Choosing not to calibrate (IATF 16949)
Hi all, I could do with an idea if this would be acceptable or not.
I am looking at calibration with a sensible eye after i have inherited a bloated and unrealistic system.
One massive pain is the fitting / trimming aids we use, there are hundreds of them, completely impossible to calibrate and get lost and moved daily.
We manufacture car interior parts to a known master, and set of standards, however sometimes we use a mating panel to double check how it would look when finished.
(What we can let go, how a seam might look when pressed against another part etc.)
I hold that these are not gauges, they cannot be calibrated (even verified really), they are not used to check a part to any standard or customer requirement.
Purely as an assistance to manufacturing.
My plan is as such:
-Keep a list of the parts and what they are for.
-Include them in work instruction as the aids they are meant to be.
-Individually label them as aids and the review them before each use for damage (they cannot wear only break).
-Change our process to clearly identify these items as aids and state that we do not calibrate them.
This would make my life so much easier and less risk.
Is there anything obvious that i have missed that would bring issue under audit.
Calibration is appropriate, but verification is. Verification can include periodic checks to ensure the condition of mating surfaces, features etc such that the mating part is correctly evaluated.
Ninja
Looking for Reality
Calibration is not appropriate, but verification is.
I think Andy missed a "not"...
The question would be "How do you know your part is good?"
When you say
you're already halfway there...
The other half is to consider "What goes wrong if the tool is bent/damaged/off-size/etc." and "Where in the process will that be caught?"
I used a granite surface plate and shims to set a gap in processing, and adjusted that gap by means of micrometers...none were calibrated.
The gage measuring the resulting product was calibrated, and that is what mattered.
Taking this approach (and not wanting to explain it to every auditor who walked by), I put the rationale right in the procedure document as notes.
Note 1: blade micrometers do not require calibration because A
Note 2: Surface plates used for setting gaps do not require calibration because B.
etc...
Once those notes were in place, I never had another question or issue about it.
TKaplan
I think the important point here is that these items are, as noted in the initial message "not used to check a part to any standard or customer requirement". I'm assuming there are other gauges and measurement equipment that performs that function.
In my minds eye, what we have here is a dress makers dummy; something to set a part to and look for flaws. If the part is not being modified or measured in any fashion through the use of this device, but is only being visually checked, then I wouldn't think that these items would need to be listed as calibrated equipment.
Validation of the condition of these items would be useful yes, but only if the damages or possible flaws to the items would result in a change or any type of acceptance / rejection of the product being analysed. From the description, it doesn't sound like that would be the case.
I have seen plenty of little gadgets and gizmos that make the production process better, faster, and more efficient. Not all of them are used as measurement tools against a products CTQ, and are therefore not calibrated equipment. In my humble opinion, if this is the case here, then it is as Benmg said.....they are 'aids'.
I agree with the advice already given...list these items in the OWI's, SOP's, and Visual Standards as "Visual Aids unrelated to validation of CTQ", and be done with it.
Thank you all for the comments, i have now started reducing our "gauge" list, in some areas this is by as much as 75%.
We have our next CB visit in March, i feel confident that this will be acceptable.
Ninja
Looking for Reality
It's all about whether it is a "tool" or a "gage"...
Or to say the same thing another way...are you getting data from it? Do you make decisions based on that data?
Q Choosing Nonconformities to Report ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
C Quantifying risk in choosing the number of parts, operators and replicates in a GR&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Q Old products new class - Dental Devices - Choosing tests EU Medical Device Regulations 2
M Choosing Auditors - ISO 9001 / ISO 27001 (UK) IEC 27001 - Information Security Management Systems (ISMS) 2
T AS9100D - Scope of QMS for New Company - Only Choosing a Function Subset Due to Management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
E Choosing an ISO 9001 registrar with auditors familiar with our industry Registrars and Notified Bodies 10
M Dilemma about choosing the most applicable clause related to Risk ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
J Choosing QMS Software for Aerospace Company Quality Assurance and Compliance Software Tools and Solutions 5
Q Choosing between ISO 9001 (2015) & TL 9000 certifications ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
H On choosing touchscreen displays and ensuring IEC 60601 compliance IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
Q Choosing In-Process Inspection Characteristics Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Choosing the correct Distribution for Acceptance Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 19
S Choosing a suitable type of Elisa to Test my Sample Misc. Quality Assurance and Business Systems Related Topics 3
S Choosing the correct Elisa Test Food Safety - ISO 22000, HACCP (21 CFR 120) 1
K Choosing a Six Sigma training organization Six Sigma 4
H Choosing between RABQSA Lead Auditor or ASQ CQA Certification Professional Certifications and Degrees 2
S Choosing ISO 9001 Training and if I need the training for work ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S CE Marking choosing between module A, B CE Marking (Conformité Européene) / CB Scheme 2
A Getting Stuck Choosing a Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Choosing the right Industry Financial Report Manufacturing and Related Processes 1
M Advice for choosing Rechargeable Lithium Batteries to be used in a Medical Device Other Medical Device Related Standards 16
L Choosing a Statistical Test for dissertation results! Statistical Analysis Tools, Techniques and SPC 4
I Choosing a X-Ray Fluorescence Measuring Device for Chrome Coating Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J Choosing the Best Standard - ISO 9001 or ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 14
B Choosing Inspection Level and AQL AQL - Acceptable Quality Level 1
I Choosing the alpha level in an ANOVA Study Statistical Analysis Tools, Techniques and SPC 3
M Tolerance vs. Study Variation - Choosing the right one Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Choosing a Higher EER Air Conditioner After Work and Weekend Discussion Topics 7
T Choosing a Mentor Career and Occupation Discussions 3
K Selection Criteria for choosing a Management Representative for QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
A Choosing Document Control Software Document Control Systems, Procedures, Forms and Templates 13
S Choosing Parts for Attribute MSA (Measurement System Analysis) in 4th Edition, pg 132 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Difference between softwares in choosing correct Taguchi designs Using Minitab Software 16
bio_subbu Choosing a laboratory for biocompatibility test ISO 13485:2016 - Medical Device Quality Management Systems 8
M Choosing a Laser Micrometer - Your recommendations? General Measurement Device and Calibration Topics 8
Marc Forum User Name - Choosing a forum User Name (aka 'handle' or 'screen name') Elsmar Cove Forum ToS and Forum Policies 0
G Short TQM training - Choosing of most important points Training - Internal, External, Online and Distance Learning 3
B Choosing number of subgroups and subgroup size Statistical Analysis Tools, Techniques and SPC 4
D Choosing a Vision System - Recommendations for a User Friendlier System Quality Tools, Improvement and Analysis 3
D Need Help on choosing dimensional standards / equipment General Measurement Device and Calibration Topics 2
J Choosing Samples for Gage R&R - Randomly picked samples show very little variation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
Tim Folkerts DOE: Choosing a Design - Factors that affect the choice of design The Reading Room 0
B ISO10012:2003 Question - Choosing or assessing the capability of a piece of equipment Other ISO and International Standards and European Regulations 1
G Choosing a Sampling plan for Start Up Fabless IC Company - Guarantee a 200 DPM limit Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
gard2372 Choosing between a Small Company or a Large Company Career and Occupation Discussions 17
D Choosing a notified body for a new start up company in the UK - Medical Device area Registrars and Notified Bodies 6
G Choosing Supplier Evaluation Methods - Determining what a Critical Supplier is Supplier Quality Assurance and other Supplier Issues 31
Steve Prevette Choosing Performance Indicators Registered Visitor Articles Archive 0
C Questions to Ask Prospective Registrars Before Choosing Registrars and Notified Bodies 3
L Choosing a Registrar - Need registrar selection advice Registrars and Notified Bodies 6
