Clamping Force measurement between two component faces?
Hello again after a short break.
I have been asked if it is possible to measure the amount of clamping force between two faces. Currently we assemble using a 10kg load to apply force to the two components to ensure an effective heat transfer path. We would like to move away from this, and need to work out what the clamping force is on the components using our prototype fixture, spring loaded clamps.
I would like my fellow Covers for some input please:
How do I measure the force between the faces when a clamp is applied (as opposed to a weight).
Picture to follow soon...
Thanks in anticipation
Paul
Jerry Eldred
Re: Force measurement between two faces?
The most immediate answer I see is a Load Cell. You can put it in-line to measure compression force. Maybe some of the mechanical experts may have some other better or more detailed thoughts.
Picture attached, the clamping force between the gold bit and the copper bit needs to be measured.
Paul
andygr
Pic did not attach but Jerry has it right.
You are looking at a load cell application( compression) . Just be carefull that you understand their use and application or your results can be very missleading. Alignment being a big influance for example and temperature.
:2cents:
DavidPhillips
It would be good to know a little more about your application but some of our customers have used a small 50kg testing machine to apply clamping (compression) forces very accurately and in good alignment using a high quality load cell. Its not the cheapest solution but it will work very well, and there are other benefits as well if you want to use this in a production environment.
Another advantage is that rather than simply measuring the applied force you can actually set it on the machine so you can experiment with different clamping forces to find the optimum value for your assembly.
Contact me for more information, and I can send you some pictures.
I see that you are in South Wales, we are in Herefordshire so that may also be an advantage.
David Phillips
E Flatness Measurement of Plastic Molded Parts - Clamping / Holding Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
K Why does load cell supplier requires force verification General Measurement Device and Calibration Topics 3
D Compression Spring Force MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
N Requirements for the identification and traceability of demo product for sales force US Food and Drug Administration (FDA) 1
J Calculating impact force, expressed in lbs, of a 5 lb weight dropped 48 inches Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K Measurement Force on Kickdown Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Compression Spring Force measurement correlation with Supplier Capability, Accuracy and Stability - Processes, Machines, etc. 7
J GHTF (Global Harmonization Task Force) SG2 Guidance Documents EU Medical Device Regulations 3
B Kanban - What is the pulling force which triggers replenishment? Lean in Manufacturing and Service Industries 7
V How to Calibrate Ring Force Gauges Service Industry Specific Topics 1
kedarg6500 How much test force to be applied for Vickers hardness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S IATF (International Automotive Task Force) Rules 4th edition changes IATF 16949 - Automotive Quality Systems Standard 1
Z Force & Strain Calibration Uncertainty for ISO/IEC 17025 ISO 17025 related Discussions 2
W Force Calibration - In-House Load Cell Calibration General Measurement Device and Calibration Topics 7
D Force Testing Round Pieces that are Twisted Together Manufacturing and Related Processes 9
Jen Kirley My son leaves for the Air Force today Coffee Break and Water Cooler Discussions 30
V Medical Device Definitions outside GHTF (Global Harmonization Task Force) Other Medical Device Regulations World-Wide 2
P GHTF's (Global Harmonization Task Force) Latest ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 5
M Rules for achieving IATF (International Automotive Task Force) recognition IATF 16949 - Automotive Quality Systems Standard 1
S Customers an Extension of the Sales Force? Customer Specific Marketing Material Quality Manager and Management Related Issues 3
D Effect of Puncture Orientation on Force Value Other Medical Device Related Standards 1
S End of GHTF (Global Harmonisation Task Force) Other Medical Device and Orthopedic Related Topics 8
M GHTF (Global Harmonization Task Force) "Archived" Document question EU Medical Device Regulations 3
M Protocol for Validating Pull Tester and Force Gage Qualification and Validation (including 21 CFR Part 11) 9
S 3 Wire Pitch Dia. Method - Measuring Force Correction & Lechowski?s method General Measurement Device and Calibration Topics 1
Ajit Basrur GHTF (Global Harmonization Task Force) release 2 final documents Other Medical Device Regulations World-Wide 2
xcanals_tecno-med.es MDD 93/42 as amended by dir 2007/47 in force next week (21 mars) EU Medical Device Regulations 2
D Coronary Stent Retention (dislodgement) Force Value - ASTM F2394-07 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Ajit Basrur Proposed documents from GHTF (Global Harmonization Task Force) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Ergonomics - Human Hand - Maximum force - Wheel/Flywheel - Help ASAP :) Human Factors and Ergonomics in Engineering 8
C NO-Go Plug Gage Force General Measurement Device and Calibration Topics 3
P New IATF (International Automotive Task Force) Communiqu ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 0
Y Measurement of Force (Newtons) generated General Measurement Device and Calibration Topics 9
C Tales from the RAF (Royal Air Force, UK). Funny Stuff - Jokes and Humour 23
chris1price Sterile Pouch Peel Force of 1 pound/inch width Other Medical Device Related Standards 10
Howard Atkins New IATF (International Automotive Task Force) web site IATF 16949 - Automotive Quality Systems Standard 26
P Force Testing Instrumentation Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Ajit Basrur GHTF (Global Harmonisation Task Force) - Guidelines for Regulatory Auditing ISO 13485:2016 - Medical Device Quality Management Systems 0
C Torque specification for setting thread rings vs. "Finger Force" and "Snug" General Measurement Device and Calibration Topics 10
R Process Control - Force in compression moulding of rubber keypads Capability, Accuracy and Stability - Processes, Machines, etc. 5
P Automotive Safety Glass Strength - Amount of Force to Shatter Safety Glass Human Factors and Ergonomics in Engineering 7
J Sales Force (Catalogue) says We are TS16949 Certified - Is this allowed? IATF 16949 - Automotive Quality Systems Standard 2
S Standards for force controller-Joystick - Bucket lift controllers Human Factors and Ergonomics in Engineering 0
C Calibration Standards and Typical Accuracy Requirements for Force Gauges General Measurement Device and Calibration Topics 3
Marc Hacker Hunters - An elite force takes on the dark side of computing After Work and Weekend Discussion Topics 0
D Ethical Question - Generate a Corrective Action to force a response and action Philosophy, Gurus, Innovation and Evolution 15
R GR&R (Gage R&R) study on Minimum Force requirement Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
W Skewed data analysis - Insertion force test Statistical Analysis Tools, Techniques and SPC 3
S Rockwell Force Testing vs. ASTM E-18 (02 version) General Measurement Device and Calibration Topics 6
A Procedure on how to conduct a Destructive MSA (Gage R&R) for Force Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
