISO and International Standards and European Regulations 1
G Choosing a Sampling plan for Start Up Fabless IC Company - Guarantee a 200 DPM limit Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
gard2372 Choosing between a Small Company or a Large Company Career and Occupation Discussions 17
D Choosing a notified body for a new start up company in the UK - Medical Device area Registrars and Notified Bodies 6
G Choosing Supplier Evaluation Methods - Determining what a Critical Supplier is Supplier Quality Assurance and other Supplier Issues 31
Steve Prevette Choosing Performance Indicators Registered Visitor Articles Archive 0
C Questions to Ask Prospective Registrars Before Choosing Registrars and Notified Bodies 3
L Choosing a Registrar - Need registrar selection advice Registrars and Notified Bodies 6
