Class II medical device - When should a complaint be closed?
Darshan_Shetty
We make a Class II medical device and sell it in US and EU. Unless it is some application issue that can be fixed onsite, the defective device part or its accessories are replaced for the customer any time there is an issue. The defective part is then sent for repair to its OEM manufacturer. Once the part is fixed (this could take months), it is sent back to us for reuse and stored in our inventory.
Question is at what point of the process should the complaint be closed?
A. At the point when customer gets a replacement or
B. At the point when the specific defective part gets repaired and sent back to us
Mikey324
When is the root cause considered? I'm in automotive, so please ignore my ignorance of medical device standards. We consider a complaint closed when the root cause has been determined, corrective action has been implemented, and its effectiveness verified.
Darshan_Shetty
Isn't that the CAPA process to determine the root cause? Where is the difference between Compliant Handling Process VS CAPA Process. I would think that the prime objective of Compliant Handling process is to relieve the customer of any concerns, and that happens when we -Evaluate>Investigate>Replace. Root cause will always point to pre-market activities and that should be a CAPA not complaint. I dont know, Please correct me if I am wrong.
indubioush
Complaints need to feed into the CAPA system. You should evaluate each complaint to determine whether corrective action is required. Corrective action could also encompass a recall.
It seems to me that you have a complaint here and also feedback. As for the complaint, the customer is satisfied after they receive their replacement. However, for your organization, you need to trend the issues and results of the repair. If you want to have a complaint be considered closed after the customer is satisfied, that is fine, but how will you close the loop on the repair results? You may want to have a separate complaint and feedback process or record. Go back and read ISO 13485 and see the difference between feedback and complaints.
There is a substantial difference in how words are used between automotive and medical devices. there is also a substantial differences between being a supplier to the final producer and being the producer of the final product.
"Complaints" in the medical device industry are the same as warranty claims in the automotive industry. (they are also analogous to nonconforming material within your organization). The using customer only needs their 'problem' corrected. replace it, repair it, whatever.
If you have enough warranty claims, Customer complaints or non-conforming material occurrences, then root cause investigation and correction to prevent recurrence is in order.
Of course some final product producers try to impose 'root cause corrective action' on every single adverse event regardless of occurrence rate or severity.
hope this helps
Watchcat
I don't think you close the complaint, although I know this is common jargon. I think you close the investigation. From that perspective, whether the customer gets a replacement part or a refund, or is told to bug off, is irrelevant.
A Clinical assessment sample size - Medical device Class IIb implantable (93/42 directive) EU Medical Device Regulations 2
H EU CE marking for Medical Device Class I EU Medical Device Regulations 2
JoCam Certified QMS for MDR - Class I medical device manufacturers EU Medical Device Regulations 4
K CE Marking Class 1 (Non sterile) medical device CE Marking (Conformité Européene) / CB Scheme 3
A ISO 13485 for Class 1 Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 7
P Anyone have an Idea on UAE Medical device registeration- Class B with FDA only Other Medical Device Regulations World-Wide 0
F Mobile app regulations - Class II medical device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
K CE Marking for Class I Medical Device? CE Marking (Conformité Européene) / CB Scheme 8
D Class IIB Medical Device Accessories - OTS Tablets Other Medical Device Regulations World-Wide 1
A Interpretation of GMP Requirements for class 1 medical device manufacturer (device GMP exempt, only General controls applicable) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
H MDD Article 12 Labeling for Class IIa Medical Device - Please Advise EU Medical Device Regulations 3
A Medical Device Vigilance decision tree for Japan for class 2 devices. Japan Medical Device Regulations 1
Edward Reesor EU Authorized Representative for a Class I Medical Device CE Marking (Conformité Européene) / CB Scheme 11
W Direct to customer export of medical device (class I: prescription lenses + frame) US Food and Drug Administration (FDA) 2
C New Class III medical device application for Health Canada Canada Medical Device Regulations 6
T First 510(k) submission - Class II software as medical device US Food and Drug Administration (FDA) 4
JoCam Failure to test Class I medical device to IEC 60601-1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S How to register class IIA medical device accessories EU Medical Device Regulations 1
U Medical device trial budget - 2 hospitals for Class IIa medical device in Sweden Other Medical Device and Orthopedic Related Topics 2
A Class medical device (MDD) - Classification help EU Medical Device Regulations 1
M Notified Body audits -Class Ia medical device product EU Medical Device Regulations 4
N Can a (class I) medical device be manufactured in a GMP certified site with no ISO13485? EU Medical Device Regulations 18
U Do we need clinical trial data for Class IIa medical device under MDR EU Medical Device Regulations 7
R Countries that accept 510k approvals - Class II nonsterile medical device Other Medical Device Regulations World-Wide 2
B Class III Medical Device Accelerated conditions Other Medical Device Related Standards 1
D FDA Approved Class II Medical Device? Other US Medical Device Regulations 11
N CE Mark for Class 1 medical device CE Marking (Conformité Européene) / CB Scheme 11
D Software as an accessory to a Class I medical device EU Medical Device Regulations 4
C ETO Sterilised Class II Medical Device - Required Temperature Storage ISO 13485:2016 - Medical Device Quality Management Systems 1
A Does Class 1 Medical Device need to be certified to MDSAP? Canada Medical Device Regulations 5
N Can we take a part from 510k cleared medical device and use it in class I device? Other US Medical Device Regulations 3
J Class 1 Medical Device - Using a UPC over the UDI? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
N Selling a class II Medical Device in Canada in Pharmacies Elsmar Xenforo Forum Software Instructions and Help 10
S Acrylic in Class II b Active Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
L A Taiwan company want to sell Class I medical device (510(k) exempt) on Amazon, should we register with FDA? US Food and Drug Administration (FDA) 4
S Conformity Assessment Route question for Class IIa medical device under MDR EU Medical Device Regulations 3
K Inventory Control - Class II (IIb for CE) medical device ISO 13485:2016 - Medical Device Quality Management Systems 6
S Software Release Note - Class A stand alone software medical device IEC 62304 - Medical Device Software Life Cycle Processes 2
J FDA Class 1 Medical Device UDI requirements Other US Medical Device Regulations 19
L Class IIa Medical Device, CE Mark & 510k - Labeling Content CE Marking (Conformité Européene) / CB Scheme 4
M How is Class I Medical Device Compliance Enforced? EU Medical Device Regulations 7
K Calibration of Dose Area Product (DAP) Meter in our Class IIb X-Ray Medical Device General Measurement Device and Calibration Topics 1
Z Class 2 medical device - Process Validation - Test sterile or non-sterile units? Qualification and Validation (including 21 CFR Part 11) 4
C Medical device manufacturing (class 2 ISO 13485:2016) - Is a Deviation allowed? Other Medical Device Related Standards 5
S Understanding UDI requirements - Class 2 medical device (hearing aids) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
N Per the FDA regulations can a medical device be class I despite that it is sterile? Other Medical Device Related Standards 4
M Include IFU in Class II Medical Device Marketing Brochure? US Food and Drug Administration (FDA) 2
J Steps when changing material for class 1 medical device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Clinical evaluation for a class IIa medical device - EU MDR Requirements EU Medical Device Regulations 3
