Choosing Samples for Gage R&R - Randomly picked samples show very little variation
jimbowen
This one again!! Ihave followed MSA 3rd edition and taken 10 random samples from our process. The problem is we have a stable process so the randomly picked samples show very little variation. Our part has a diameter of 26.32mm and the parts produced do not really vary due to the stable nature of the process.
R & R is a ratio of variation in measurement system divided by variation between the parts. By reducing part to part variation, you are reducing the denominator which will result poor ratio.
This basically means I end up with a poor %GRR.
How can I get around this?
Re: Choosing Samples for R&R
There is no easy way around this. If the standard deviation of your samples is equal to the short term standard deviation of your process, and you get a poor %GRR, your only option is to improve the gaging system. It is an iterative process. That is you improve the process until the gage becomes inadequate, then you improve the gage and repeat the cycle of improvement.
Can you attach the results of your study, including the graphs? We might be able to point you in the right direction. Did you verify that the gage has adequate resolution? This can kill an MSA before you start.
jimbowen
i'll have to post it tommorrow as I'm sat in my front room but thanks anyway. What I did find though is that if you enter 6.85 into all of the inputs apart from one where you enter 6.86 then the %GRR was 59.76%. I don't understand how if the process is so tight and the variation is so low that you would get such a high result.
Re: Choosing Samples for Gage R&R
That sounds like a gage resolution issue. I'll be able to confirm when I see the data.
Atul Khandekar
To add to what Miner has said...Are you doing SPC on this characteristic? What is the 6-sigma process width, Tolerance and Cp? Are you using this gage for process improvement or final inspection? Over what period of time did you collect your samples?
jimbowen
The tesing we carry out is final inspection. I think on reading a couple of other threads that the answer to our problem is to use tolerence rather than variation for the %GRR. We are assessing the gage and not the process and believe that using the tolerence range gives us a better indication of the gage %GRR. The only thing I would ask is do I replace the TV or PV with the tolerence range. Please refer to page 114 MSA 3rd edition. Thanks...
Atul Khandekar
Are you refering to the spreadsheet you attached in the other thread? You need to divide the values of EV,AV and GRR by (Tolerance/6). Refer to the para at the end of page 116 MSA manual.
You will have to look at the parts selection and gage resolution as well.
jimbowen
Ok here goes. The gauge is 0.001mm resolution. The tolerence is +-0.02mm. The 10 parts were randomly picked from process and there are 3 operators who carry out 3 trials. The actual data collected is entered into the attached spreadsheet which is taken from MSA 3rd Edition, page 113-114. Incendently we put the same data into a Ford spreadsheet and came up with 19.32%. The MSA version using the same data came up with 51.29%:confused:
Wesley Richardson
Wes R
Hi Jim,
I see two immediate problems with your spreadsheet. Your range is showing 0.00 in several cases, when it is > 0. Also your averages do not reflect the data you have shown. Both may be due to the number of digits you are displaying. You did not include the equations for the calculations, so I cannot tell.
Wes R.
Atul Khandekar
Look at the values.
I think Ford doc uses K constants from MSA 2nd edition. The GRR VALUE is already multiplied by a facor of 5.15. Also the values in Ford doc are shown rounded off (ex. GRR=0.01 which I think is 0.0115), the tolerance it uses is 0.06! and the GRR % is a % of Tolerance.
Your calculations seem to be correct as per MSA 3rd edition. The GRR% (51.29) is a % of TV, not a % of tolerance.
S Help needed in choosing the method of calculating the minimum sample size Internal Auditing 12
T Choosing a Notified Body for MDR - SGS/BSI/DNV/DQS-MED Registrars and Notified Bodies 0
E Choosing correct MOPs IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Q Choosing Nonconformities to Report ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
C Quantifying risk in choosing the number of parts, operators and replicates in a GR&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Q Old products new class - Dental Devices - Choosing tests EU Medical Device Regulations 2
M Choosing Auditors - ISO 9001 / ISO 27001 (UK) IEC 27001 - Information Security Management Systems (ISMS) 2
T AS9100D - Scope of QMS for New Company - Only Choosing a Function Subset Due to Management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
E Choosing an ISO 9001 registrar with auditors familiar with our industry Registrars and Notified Bodies 10
M Dilemma about choosing the most applicable clause related to Risk ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
J Choosing QMS Software for Aerospace Company Quality Assurance and Compliance Software Tools and Solutions 5
B Choosing not to calibrate (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 6
Q Choosing between ISO 9001 (2015) & TL 9000 certifications ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
H On choosing touchscreen displays and ensuring IEC 60601 compliance IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
Q Choosing In-Process Inspection Characteristics Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Choosing the correct Distribution for Acceptance Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 19
S Choosing a suitable type of Elisa to Test my Sample Misc. Quality Assurance and Business Systems Related Topics 3
S Choosing the correct Elisa Test Food Safety - ISO 22000, HACCP (21 CFR 120) 1
K Choosing a Six Sigma training organization Six Sigma 4
H Choosing between RABQSA Lead Auditor or ASQ CQA Certification Professional Certifications and Degrees 2
S Choosing ISO 9001 Training and if I need the training for work ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S CE Marking choosing between module A, B CE Marking (Conformité Européene) / CB Scheme 2
A Getting Stuck Choosing a Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Choosing the right Industry Financial Report Manufacturing and Related Processes 1
M Advice for choosing Rechargeable Lithium Batteries to be used in a Medical Device Other Medical Device Related Standards 16
L Choosing a Statistical Test for dissertation results! Statistical Analysis Tools, Techniques and SPC 4
I Choosing a X-Ray Fluorescence Measuring Device for Chrome Coating Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J Choosing the Best Standard - ISO 9001 or ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 14
B Choosing Inspection Level and AQL AQL - Acceptable Quality Level 1
I Choosing the alpha level in an ANOVA Study Statistical Analysis Tools, Techniques and SPC 3
M Tolerance vs. Study Variation - Choosing the right one Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Choosing a Higher EER Air Conditioner After Work and Weekend Discussion Topics 7
T Choosing a Mentor Career and Occupation Discussions 3
K Selection Criteria for choosing a Management Representative for QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
A Choosing Document Control Software Document Control Systems, Procedures, Forms and Templates 13
S Choosing Parts for Attribute MSA (Measurement System Analysis) in 4th Edition, pg 132 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Difference between softwares in choosing correct Taguchi designs Using Minitab Software 16
bio_subbu Choosing a laboratory for biocompatibility test ISO 13485:2016 - Medical Device Quality Management Systems 8
M Choosing a Laser Micrometer - Your recommendations? General Measurement Device and Calibration Topics 8
G Short TQM training - Choosing of most important points Training - Internal, External, Online and Distance Learning 3
B Choosing number of subgroups and subgroup size Statistical Analysis Tools, Techniques and SPC 4
D Choosing a Vision System - Recommendations for a User Friendlier System Quality Tools, Improvement and Analysis 3
D Need Help on choosing dimensional standards / equipment General Measurement Device and Calibration Topics 2
Tim Folkerts DOE: Choosing a Design - Factors that affect the choice of design The Reading Room 0
B ISO10012:2003 Question - Choosing or assessing the capability of a piece of equipment Other ISO and International Standards and European Regulations 1
G Choosing a Sampling plan for Start Up Fabless IC Company - Guarantee a 200 DPM limit Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
gard2372 Choosing between a Small Company or a Large Company Career and Occupation Discussions 17
D Choosing a notified body for a new start up company in the UK - Medical Device area Registrars and Notified Bodies 6
G Choosing Supplier Evaluation Methods - Determining what a Critical Supplier is Supplier Quality Assurance and other Supplier Issues 31
Steve Prevette Choosing Performance Indicators Registered Visitor Articles Archive 0
