Clamps in checking fixtures used to drive datum features.
O
OmarEn
Hi guys,
I have a question, hopefully, you could help me:
In our checking fixtures, when we have any part surface called out as datum feature or datum target, we used to install clamps at the opposite side to push the surface against its counterpart in the gage and have maximum possible contact. But one customer has been questioning about these clamps arguing that they force the part to be in-tolerance, and they should be removed.
I have seen this made this way from years in different companies, but I cannot find where in the Y.14.5 Standard states that the use of these clams. Could you guys please help me with this Issue?
Thanks in advance!
Stijloor
Hi guys,
I have seen this made this way from years in different companies, but I cannot find where in the Y.14.5 Standard states that the use of these clamps. Could you guys please help me with this Issue?
Thanks in advance!
There is a general dimensioning rule in ASME Y14.5-2009 [(Page 8 (m)] that states that all dimensions apply in a free-state condition. However, if it's necessary to inspect the part in a fixture (datum target simulators in your case), then a restraint note must be placed on the engineering drawing. The restraint requirements are on Page 79, Par 4.20 and an example in Fig 4-42 on page 81. There must be a note and a possible separate instruction on how and with what force (torque) the part must be restrained.
Hope this clarifies.
O
OmarEn
Thank you guys, excellent answers.
These drawings do not have such restraint notation. Therefore my part is considered rigid.
I think I can not make anything to solve this Issue and give an answer to my customer that can help me.
Bruser
A question is how is the part used? is it restrained in any way when in the "in use" position? is it a sub-component of another assembly that is clamped together in assembly?
an alternative to hard clamping is using spring loaded clamps that provide a fixed amount of pressure on the part, this eliminates putting "extra" pressure on the part to make it conform to the fixture, only applying enough pressure to keep the part from slipping.
C Inspection of clamps Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
R Through-Hole Electronics - Checking Lead Length Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
G Supplier Checking With Gauge Pin Problem Solving, Root Cause Fault and Failure Analysis 2
B Design of fixture checking including Position of hole and slot General Measurement Device and Calibration Topics 5
S Checking status of Medical device Other Medical Device and Orthopedic Related Topics 2
KyloDen Checking Threads - Discrepancy in threads that are machined In-House vs. Outsourced General Measurement Device and Calibration Topics 11
P Checking flatness with Go and No Go Jig Manufacturing and Related Processes 2
M Checking Fixture for Stamping Parts Manufacturing and Related Processes 2
F Checking Gages In and Out and Verifying Calibration Status Calibration and Metrology Software and Hardware 8
R Weight Sets for Checking Table Balances Quality Assurance and Compliance Software Tools and Solutions 5
E Methods in Measuring Angles or Checking Angles for tools? General Measurement Device and Calibration Topics 10
E PPAP Checking aids, what to do exactly? APQP and PPAP 5
N Survey about Attribute Gage and Sight Checking R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
V Checking for Oversize Hole - Dimensioning question APQP and PPAP 7
J Micro Tubing Concentricity Checking using Crosshairs Manufacturing and Related Processes 1
F Checking runout in reference to 2 datums Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
F Besides using the CMM - Checking perpendicularity between a plane and an OD Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L GD&T Bonus Tolerance - Checking True Position of a Pierced Hole Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
C Checking True Position with Pin Gage Measurement Uncertainty (MU) 3
D Checking my organization's current Quality Policy Quality Manager and Management Related Issues 9
J Checking Variance/Normality of my two Samples (question) Using Minitab Software 2
F Calibration Reports for Wood Checking Fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
K Verification, Validation or Checking? Definition of the word "Checked" Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
Z Error of 30 microns checking a Ring Gauge on a CMM Machine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
D Laser Micrometer for checking Thickness of Steel - Any Recommendations or Comments General Measurement Device and Calibration Topics 3
K True Position Checking such as Bolt Hole Position w.r.t Center Bore on Wheels Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
A Can we reduce documents checking percentage on supplier certificates? Supplier Quality Assurance and other Supplier Issues 3
J Checking the Theoretical Sharp of a Flush Head Bolt on an Optical Comparator Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Inspection Equipment for Checking Serrated Steel Tubing Depths Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
D Checking Rib Thickness on a Part and Necessary Process Controls Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
D Checking the Homogeneity of the Variance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Ajit Basrur Checking in on Saturn - Good pictures ! Coffee Break and Water Cooler Discussions 0
T AQL Difference in Checking LCD Pins AQL - Acceptable Quality Level 4
G Dispute - Checking a thin walled, round, hollow part with micrometer Inspection, Prints (Drawings), Testing, Sampling and Related Topics 25
L PPAP List Requirements - Molds, Tools or the Checking Tools? APQP and PPAP 5
D Good source for Checking and Evaluating Control Plans needed FMEA and Control Plans 4
J Surprise - And Hello - Just Checking In Coffee Break and Water Cooler Discussions 20
A Optical Magnification Checking Graticule - Starrett 400-360 (P-10089) General Measurement Device and Calibration Topics 2
S Go/No-go Length Gauges - Length checking of beam assemblies General Measurement Device and Calibration Topics 2
J Why control of records in checking section? Miscellaneous Environmental Standards and EMS Related Discussions 3
M Checking a male taper using a female air gage fixture - Air Gaging question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
Jim Wynne Virus Hoaxes or, What Ever Happened to Fact-Checking? After Work and Weekend Discussion Topics 5
R Checking (Calibrating) Truncated Thread Set Plugs General Measurement Device and Calibration Topics 11
J Checking work question - How do you check your work? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Tolerance Stacking or Tolerance Chart - Checking manufacturing print tolerances Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A Checking Profile Tolerance on CMM's Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
C How long does it take to clear back ground checking? Career and Occupation Discussions 7
T Checking Contractors for Charity Organisation Service Industry Specific Topics 5
L Asking for AQL for checking 5 liters can AQL - Acceptable Quality Level 5
Y PFMEA detection value for checking C of C in receiving inspection FMEA and Control Plans 2
