Cl 5.7 Humidity preconditioning required for all Medical Electrical Equipment?
michael Cejnar
Does Cl 5.7 Humidity preconditioning have to be performed on all MEE?
Our CB Certified Ed2 Test Report called Cl. 5.7 as N/A, stating: ?Humidity conditioning was not required under Cl 4.10 of IEC60601-1, as no hydroscopic material was used which would cause a safety hazard.?. Several prior test said the same thing.
A recent external Test Lab review of our internal IEC60601-1 Ed3 delta Test Report disagreed:
"Seldom is it possible to eliminate humidity conditioning prior to leakage current and dielectric testing."
The relevant Ed3 Cl5.7 states:
"Prior to the tests of 8.7.4 and 8.8.3, all ME EQUIPMENT or its parts shall be subjected to a humidity preconditioning treatment."...but then gives an out clause: "This treatment is applied only to those ME EQUIPMENT parts which are influenced by the climatic conditions that are simulated by the test."
So can humidity testing in Cl 5.7 be omitted if there are no parts likely to be affected, as per the Clause and our CB Certificate?
Or has our CB certificate been in error for the past 12 years?
Peter Selvey
I worked for 3 different agencies and frequently used the rationale to skip the hygroscopic test, and there was never any internal problems with reviewer and certification bodies, including in the CB scheme.
But it is an individual judgement call based on experience. I came across certain cases where it the humidity test was important, for example, checking the seal in powder insulated heaters, quality of impregnated paper based insulation used in some older or larger types of transformer, and insulation unknown materials. Having that experience makes it clear that in other cases it's not really important, noting that most modern insulating materials have very low water absorption rates.
If the insulation system is made up of approved (recognized) components like like optocouplers, capacitors, PVC wiring, connectors, then it's also clear the humidity test can be skipped. Most NRTLs allow manufacturers to list "any" or "various" as long as the part is approved and fits the listed specifications. If the humidity test was really important, this practice could not be allowed.
N
NickM
Also, check your particular standards. Some particulars for large fixed medical equipment like MR (-2-33), waive humidity preconditioning. There are a few reasons for this.
1) It is very impractical to try to find a humidity chamber for large ME equipment like an MR system
2) The equipment has tight environmental operating specifications
3) The equipment installation takes days-weeks which would evaporate any potential condensation build up due to transport/storage.
If there is nothing in your particular standards, you need to focus on the statement in -1, which states "This treatment is applied only to those ME EQUIPMENT parts which are influenced by the climatic conditions that are simulated by the test." Couple points regarding this statement:
a) You would need to provide sufficient objective evidence that your equipment is not influenced by test. The hydroscopic argument is valid but is challenging to prove out. You would basically need to list out the raw material of all the insulation in the product and then find water absorption specs on those materials.
b) You don't necessarily need to do conditioning on the entire device, only the "parts which are influenced". Isolation devices would be a good example that need to be considered. If the isolation is provided in a component (i.e., power supply) that has already been certified to 60601 or 60950, there is a possibility that the conditioning was already performed at that component level and you can just show that data.
G IEC 61010 Humidity Preconditioning and Condensation CE Marking (Conformité Européene) / CB Scheme 4
C One Time Service Supplier - Temperature and Humidity Testing Service ISO 13485:2016 - Medical Device Quality Management Systems 5
J ISO 15223-1: Keep dry vs. humidity limitation label symbol Other Medical Device Related Standards 2
Q Weigh Scale Electronics - Suggested Storage Humidity and Temperature Manufacturing and Related Processes 7
S IEC 60601-1 Humidity Precondition Test IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
S Methods to reduce relative humidity in Datacenter IEC 27001 - Information Security Management Systems (ISMS) 3
M Saturated salts issue - Humidity Chamber General Measurement Device and Calibration Topics 5
V Temperature/humidity requirements in internal metrology laboratory General Measurement Device and Calibration Topics 3
N ESD and Humidity Monitoring in Work Areas Manufacturing and Related Processes 1
Ajit Basrur MS Excel to study Correlation between Humidity & Differential Pressure Excel .xls Spreadsheet Templates and Tools 7
M How to Measure Paper considering Variation and Humidity General Measurement Device and Calibration Topics 10
D Sterile Medical Device Temperature and Humidity (Storage) Labeling Requirements EU Medical Device Regulations 5
Ron Rompen Help with Corrosion (Humidity) Testing Procedure - Sintered Metal Steel Parts Manufacturing and Related Processes 9
J Transformer Compliance Testing, overheat then humidity treat, then dielectric test? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
P Humidity Pre-Conditioning before leakage current and dielectric strength tests IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
B Do I need to perform Gage R&R on a Digital Temperature & Humidity Gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
J Relative Humidity and Plastic Raw Material Moisture Manufacturing and Related Processes 4
M Daily Temperature and Humidity Graph template Document Control Systems, Procedures, Forms and Templates 2
A MSA (Measurement Systems Analysis) for Humidity Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Temperature/Humidity inside a store Human Factors and Ergonomics in Engineering 7
M Temperature and Humidity requirements for Raw Material Storage and Quality Labs IATF 16949 - Automotive Quality Systems Standard 13
R 5% to 95% Non-Condensing Humidity Storage Test Conditions and Failure Modes APQP and PPAP 2
D PCBA Lab Temperature & Humidity Requirements - Advice needed Manufacturing and Related Processes 7
H What is the ISO Class 7 cleanroom requirement on Temperature and Humidity ? Manufacturing and Related Processes 3
S ETO ISO 11135-1 & ISO 17665-2 - Purity and Quality of Steam (Humidity) Qualification and Validation (including 21 CFR Part 11) 3
T ISO 2230 (Guidelines for Storage of Rubber Products) - Temperature, Humidity & Light Other ISO and International Standards and European Regulations 8
K Desiccants & Humidity Control inside ocean going Shipping Containers Supplier Quality Assurance and other Supplier Issues 5
T Calibration Laboratory Temperature/Humidity goes out of tolerance due to Power Loss General Measurement Device and Calibration Topics 9
E Humidity Pre-Conditioning IEC 60601-1 (2005) IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
D Buying a Temperature and Humidity Device, and Calibration AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
D Will just Heat and Humidity be Adequate to Simulate EtO Sterilization? Design and Development of Products and Processes 2
R Inspection Humidity Control - Range for Mechanical Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
N Chilled Mirror Dew Point Meter for Humidity Measurement Measurement Uncertainty (MU) 2
R Does Humidity affect Electronic Instrument Calibration? General Measurement Device and Calibration Topics 16
D How to use temperature and humidity environmental control data? Statistical Analysis Tools, Techniques and SPC 18
B Analytical Lab Environmental Condition (Temperature & Humidity Control Limit) General Measurement Device and Calibration Topics 5
G Humidity Problem in our Laboratory General Measurement Device and Calibration Topics 12
S Temperature and Humidity Chamber Verification General Measurement Device and Calibration Topics 5
C Need source for temperature and humidity gage General Measurement Device and Calibration Topics 8
M Temperature/humidity monitoring process procedure Manufacturing and Related Processes 2
N Uncertainty calculations for RH (Relative Humidity) sensors Measurement Uncertainty (MU) 5
N Uncertainty for Humidity Probes - Temperature Effect from 0.5?C dew point = 1.3%rh Measurement Uncertainty (MU) 2
I Temperature and humidity storage requirements? US Food and Drug Administration (FDA) 6
J Controlling Temperature and Humidity in the CMM Room and does anyone use Artifacts? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
K Relative Humidity Requirement on Calibration Certificates General Measurement Device and Calibration Topics 5
E Humidity Requirements for an ISO 7 or ISO 8 Medical Device Cleanroom? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
A Relative Humidity + ISO 9001:2000 Audit of Maintenance Department ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
A Controlling Humidity in a Textile Testing Laboratory General Measurement Device and Calibration Topics 10
D Is Temperature & Humidity monitoring in a Metrology / Test Laboratory required? General Measurement Device and Calibration Topics 28
G What material would you use in extreme humidity and mercury vapor lighting? Various Other Specifications, Standards, and related Requirements 20
