Clarifications on Lists, Logs and Registers
sharat_m
Hi All,
We are a small software company with staff strength of 20. We are now getting prepared to be ISO 9001:2000 Certified by end of November. I was going through the topics in this forum and found them interesting. My interest is to know which of the following is a document, a record or none:
* Master list of Quality Documents - contains the list of controlled documents
* Master list of Quality Records - contains the list of controlled records.
* Task tracking sheet - contains the list of tasks in the project
* Test case Review log - contains the list of test cases documents and their review dates.
* Facility Service log - contains the service requests for various facilities in the office.
Thanks in advance for the time spent to understand my question and answering it.
Sharat .M
SteelWoman
Remember, to some extent at least, YOU get to decide the measure of control you exercise over documents. TS wants you to "establish criteria" for that control, which should of course be appropriate to your facility/operation. YOU decide what needs to be controlled, doesn't need to be in order for your quality system to operate effectively. Fer' instance: we define in our document control procedure that normally LOGS are not controlled documents here. We decided that on the basis of how the few logs we use are utilized AND based on our "criteria statement" for deciding whether or not a document should be controlled. But I know in some organizations logs are used differently, and their mis-use or "non-controlled" status would be problematic.
Bottom line: What makes sense for YOU?
Hello Sharat, and welcome to the Cove. :bigwave:
Here is my take:
* Master list of Quality Documents - contains the list of controlled documents -Record.
* Master list of Quality Records - contains the list of controlled records. -Record
* Task tracking sheet - contains the list of tasks in the project - Record
* Test case Review log - contains the list of test cases documents and their review dates. -Record
* Facility Service log - contains the service requests for various facilities in the office. - Record
Steel provided good advice. pay attantion to what she said.
Another thing: Considering what you do for a living I suppose a computer based system would be nice?
/Claes
Added later: Sharat, Since you're going for ISO 9001 I moved this thread to the ISO900X forum. I think you'll get more answers that way.
Cari Spears
SteelWoman said:
...Fer' instance: we define in our document control procedure that normally LOGS are not controlled documents here. We decided that on the basis of how the few logs we use are utilized AND based on our "criteria statement" for deciding whether or not a document should be controlled. But I know in some organizations logs are used differently, and their mis-use or "non-controlled" status would be problematic.
Good example - we decided to control our log books as records (they are included in our Record Retention List) because they are critical records - especially in the repair end of our business. In addition - a current customer of ours requires us to retain an EDI log in sheet of their RFQ's and retain for one year.
tracey
The way I look at it, a document that has not been filled out = a doucument; once it has been completed and information recorded on it, it is now a record. JMHO :)
howste
Thaumaturge
My take is a little different than that of Claes. Since the master lists of documents and records will be revised from time to time (as you add or change revisions), I would call them a document. Logs are a history, so they would be a record. For the task tracking sheet, I'm not sure. What is it used for? If it is subject to revision, and/or is used to provide instructions, I would call it a document. If it just shows what happened, it would be a record.
* Master list of Quality Documents - document
* Master list of Quality Records - document
* Task tracking sheet - ??????
* Test case Review log - record
* Facility Service log - record
Douglas E. Purdy
Similar to Howste
Sharat M.,
I pretty much go along with Howste, but if the log is purely a management tool to know what is happening with the records, then it is not necessarily a record.
doug
Wes Bucey
First a statement:
Records are merely a special form of document, not normally subject to revision because they represent the RECORD (history) of activities.
I agree with Howste to the extent that the two items he lists as documents because they are subject to revision is a fair statement. The last three items are records in my opinion, with this provision:
"as new or additional data is added to a record, it becomes a new record and the old (previous) one is obsolete and should be discarded if it is a paper printout."
Compare this concept to a continuing inspection log on a part which tracks inspections over the entire production period.
  1. Do we make a new revision of the log each time a new set of inspection results is added? (probably not.)
  2. Is a copy of yesterday's log valid if new info has been added today? (probably not and should be discarded.)
In essence, the date of the last entry in the log takes the place of the involved process of creating a new revision with checks and approvals normally required in a document control system.
Wes Bucey
I'm not sure I was clear in the "discard" aspect of my post. I referred only to the "copy" of the previous date of the record. In the case of computer entry, the previous material remains, course, as the history of what happened. In a machine shop, for example, the inspection record may be maintained on one sheet of paper, adding new entries at every inspection. Copies of the record through a certain date may have been made for different purposes. Once the new data is added to the record, the previously made copies are obsolete and may be discarded.
RoxaneB
sharat_m said:
Hi All,
Sharat .M
Like Claes pointed out, looking at your industry, what kind of document control system do you have? Is it primarily electronic? But here's my take...
At my organization, our Document Control System is the list Master List of Documents. Controlled documents from external sources and controlled software have their lists maintain via a document (i.e, a work instruction) - listing name, rev#/date, location, person responsible for maintaining it. The Document Control System software can be found on the controlled software listing.
Within our Document Control System, there is a Records List module. Again, cound on the controlled software listing.
Task tracking sheet, Test case Review log, & Facility Service log
While blank, it a document called a form. Once there is data on it, it becomes a record.
Sidney Vianna Informational New IAQG Document - AS9100 Clarifications of Intent AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M Clarifications needed about WIP (Work In Process) and about Inspection Lean in Manufacturing and Service Industries 12
M TS 16949 clause 8.5.2 - Corrective Action - Need to some clarifications IATF 16949 - Automotive Quality Systems Standard 4
V Achieving ISO/TS 16949 "Compliance" - Miscellaneous clarifications needed... IATF 16949 - Automotive Quality Systems Standard 9
Sidney Vianna IAQG AS9100 Rev. C Clarifications Document now available AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
Sidney Vianna AS9100 Rev. B - The IAQG has made available a clarifications document AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
R ISO 9001:2008 Clause Interpretations and Clarifications ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
M Bullet Points vs Numbered lists Document Control Systems, Procedures, Forms and Templates 11
N Database that lists labs accredited to ASTM / ANSI standards Various Other Specifications, Standards, and related Requirements 6
M CAAC-145 Manuals - Looking for examples of MOM's, MMM's Capability Lists, etc. Federal Aviation Administration (FAA) Standards and Requirements 13
T Parts Lists - Use of the word "off" against Quantity Coffee Break and Water Cooler Discussions 2
D Medical Devices technical lists for Germany, Austria, Sweden, Switzerland, etc. EU Medical Device Regulations 2
M Types of Controlled Documentation - Call Lists of Emergency Contacts Quality Manager and Management Related Issues 5
C Log Files (Training, CAPA, Complaint, for example) & Lists in QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
R FDA no longer lists Medical Device Proprietary Names Other US Medical Device Regulations 5
Sam Lazzara Updated Europe Harmonised Standards Lists (2012-08-30) EU Medical Device Regulations 3
R Registers and Master Lists - Differences ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q APQP Compliance Internal Audit - Ideas, check lists or main questions to prepare APQP and PPAP 9
K What types of charts, lists, views do you like regarding FMEA results? FMEA and Control Plans 7
E Process Audit Timetables and Check Lists - Medical Device Industry (ISO 13485) Process Audits and Layered Process Audits 7
Q Internal Audit Check Lists for GM, Ford, and DCX (TS Specifics) IATF 16949 - Automotive Quality Systems Standard 5
R Website that lists Certified ISO13485 Registrars ISO 13485:2016 - Medical Device Quality Management Systems 5
V Process Based Organization Chart that lists processes instead of departments? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
C Control of Document and Form Master Lists Document Control Systems, Procedures, Forms and Templates 9
K Tool crib clerk inventories Perishable Tooling - Part Number Tool Lists - Auditable? General Auditing Discussions 2
B GM DDW Self-Assesment and GM DDW Audit forms / check-lists Customer and Company Specific Requirements 5
B Internal Audits - Changing from Check Lists to Process Approach Internal Auditing 13
N Do Document Master Lists need a Form Number Document Control Systems, Procedures, Forms and Templates 4
S Control of Price Lists and Marketing Brochures Document Control Systems, Procedures, Forms and Templates 12
C ISO 9001:2000 Internal Auditor System and Preparation - Schedule, Check Lists, etc. Internal Auditing 57
A Use of Terminology - Difference between NC, deficiency, punch lists, etc. Document Control Systems, Procedures, Forms and Templates 4
Marc Control of Price Lists Document Control Systems, Procedures, Forms and Templates 3
M I have two Approved Supplier Lists - Hard Copy vs. Electronic Supplier Quality Assurance and other Supplier Issues 7
G Inspection Logs - Asked to remove an Inspection Sheet ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D How do I go about creating document logs and registers with the MS Excel Excel .xls Spreadsheet Templates and Tools 2
B M&TE (Measurement and Test Equipment) Usage Records (Logs) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
W Internal Audit Non Conformance Tracking Logs and NC Systems ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
N Customer Property Logs - Tracking customer property, specifically production tooling IATF 16949 - Automotive Quality Systems Standard 5
P Question in auditing regarding CAR (Corrective Action) Logs Internal Auditing 7
T Implementing Defect Logs into my existing Non-conformance procedure Nonconformance and Corrective Action 4
D Scrap Logs - Do Scrap Logs have to have a document number? Records and Data - Quality, Legal and Other Evidence 27
T Supplier and Customer Survey (including Logs) Ideas and Examples wanted ISO 13485:2016 - Medical Device Quality Management Systems 3
L Audit Logs - What do you do when registrars ask for them? General Auditing Discussions 10
L LOGS - Record or Document? How to control logs? Document Control Systems, Procedures, Forms and Templates 10
M Training Documentation - Control of Signed Training Documents e.g. Training Logs Training - Internal, External, Online and Distance Learning 10
a_bardi Help me define way of control electronic data files - Logs, etc Records and Data - Quality, Legal and Other Evidence 3
Marc Control of Laboratory Notebooks and Logs Document Control Systems, Procedures, Forms and Templates 0
