Clarification on Document Signatories under ISO9001
E
esqchem
I now work in cosmetics manufacturing and under me is the document center. The documents in my perception are quite tight. The individual who previous handled the section patterned their docs under ISO9001. However, the company follows more on the GMP.
I am trying to lessen their documentation and wanted to start with the basic----their control of document specifically signatories. All quality procedures follow this sequence at the bottom:
a. Prepared by/Originator
b. Reviewed by 2 (Originator (Department) Supervisor or next in line position and a QMR)
c. Department Head/Manager
The thing is, this is the first time I encountered review by a QMR before signature of the department head. QMR is not one appointed person but several in each department. When I asked why its presence, the QMR is the only one who checks formatting and grammars per se. They told me that the previous individual who handled their documentation who had been in a known electonics ISO company told them that QMR's signature is required based on ISO9001 standard.
I had been in an international TS16949 company and ISO9001 service industry but never had this sequencing in signatories. Our QMR and only the director of Quality only signs the Document Request form but never ALL standard operating procedure.
I told them that those checkings are responsibility of the originating department's reviewer.
A. Can somebody really define where should the QMR sign? What does ISO9001 says because it might be an expanded topic. I might be missing something.
B. Repeating, this is more of GMP environment rather than ISO9001. Only patterned under ISO9001 by the previous handler. Is there anything in GMP saying this?
C. Finally, probably off topic but can anyone point me where GMP/FDA discussion of drugs and cosmetics is more detailed or I can also ask here?
Thanks.
P
PaulJSmith
ISO 9001:2008 Clause 4.2.3 Control of Documents states that you must establish a documented procedure to define the controls needed:
"a) to approve documents for adequacy prior to issue,"
As with pretty much all of that standard, it tells you what you must do, but not how to do it. There is no requirement for signatures in the standard. That would be governed by your own internal procedure.
As for the medical devices parts, I'll have to leave that to someone in that field.
yodon
PaulJSmith gave good advise and it's just as relevant for GMP. Regarding your question below:
I presume you mean with respect to document control / approvals. Here's where you can find that discussion: http://www.accessdata.fda.gov/scrip...Part=820&showFR=1&subpartNode=21:8.0.1.1.12.4
As you can see, very much in line with what PaulJSmith stated.
Hope that helps.
S 21 CFR Part 820.40(b) Clarification on Required Document Approvers 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
Chennaiite Controlled vs. Uncontrolled Document - Clarification requested IATF 16949 - Automotive Quality Systems Standard 11
L Stage One Audit vs. Document Review - TS16949 - Need clarification IATF 16949 - Automotive Quality Systems Standard 5
qualprod D5 of 8D clarification, how to verify root cause Problem Solving, Root Cause Fault and Failure Analysis 24
K IPC-610 Section 10.4.2.2 clarification - Distance to be measured Various Other Specifications, Standards, and related Requirements 0
M Off-Label Use - Clarification of FDA Policy US Food and Drug Administration (FDA) 1
T Implant Card - Article 18.1(a) and MDCG 2019-8 clarification EU Medical Device Regulations 3
Q Need clarification on requirements.... Class i, gmp & 510(k) exempt Medical Device and FDA Regulations and Standards News 12
M Informational TGA Consultation: Proposed clarification of the regulatory requirements for medical device systems and procedure packs Medical Device and FDA Regulations and Standards News 2
R ASQ reference material clarification - Spiral bound materials allowed in ASQ Exam? Professional Certifications and Degrees 1
Q ISO 3310 Clarification Help - Aperture sizes for sieves used for particle sorting Other ISO and International Standards and European Regulations 2
S The Severity of a Medical Device Hazard - Risk Analysis Clarification ISO 14971 - Medical Device Risk Management 6
M 8.3.2.3 Development of products with embedded software - request for clarification IATF 16949 - Automotive Quality Systems Standard 1
M FDA News USFDA Draft Guidance – Clarification of Radiation Control Regulations for Manufacturers of Diagnostic X-Ray Equipment Medical Device and FDA Regulations and Standards News 0
T Clarification on MDR - Article 18(d) - Implant Card EU Medical Device Regulations 14
S QS, RS deflection - clarification wanted IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
A ISO 2859 Single Sampling - Clarification regarding the sampling table Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Requirements for Interval Measurement test & Frequency Response test clarification IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
S Clarification regarding tests in IEC 60601-2-25 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
J Internal Audit clarification - How to perform the audits IATF 16949 - Automotive Quality Systems Standard 6
V Clarification - Hydrogen De-embrittlement Manufacturing and Related Processes 6
K UDI Direct Marking Compliance Date Clarification and one other UDI question Other US Medical Device Regulations 0
N Applied Parts Classification Clarification - Breast Pump IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
V Clarification of Injection part shrinkage ratio Manufacturing and Related Processes 1
J ISO 9001:2015 8.2.3 - Review of Requirements (Clarification on compliance) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
B Health Canada Recall Definition - Seeking Clarification Canada Medical Device Regulations 5
Q ISO 9001:2015 - Clarification in 6.1.2 Note 1 (Options to Address Risks) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Clarification of threaded ring gage calibration procedure/requirements General Measurement Device and Calibration Topics 2
M Clarification on Calibration/Verification Records 7.1.5.2.1d (IATF 16949) General Measurement Device and Calibration Topics 11
B Clarification on interpretation of some EN ISO 14971:2012 & IEC 62304:2006 req's ISO 14971 - Medical Device Risk Management 46
S AS9102 - Clarification - PO asking for an Assembly at Rev B (Print at Rev C) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Pmarszal Clarification for 21 CFR Part 11.100 - General Requirements Other US Medical Device Regulations 14
B Clarification of ISO 9001:2015 Clause 8.5.6 Control of Changes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
M Integrated Phased Processes - AS9100D cl. 8.1 Operational Planning - Clarification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
A Monitoring and Measuring Resources (7.1.5) - Clarification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
dubrizo Clarification Requested in 6.2.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
F TS 16949 Clause 7.2.1 - Note 2 - Recycling program - Clarification IATF 16949 - Automotive Quality Systems Standard 4
K EN ISO 15223-1:2012 Clarification or Examples on when to use Safety Symbols Other Medical Device Related Standards 3
S Clarification regarding types of processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D Clarification of Applicability of TS 16949 Requirements to a Non-Automotive Business IATF 16949 - Automotive Quality Systems Standard 13
M Request for clarification on TS 16949 Clause 5.6.1.1 IATF 16949 - Automotive Quality Systems Standard 5
Q Configuration management clarification and example AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S Clarification in organizing required documents for ISO 27001 IEC 27001 - Information Security Management Systems (ISMS) 6
J Definition Actively Manufacturing - ISO 13485 Definition and clarification Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 8
T Early Research & Development - ISO 13485:2003 requirements Clarification ISO 13485:2016 - Medical Device Quality Management Systems 34
B Detachable Power Supply Cable Connection ESD Clarification IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
D NIST HDBK 44 Table T.3. Class III Tolerance in Divisions Clarification General Measurement Device and Calibration Topics 4
M UDI - Direct Marking and Reprocessing Clarification Other US Medical Device Regulations 12
P ISO 27001:2013 Clause 4.1 and 4.2 Clarification and Guidance IEC 27001 - Information Security Management Systems (ISMS) 13
C Positional Tolerance - Bonus / Datum Shift / ASME Y14.5M - Clarification Various Other Specifications, Standards, and related Requirements 9
