Circuit board FAI reports- How do you folks deal with these?
FloridaST
I'm looking for ideas on how best to create a First Article Inspection on completed circuit boards (PCBAs). Not the raw board, the populated board.
Our current process follows AS9102 but it's all done by hand. Bubble numbering the drawing, entering the BOM into excel (sometimes hundreds of components), coloring in the drawing to indicate when components are verified against the first article board. It's tedious and it doesn't look professional. Can someone recommend software to help create these more quickly and professionally?
I looked into DISCUS but it's more suited towards machined parts though I can make it work for what I need and it would certainly be more professional and easier to print and submit to customers. Thanks!
Kingsld1
RS Simmons Co: Mfg of PCB & PCBA Semi-automatic optical Inspection Machines is a hardware/ software solution. basically a camera on a xy table with custom software.
you take a picture of a golden component as you program the machine. When the program runs, it displays the golden part and the current part. Operator decides if its good, bad or marginal. Bad or marginal calls let you enter a custom error code. Excel spreadsheet report and photos are saved.
Have not used the system but it looks slick. Our company looked at it a few years ago but decided to try to duplicate the function with a vision system. :(
FloridaST
That would be amazing but I'll just keep doing it the way we've always done it. It works, customers don't complain, so meh. My main problem is by the time I get to do a 1st article on a board, they've already built the whole job. Kinda defeats the purpose.
V Printed Circuit Board Assembly and Components FAI Question Document Control Systems, Procedures, Forms and Templates 8
gohyl Printed Circuit Board - Unusual sighting between pads, is it normal. Manufacturing and Related Processes 19
W Printed Circuit Board - IMDS declaration RoHS, REACH, ELV, IMDS and Restricted Substances 3
D Printed Circuit Board Assembly - General Discussion Manufacturing and Related Processes 1
R Medical Device Circuit Board Component Changes - Is this rework or not? ISO 13485:2016 - Medical Device Quality Management Systems 8
michellemmm Hardware Design Standards - Printed Circuit Board Assembly EASA and JAA Aviation Standards and Requirements 2
B Revision Control of PCBs (Printed Circuit Board) and Printed Circuit Board Assemblies Manufacturing and Related Processes 6
Q Workmanship on PCB (Printed Circuit Board) Assembly Manufacturing and Related Processes 14
P PCB (Printed Circuit Board)/Electronics Inspection Training? IPC-A-610? Career and Occupation Discussions 10
K Change Circuit Board to CE marked product on CE Marked Medical Device EU Medical Device Regulations 2
J Frustrated with Printed Circuit Board Assembly Suppliers Supplier Quality Assurance and other Supplier Issues 11
A PCB (Printed Circuit Board) Assembly Inspection Checklist Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J Circuit Board Incoming Inpection Criteria 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
J Curing Circuit Board Soldermask and Legend Simultaneously Quality Manager and Management Related Issues 4
N PCBA (Printed Circuit Board Assembly) Conformal Coating Material and Thickness? Reliability Analysis - Predictions, Testing and Standards 15
J Auditing PCB (Printed Circuit Board) Assembly Lines - Fire And Safety Systems ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
P I need to make an MSDS for PCB (Printed Circuit Board) Assembly Product Miscellaneous Environmental Standards and EMS Related Discussions 10
M PCB (Printed Circuit Board) Root Cause Fault Analysis Problem Solving, Root Cause Fault and Failure Analysis 1
C PCB (Printed Circuit Board) Assembly - Wave Solder Capability Statistical Analysis Tools, Techniques and SPC 6
G 60601-1 8.8.3. short circuit of both side during insulation test IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M Do I need separation in my circuit with a medical charger? IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
D SINGLE FAULT CONDITION, short circuit and open circuit of any component (IEC 60601-1 3.1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
Ahang Separation between secondary circuit and accessible parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S Serializing Circuit Card Assemblies (CCAs) in EPICOR Misc. Quality Assurance and Business Systems Related Topics 2
S How to determine the Air Clearance for Floated Secondary Circuit IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
W Supply Voltage Condition for Transformer O/L and S/C (open & short circuit) testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
R How to determine the ratings of components in primary circuit IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
D CCA (circuit card assembly) First Article form 1 requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
R How much Protective Current Rating of Building Branch Circuit should be considered? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
G Creepage and Clearance Distance for MOOP on Secondary Circuit IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
R Separation of Network Port from other Circuits including Patient Circuit IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
JoCam Nadcap AC7120 (Audit Criteria for Circuit Card Assemblies) - Acceptance Criteria AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
V External power supply with reinforced insulation as a simple secondary circuit? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
R DFMEA (Design FMEA) on Printed Circuit Boards (PCB's) FMEA and Control Plans 2
K Using a Circuit Breaker instead of Fuses in Medical Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
C Any CQI-Special Process related to Printed Circuit Boards (PCB)? IATF 16949 - Automotive Quality Systems Standard 1
Al Rosen AS9102 for Electronic Circuit Card Assembly that contains COTS Components AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
W Kalrez 1050LF in Medical Device Breathing Circuit ISO 13485:2016 - Medical Device Quality Management Systems 9
J Definition Servicing circuit boards - Differences between Rework and Repair Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
L Calibration Procedure for an IC (Integrated Circuit) Test Socket Calibration and Metrology Software and Hardware 6
R Are multi-faults needed? Effects of a Short Circuit IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
B Manual Inspection Tools for PCB (Populated Printed Circuit Boards) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
G Using Visio 2010 as a Mapping Program for Circuit Boards Quality Assurance and Compliance Software Tools and Solutions 3
R Induction Coil Open Circuit Failure Root Cause Problem Solving, Root Cause Fault and Failure Analysis 15
Al Rosen AS9102 FAI for Circuit Card Assembly - Measure each hole and document it? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
Marc Welcome to Circuit City, where stupidity is state of the art World News 24
J Short-circuit in electronic circuit - FMEA failure effect or a failure cause? FMEA and Control Plans 7
D Supplier QMS Development - Tier 3 integrated circuit supplier to automotive Supplier Quality Assurance and other Supplier Issues 4
Q Qualifying Persons to Reflow Solder by hand - Circuit boards Various Other Specifications, Standards, and related Requirements 3
Marc Jack Kilby, inventor of the integrated circuit, dies at 81 World News 1
