Class I non-sterile, non-measuring: Requirements fulfiled?
mr.mike
Hi Everyone,
Could use a bit of guidance regarding the sale of a Class I, non-sterile, non-measuring device in Europe.
Our company has the following:
- CE marking (with a CB test-report)
- A completed Technical File for the device
- We meet the Essential Requirements for our device as per MDD Annex I
What I'd like to clarify is the following:
- Do we need a Notified Body? (given Class I non-sterile, non-measuring). As far as I gather, we do not. However, according to section 3.1 of Annex II, we must lodge an application for Quality System assessment with a NB?
- I presume that our next step is a EC Declaration of Conformity? Does anyone have a link to a good guideline for drawing up such a document? Also, when completed, where does this declaration document get submitted?
- Are there additional regional requirements? For example, is registration with the MHRA necessary to sell in the UK?
- Also, probably relevant is the fact that we are NOT based in Europe. Does this impose any additional requirements?
Finally, I'm confused by the term "Competent Authority" which is used often in the MDD. Is this an additional service we will have to pay for?
I know this is a lot of questions, and please forgive me if I've overlooked anything obvious. Any links, guidelines, or references to relevant threads is greatly appreciated.
Thanks in advance,
MM.
Peter Selvey
Hi Mr. Mike,
First of all, although a little confusing the MDD is much more "readable" than most regulations, so just keep trying and it will start to make sense.
Under Article 11, you will find links between the Class of the device and the Annexes II ~ VII which outline declaration of conformity, required documents and notified body involvement. For a Class I, non-sterile, non-measurement device, the link is only to Annex VII (see Article 11, paragraph 5).
Annex VII is a self declaration and does not need notified body involvement, nor a quality system. The only need is to draw up the technical documents as outlined in that Annex.
Officially the format of the declaration of conformity should follow EN ISO/IEC 17050-1:2004, but as there some quirks with the MDD I recommend to search this forum for links to examples that I have seen before. One quirk is the declaration should refer to the "national transposition" of the medical device directive, another problem is that there are many standards for medical devices (not only IEC 60601-1) so best to link to a separate document in the technical file that lists all the applied standards including edition and amendments.
The competent authorities supervise the whole regulation. Generally you do not need to get involved with them unless there are incidents, or clinical trials or other serious matters, with the exception of registration under Article 14.
So, I recommend to read Article 11, 14 and Annex VII and then come back with more questions.
Ronen E
Problem Solver
Moderator
Hi Everyone,
Thanks in advance,
MM.
Hello and welcome to the cove :bigwave:
- For class I non-sterile non-measuring annex VII suffices, and annex II can be ignored. No need for NB.
- You can find good references for an EC DoC all over the web and probably in past threads here; anyway, the MDD is quite straightforward on this issue and if you follow its requirements your DoC will be fine. Once you have complied with the essential requirements and compiled the technical file, you should engage with an "EC representative" (see below), draw your EC DoC and submit it to your EC rep for registration with a competent authority.
- Class I devices need be registered with only one EC competent authority (could be MHRA but not necessarily). Such registration applies to the whole EC. The only exception I know is Italy, look for past threads here on this matter. Once you have engaged with one, your EC rep will apply for registration with the competent authority (typically the ministry of health) of their own member state. Please note you have to meet all applicable language (translation) requirements for the states your product will be distributed in.
- Being located outside the EC, you have to engage with an Authorized Representative ("EC rep"), which has an official place of business inside the EC. This representative will handle registration with the competent authority, and will also serve as the primary point of contact for the EC authorities, in case they have any concerns regarding your product.
Good luck,
Ronen.
SilverHawk
It is now a requirement that your organization have to appointed an Authorized European Representative to list your Class I product. You may contact Obelis Belgium Email : [email protected] and log into their website www.obelis.net for further details
K CE Marking Class 1 (Non sterile) medical device CE Marking (Conformité Européene) / CB Scheme 3
Z Class 2 medical device - Process Validation - Test sterile or non-sterile units? Qualification and Validation (including 21 CFR Part 11) 4
A Medical Device Class 2A, non sterile bodyworn packaging requirements CE Marking (Conformité Européene) / CB Scheme 7
N Registering a Class 1 Sterile Medical Device - Currently selling a Non-Sterile 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
J Non-Sterile Class 2 Medical Device Shelf Life Other Medical Device Related Standards 3
R Shipping Stability for Class III IVD (Non Sterile) Medical Device Other Medical Device Related Standards 7
J Biocompatibility for Class I Non-Sterile Medical Device EU Medical Device Regulations 2
R How to go about package validation on a class II, non-sterile device US Food and Drug Administration (FDA) 4
Q Expiry Dates on a Non-Sterile Class 1 Medical Device (5 Year Shelf Life). Other Medical Device and Orthopedic Related Topics 11
A Need to register with CA for Class I (Non-Sterile and Non-Measuring) Medical Device EU Medical Device Regulations 4
M Packaging Requirements for Non-Sterile Class II Medical Devices EU Medical Device Regulations 11
J Requirements for Own Branding Class I Non-Sterile Device? ISO 13485:2016 - Medical Device Quality Management Systems 1
K Requirements for Exporting from US to EU - Class I MD non-sterile, non-measuring EU Medical Device Regulations 7
A Non-sterile liquid bandage as Class 1 - Anyone concur or disagree? EU Medical Device Regulations 17
A Documentation required for launch of a non-sterile exempt class 1 medical device ISO 13485:2016 - Medical Device Quality Management Systems 7
T Self Declaration for CE Class I, Non-Invasive Medical Device EU Medical Device Regulations 10
M Class II Medical Device Design Control Non Conformance 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
T 510k Submission - Class II Software communicates with a Non-Classified Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
A Launching a CE Mark Class I (non-measuring and non-sterilzed) Medical Device EU Medical Device Regulations 1
L Importing exempt Class I device from non-registered manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
G New intended use - Validation of a class IIb implantable (non-active) ISO 13485:2016 - Medical Device Quality Management Systems 5
A Research in Mexico, anyone? US class I (non exempt) 510(K) Dental ISO 13485:2016 - Medical Device Quality Management Systems 1
A What is required to export Class I (non exempt) 510(k) approved product to Mexico ISO 13485:2016 - Medical Device Quality Management Systems 3
shimonv Clinical evaluation report for class I device EU Medical Device Regulations 1
D Control Number for Class III and IV devices Canada Medical Device Regulations 0
M Class II type machine , and its compliance with 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
A Clinical assessment sample size - Medical device Class IIb implantable (93/42 directive) EU Medical Device Regulations 2
P ISO 14644 Class 8 Cleanroom Air Filter Requirements Other Medical Device Related Standards 4
J Instructions for use for Class I devices under MDR EU Medical Device Regulations 1
D Electrical Medical Devices class I EU Medical Device Regulations 0
K MDR Class 1 Self Certification - Competent Authority or Notified Body? EU Medical Device Regulations 6
K "World Class Product" based QM. I need advice. Quality Management System (QMS) Manuals 14
L Class IIb devices marked EC according to the 93/42/CE - Portugal CE Marking (Conformité Européene) / CB Scheme 3
J Biocompatbility testing on Class 1 device requirements Other US Medical Device Regulations 12
J Reusable surgical Instrument is under class IIa? EU Medical Device Regulations 4
H EU CE marking for Medical Device Class I EU Medical Device Regulations 2
E Any sample of a full software life cycle IEC 62304 report ( any class )? IEC 62304 - Medical Device Software Life Cycle Processes 1
JoCam Certified QMS for MDR - Class I medical device manufacturers EU Medical Device Regulations 4
G Voluntary Class I Device Filing Other US Medical Device Regulations 4
J IEC 60601-1-11 Home Class II With Ballasts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A ISO 13485 for Class 1 Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 7
N Validating Software before getting approved as Class 2 device US Food and Drug Administration (FDA) 5
D Can a diagnostic device be class I? EU Medical Device Regulations 1
A AMSQQP416E Class 2 type 2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S IVD risk class II devices for Brazil and MDSAP Other Medical Device Regulations World-Wide 0
P Anyone have an Idea on UAE Medical device registeration- Class B with FDA only Other Medical Device Regulations World-Wide 0
F Mobile app regulations - Class II medical device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Medical watch Class II (AP Type CF) with USB connection IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
