Citied for not doing a pull test on our crimper - Is there a 'cheap' way to do it?
L
Leonard1234
I run a new small business and I have just went through a audit from a customer and was citied for not doing a pull test on our crimper we use. I don't have the capital right now to buy a pull tester but I do have calbrated weights that meet his pull requirement of 40 lbs can i use this instead if so what would be the best way to do it and record it?
Please advise :confused:
Hershal
Metrologist-Auditor
I would suggest crimping some specimens at periodic intervals and use the weights as a static pull. Tie the weights to the non-crimped end. Set up a check form under your document control system, and when the checks are performed then fill in the appropriate fields on the form. Keep this one nice and simple.
Hope this helps.
Hershal
E
e006823
What is your customer’s requirement? Do they specify a test method? I know that crimped connections on cable harness assemblies NASA specifies a minimum pull force, head travel speed the tester and frequency that the test will be performed. Whatever method you choose make sure your customer agrees with it.
Test and inspection requirements originate in the design record (the drawing and associated standards and specifications). If there's a customer specification that addresses crimp integrity, it's expected that you'll have data to support compliance with it, rather than just your own assertions that everything's OK. The customer has already told you that data is expected, so if you're not sure about acceptable test methods you need to talk to the customer.
This is all a part of contract review--when a job is quoted, you need to review the specifications and make sure that you are capable of producing parts that meet specifications, and that you are capable of verifying that you've met them. In this instance, the need for pull-testing should have been established at the outset, so that associated costs could be accounted for in your quotation.
qualprod What do CB´s change when doing a partial moving ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M What to be careful about/focus on when doing a Technical File review EU Medical Device Regulations 4
K The correct way of doing a 2 Sample T test Reliability Analysis - Predictions, Testing and Standards 7
V CE Mark under MDD or IVDR - IVD company doing Virtual Manufacturing Other Medical Device Regulations World-Wide 3
Sidney Vianna Are the Accreditation Bodies doing their job? Keeping CB's accountable Registrars and Notified Bodies 0
GreatNate QMS in SharePoint - Is anyone doing this? Manufacturing and Related Processes 10
D Doing both a top-down and a bottom-up risk assessment - How to combine ISO 14971 - Medical Device Risk Management 13
A True purpose of doing EST (Electrical Safety Test) on medical device Other Medical Device Related Standards 3
supadrai d/b/a doing business as and the FDA US Food and Drug Administration (FDA) 1
Raffy What is the first step in doing PIA (Privacy Impact Assessment)? IEC 27001 - Information Security Management Systems (ISMS) 3
I AS9100D - Interview Request - I'm doing research Misc. Quality Assurance and Business Systems Related Topics 1
Q Doing an MSA on a Climatic Chamber Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
N Explanation - Quality means doing it right when no one is looking ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R CMDCAS and dba's (Doing Business As) Canada Medical Device Regulations 2
Sidney Vianna As a profession we, auditors, are not doing enough - Simon Feary speech Registrars and Notified Bodies 36
B Doing MSA Variables Data Study on Threads Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D Are we doing enough to meet Identification and Traceability 7.5.3 Requirements? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Who is doing BGA cross sectional analysis in assembled PCBA in INDIA? Reliability Analysis - Predictions, Testing and Standards 1
G Thoughts on Audit Finding for not doing Gage R and R for Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
AnaMariaVR2 What the Internet is Doing to Our Brains Coffee Break and Water Cooler Discussions 5
J Doing a "yearly" mass calibration of gages over the weekend. Any advice? General Measurement Device and Calibration Topics 4
P Root Cause for not doing Management Review ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P Testing Standards - Regulatory agency doing Enforcement Testing of Medical Devices EU Medical Device Regulations 5
T DOE Multi level Taguchi - I am doing a Capstone Project Using Minitab Software 10
M Requirement to complete an MSA when doing Comparative Tests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G Dealing with Excessive Within-Part Variation when doing MSA and Cpk studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
M To find the Optimum Parameter Setting using Minitab (Doing DOEs) Using Minitab Software 18
O NET-INSPECT is it worth it? Small Machine Shop doing AS9100 Quality Manager and Management Related Issues 8
R First Pass Yield - Am I doing correct the First Pass Yield Metric Quality Tools, Improvement and Analysis 2
P Environmental Aspects and Impacts while doing Software Development ISO 14001:2015 Specific Discussions 6
L Must Calibration Labs have IEC 17025 before doing Calibration Jobs for Customers ISO 17025 related Discussions 13
F Regulatory Affairs Certification (RAC) April/May EU Exam - Anyone doing it? Professional Certifications and Degrees 10
D Is anyone familiar with doing a DVI (Dossier de Validation Industrielle) for Snecma AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
E Should FDA implement 3rd party (PMAs) reviews? What are the pros and cons of doing so Other US Medical Device Regulations 2
Q Methods for doing Production Process Risk Analysis ISO 14971 - Medical Device Risk Management 4
V Help doing 6sigma Green Belt Professional Certifications and Degrees 6
Anerol C What activities are you doing daily as QMS Coordinator? Career and Occupation Discussions 3
C Setting Up Part Masters in ERP Systems - How are others doing it? Document Control Systems, Procedures, Forms and Templates 1
C Handling Repeated Non-Conformities when doing Layered Process Audits Process Audits and Layered Process Audits 11
A MR (Management Representative) also doing Internal Audits? Internal Auditing 27
J Registrars Doing Synchronized (Combined) Audits to AS9100 and ISO 13485 Registrars and Notified Bodies 8
C Volkswagen Quality System - Is Volkswagen doing anything different? Customer and Company Specific Requirements 1
Marc What are Toyota's idled U.S. workers doing? World News 4
M FOC (3 lots) - First of Code - Are you still doing 3 lots for FOC? Other Medical Device and Orthopedic Related Topics 1
D Greening of Standard Specifications - What is your company/ organization doing Sustainability, Green Initiatives and Ecology 10
S Please tell me how to start doing an FMEA FMEA and Control Plans 6
D Currently doing battle with IT - IT Help Desk procedure wanted Service Industry Specific Topics 5
B 'Doing Quality' - But calling it something else Quality Manager and Management Related Issues 12
ScottK What is LinkedIn doing with the "People you may know" box? After Work and Weekend Discussion Topics 8
