Class Ins CE Mark Labeling Requirements (particularly Lot or Batch symbol and number)
K
katastic
Good Morning,
I am wondering if anyone out there can help me out. I work for a small Surgical Instrument company in Colorado. We just had a review of our Technical File by our Notified Body so we can self certify our Class Ins instruments. One the report given to us by our Notified Body, one of the findings was that we needed to add the "Lot" number symbol to our labels (I'm assuming along with the lot number of the instrument) However, I am trying to find out if this is a requirement for Class Ins instruments. All I can find or gather from the MDD is
13.3. The label must bear the following particulars:
(a) the name or trade name and address of the manufacturer. For devices imported into the Community, in view of their distribution in the Community, the label, or the outer packaging, or instructions for use, shall contain in addition the name and address of either the person responsible referred to in Article 14 (2) or of the authorized representative of the manufacturer established within the Community or of the importer established within the Community, as appropriate;
(b) the details strictly necessary for the user to identify the device and the contents of the packaging;
(c) where appropriate, the word 'STERILE';
(d) where appropriate, the batch code, preceded by the word 'LOT', or the serial number;
It indicates "Where appropriate" but I have searched and searched to try and find what is deemed "appropriate" and I just need a reference to a applicable standard, that I can reference. I hope all that makes sense and I appreciate any help that can be given.
I am new to the world of Medical Devices, so I may be coming back with more questions.
thank you
MIREGMGR
Re: Class Ins CE Mark Labeling Requirements (particularly Lot or Batch symbol and num
I'm not aware that there is a formal definition. I think the common understanding is that it's "appropriate" when the production process is batch/lot oriented.
K
katastic
thank you. I would say that the batch/lot situation doesn't apply to what we sell, all non sterile reusable, low risk, class I instruments. We are an overbrand relabeler and don't do our own manufacturing. Am I correct in my assumption that it wouldn't apply?
MIREGMGR
I'd think you'd want to batch code your products...either with the actual maker's batch code if that's known to you, for instance from their production documentation provided to you, or in regard to your purchase lots.
If you have an issue or event that results in a Recall, and you are not batch coded, FDA and possibly EU authorities will expect you to recall all products from a long period of time surrounding when the incident-creating product unit was thought to have been made. If on the other hand your products are batch coded, you only have to Recall the suspect batch plus any other batches that investigation shows probably have the same issue.
To answer your direct question: obviously your NB auditor thinks that you need to so label. If I were the auditor, I'd probably agree. My view is that everything should be batch/lot coded. I'm hard pressed to think of a production process that doesn't have some characteristic that can be recorded to indicate batch/lot. Even a continuous process can be date- or date/time-marked, as is common in pharma and food production.
Note that as the CE Marking party, you are the Manufacturer (or Specification Provider, which is regulatorily equal) in US FDA terminology or the Own Brand/Private Label Manufacturer in MHRA Bulletin 19 MDD terminology, i.e. the primary regulatorily responsible party, irrespective of who actually fabricates the products. Thus your "overbrand relabeler" comment is misleading.
K
katastic
We do have lot traceability, it just isn't something that is printed out on the labels. when we get an order from our supplier with the lot number that is entered into our inventory, and copies filed of our suppliers certs, packing lists etc... If a situation were to happen, it is an easy 5 minute look up to find out the lot number from our supplier in our database. Also a 5 minute look up if we needed to find out what customers purchased the recalled item.
MIREGMGR
If you've got the information, I very much doubt if you're going to convince the auditor that it doesn't fall under the "appropriate" qualification.
Ronen E
Problem Solver
Moderator
Hello and welcome to the Cove (and the MedDev field) :bigwave:
2 things bother me:
(a) Why was a NB involved in the CE marking process of a class Ins in the first place?
(b) If you get a defective unit back from the field, with no accompanying paperwork and/or packaging, with limited and/or confused verbal information from the complaining party (it happens a lot! sometimes you don't even get the unit, you just hear about it...), and it's not lot/batch-identified (on the unit itself), how do you quickly, easily and reliably find out to what lot/batch of yours it belongs?
Cheers,
Ronen.
pkost
2 things bother me:
Cheers,
Ronen.
Both good questions I was about to ask!
shimonv Clinical evaluation report for class I device EU Medical Device Regulations 1
D Control Number for Class III and IV devices Canada Medical Device Regulations 0
M Class II type machine , and its compliance with 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
A Clinical assessment sample size - Medical device Class IIb implantable (93/42 directive) EU Medical Device Regulations 2
P ISO 14644 Class 8 Cleanroom Air Filter Requirements Other Medical Device Related Standards 4
J Instructions for use for Class I devices under MDR EU Medical Device Regulations 1
D Electrical Medical Devices class I EU Medical Device Regulations 0
K MDR Class 1 Self Certification - Competent Authority or Notified Body? EU Medical Device Regulations 6
K "World Class Product" based QM. I need advice. Quality Management System (QMS) Manuals 14
L Class IIb devices marked EC according to the 93/42/CE - Portugal CE Marking (Conformité Européene) / CB Scheme 3
J Biocompatbility testing on Class 1 device requirements Other US Medical Device Regulations 12
J Reusable surgical Instrument is under class IIa? EU Medical Device Regulations 4
H EU CE marking for Medical Device Class I EU Medical Device Regulations 2
E Any sample of a full software life cycle IEC 62304 report ( any class )? IEC 62304 - Medical Device Software Life Cycle Processes 1
JoCam Certified QMS for MDR - Class I medical device manufacturers EU Medical Device Regulations 4
K CE Marking Class 1 (Non sterile) medical device CE Marking (Conformité Européene) / CB Scheme 3
G Voluntary Class I Device Filing Other US Medical Device Regulations 4
J IEC 60601-1-11 Home Class II With Ballasts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A ISO 13485 for Class 1 Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 7
N Validating Software before getting approved as Class 2 device US Food and Drug Administration (FDA) 5
D Can a diagnostic device be class I? EU Medical Device Regulations 1
A AMSQQP416E Class 2 type 2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S IVD risk class II devices for Brazil and MDSAP Other Medical Device Regulations World-Wide 0
P Anyone have an Idea on UAE Medical device registeration- Class B with FDA only Other Medical Device Regulations World-Wide 0
F Mobile app regulations - Class II medical device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Medical watch Class II (AP Type CF) with USB connection IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
L Radiology software Class I exemption Medical Device and FDA Regulations and Standards News 3
K CE Marking for Class I Medical Device? CE Marking (Conformité Européene) / CB Scheme 8
A Class I (exempt) testing requirements Other Medical Device Related Standards 0
Z Class I marketing regulation and supply chain Other Medical Device Regulations World-Wide 0
S We are looking for EU authorised Representative for both Class I and Class IIb devices EU Medical Device Regulations 7
S How is the service life for class I reusable medical devices described in MDR? EU Medical Device Regulations 7
S How is the service life described for class I reusable medical devices in MDR? Elsmar Xenforo Forum Software Instructions and Help 1
R Class 1 Convenience kits for home teeth impression, NOT smile direct or other for alignment purposes Canada Medical Device Regulations 0
J Confusing on Harmonic Emissions/Voltage Fluctuations/Flicker test for CISPR 11 Class A Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
J Intervertebral body fusion cage, MDR Class II or Class III? EU Medical Device Regulations 4
T Do I need a qualified compiler for class B software? IEC 62304 - Medical Device Software Life Cycle Processes 3
R Nanomaterials used as coating on class I MD - rule 19 EU Medical Device Regulations 4
D Amendment Class II - Please confirm if the submission is by email (Canada) - Help Canada Medical Device Regulations 0
D Class IIB Medical Device Accessories - OTS Tablets Other Medical Device Regulations World-Wide 1
K Doubt on insulation class of a device IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
D Where to find Guidance Class II Amendment Canada Medical Device Regulations 1
A First CE-mark class III implantable device under MDD EU Medical Device Regulations 8
P ISO Class 8 particle count (annual certification vs monitoring) ISO 13485:2016 - Medical Device Quality Management Systems 4
I IVD - 98/79EC - class IIa - Annex to the EC from the NB states the CM as one of the facilities? CE Marking (Conformité Européene) / CB Scheme 2
Z MDR Class Ir deadline (Reusable surgical instruments) EU Medical Device Regulations 27
D Adding a Class I to a sample box Canada Medical Device Regulations 5
T Class A PRTD beyond 300°C General Measurement Device and Calibration Topics 0
