Clarifying FDA definition of "finished device" and “capable of functioning”
outdoorsNW
We are an electronics contract mfg., high mix, low volume. We are looking at targeting medical electronics companies. We are at an early stage and am trying to determine where we may need to hire outside experts and what we should avoid until we have a better understanding of the requirements.
For the moment I think we should avoid producing “finished medical devices” because of the added regulatory requirements. However the definition of what is a finished medical device leaves room for interpretation.
From the FDA regulations: “820.3 Definitions. (l) Finished device means any device or accessory to any device that is suitable for use or capable of functioning, whether or not it is packaged, labeled, or sterilized.” [Emphasis added]
How is “capable of functioning” defined?
When I searched both the web and elsmar, I did not find anything clarifying this.
For instance, with an electronic item, the device may have been fully assembled but not tested. If you have a good customer design and a good manufacturing process, an untested device usually will be fully functional. If the design responsible customer is responsible for final testing, is this considered “capable of functioning” when we send it to our customer?
What if the scenario changes and the device needs calibration or some other setup before use, but may function with reduced performance, such as reduced accuracy?
monoj mon
Let me give you a simple example. Suppose you manufacture a suction liner which is suitable as an accessory to any manual or electronic suction device. If you manufacture every single component of the suction liner and assemble it at your facility, it will be considered as the finished device. Because, in that form anyone can use your suction liner to fit it with any type of suction device. However, if you just manufacture the fluid containing part while rest of the parts (such as the lid, tubing etc.) are manufactured by some one else and all the components are sent to your client's company for assembly then none of the third party manufacturers are considered to be manufacturing a "Finished Device" as the individual components can not be used by anyone as a "Device".
In your case, as you have said, you fully assemble the device. That means, anyone can pick your product and attempt to use it as a "Device" (refer to the FDA's definition of device) which would mean that your device is "Capable of functioning".
No, that is not what it means by "capable of functioning". It means, the product can be used as intended even though it fail and harm the patient.
Exactly, if anyone can pick your device and perform the intended use even though with reduced accuracy or failure, still your device will be considered "capable of function".
This is why, it is important for the third party manufacturer of "finished device" to register and list the device with the FDA. Registration and Listing will make FDA aware of your existence and ultimately your facility will be inspected in the future.
M FDA News FDA Releases Draft Guidance Clarifying Application of ISO 10993-1 Biocompatibility Standard Medical Device and FDA Regulations and Standards News 0
M Clarifying the many different Medical Device national and international standards Other Medical Device Related Standards 4
L FDA & 21 CFR Part 11 Medical Device and FDA Regulations and Standards News 19
B A.I diagnostic software is considered as medical device in FDA? US Food and Drug Administration (FDA) 5
Ed Panek 2020 FDA Top Ten Observations 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M FDA Requirements for Investigational Devices - Clinical Investigation & Shipping Medical Device and FDA Regulations and Standards News 0
Ed Panek Does this FDA Requirement Apply to international (not USA) distributors for USA based manufacturing companies? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
B FDA Breakthrough Device can be overlapped with a designated device? US Food and Drug Administration (FDA) 6
pbojsen ISO 13485 Requirements versus FDA product classification and GMP exemptions - Audits ISO 13485:2016 - Medical Device Quality Management Systems 3
S Examples of FDA acceptable Software Design Specification (SDS) Medical Device and FDA Regulations and Standards News 6
F Labelling to comply with both FDA and MDR US Food and Drug Administration (FDA) 6
Watchcat FDA vs NB Fees? Other US Medical Device Regulations 7
K FDA Registration and listing weird situation Medical Device and FDA Regulations and Standards News 4
D FDA Guidance on Computer Software Assurance versus 21 CFR Part 11 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
G Does FDA allows remote approvals of quality documentation. Is there any specific guidance on signing any quality records remotely? Document Control Systems, Procedures, Forms and Templates 1
B Does FDA Registration QSR need to cover non-medical devices for contract repackager? US Food and Drug Administration (FDA) 1
S Transitional Adolescent A and B - "CDRH PREMARKET REVIEW SUBMISSION COVER SHEET FORM FDA 3514" Medical Device and FDA Regulations and Standards News 1
P MSDS for MVQ FDA White, Vinyl Methyl Silicone Rubber EU Medical Device Regulations 4
C RA (Regulatory Assurance) Training (FDA) looking for resources Training - Internal, External, Online and Distance Learning 5
E FDA 513(g) Cover Letter US Food and Drug Administration (FDA) 5
S Records - Do's and don't' of record entries (FDA - 21 CFR 820) Records and Data - Quality, Legal and Other Evidence 13
B New Facility register with FDA Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 4
J FDA regulation on decorative contact lenses Medical Device and FDA Regulations and Standards News 5
P Anyone have an Idea on UAE Medical device registeration- Class B with FDA only Other Medical Device Regulations World-Wide 0
F FDA classification for a mobile app Medical Information Technology, Medical Software and Health Informatics 3
Ed Panek IFU Contact Requirements - FDA and MDD/MDR US Food and Drug Administration (FDA) 1
O Any info on release date of FDA “Computer Software Assurance for Manufacturing and Quality System Software” document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
P Writing a presubmission to the FDA prior to the De novo submission US Food and Drug Administration (FDA) 4
K FDA - Can we have more than 1 Initial Importer Medical Device and FDA Regulations and Standards News 4
K Two FDA questions regarding UDI (and potentially 803.52 MDR) Other US Medical Device Regulations 0
R Importers - For the FDA Registration/ Listing, is the CMO the importer? Medical Device and FDA Regulations and Standards News 6
Z Iterative development and FDA change requests IEC 62304 - Medical Device Software Life Cycle Processes 13
P FDA Approved Product Contact Parts ISO 13485:2016 - Medical Device Quality Management Systems 6
A FDA guidance on non-sterile Medical Device Packaging Medical Device and FDA Regulations and Standards News 7
JoCam FDA Registration for Sub-contract manufacturers Medical Device and FDA Regulations and Standards News 2
E Contract manufacturer FDA requirements foreign company US Food and Drug Administration (FDA) 6
P Choice of FDA reviewer US Food and Drug Administration (FDA) 6
J Is Device Tracking Card an actual requirement under FDA regulation? Other US Medical Device Regulations 0
T Definition Human Use (FDA) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 7
K FDA 510k electrosurgery 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
