Classifying SMD chip resistor and SMD array resistor - Electronic Components
Sherin MR
Hi All,
I have a doubt in classifying the resistor.
I have got three classification of resistors with values
1.composition
2.fixed
3.fixed film
4.fixed wire wound
5.thermistor
6.variable
Into what category does SMD chip resistor and SMD array resistor fall into?
Waiting for a reply...................
Regards,
Sherin MR
BradM
Re: Electronic Components - Classifying the resistor
Hello, Sherin!
I am not sure I understand your question. You state that you have 3 classifications of resistors, do you mind listing those?
Each of the three classifications have 6 characteristics. You have listed those. The 6 characteristics look more like resistor classifications to me. Are they?
Then you list SMD chip resistor and SMD array resistor. Are those two of the 3 classifications that you referred to?
What does SMD stand for? Could they be considered a different classification?
Sorry for all the questions.:) Look forward to hearing from you.
andygr
SMD- Surface Mount Device
I would go with classification of 3 since they are film resistors
:2cents:
Sherin MR
Actually I have the failure mode probability of only those resistor classifications that is listed above.So I wanted to know to which category it will fall into.
I guess SMD means Surface Mount.Please help me......................
How can u say that they are film type?
Regards,
Sherin MR
Sherin MR
Thank you for this information:thanx:, but nothing is said about array resistors.
What are this array resistors?
Waiting for your reply....................................
Regards,
Sherin MR
harry
Regards,
Sherin MR
Array means 'group' - often designed with a special purpose or function in mind. See the link provided in the post before.
Sherin MR
What are SMD Transil diodes and ultra fast diodes?
To which category of diodes it will fall into if am given with classifications given below
1.general
2.rectifier
3.silicon control rectifier
4.small signal
5.thyristor
6.tirac
Waiting for ur reply......................
Regards,
Sherin MR
E Can we still use MEDDEV 2.4/1 rev. 9 when classifying a medical device product under MDR? EU Medical Device Regulations 4
J MDR reporting and CAPA thoughts? Classifying Complaints on Risk 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
D Down Classifying a Medical Device from Class II to Class I Other US Medical Device Regulations 21
M Classifying Software - Insulin Calculator EU Medical Device Regulations 13
M Classifying a Multiple Risk Medical Device System 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
J Classifying Defect Reports from Business Partners US Food and Drug Administration (FDA) 4
S Directives for Classifying Standalone Software as Medical Devices CE Marking (Conformité Européene) / CB Scheme 3
J FDA classifying all PACS software devices as Moderate Level of Concern? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
B Classifying findings as Major vs. Minor findings in the AS9100 world AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
C Classifying documentation changes for priority Document Control Systems, Procedures, Forms and Templates 1
D Classifying Nonconformance so that they can be Actioned in Relation to Time Frames Nonconformance and Corrective Action 7
A Classifying Documents for Different Document Levels ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Suppliers - Classifying Critical and Major suppliers & how to define them? Supplier Quality Assurance and other Supplier Issues 2
O Classifying Characteristics QS-9000 - American Automotive Manufacturers Standard 4
I SMD line PQ Validation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
B Looking for Photos of Surface Mount Device (SMD) Soldering Manufacturing and Related Processes 14
L Clean room class for SMD capacitor manufacturing Manufacturing and Related Processes 1
R Thread plug chip groove - Thread plugs without the chip groove General Measurement Device and Calibration Topics 0
N Convert Class A Software to B by on-chip Watchdog IEC 62304 - Medical Device Software Life Cycle Processes 5
A Chip Resistor Body Marking Standard - Is EIA-96 being replaced? Various Other Specifications, Standards, and related Requirements 6
M Using the Chip Box and Sampling Bowl to Teach SPC Training - Internal, External, Online and Distance Learning 7
M Diebond adhesive blowholes seen after thermal curing on chip to plastic bottle mount Manufacturing and Related Processes 4
Marc 'Sex chip' being developed by scientists Coffee Break and Water Cooler Discussions 16
C Is there a JEDEC, EIA or Military standard for Chip Scale Package Inspection Criteria Various Other Specifications, Standards, and related Requirements 5
M Qualification of a Poron Gasket for a Silicon Acoustic Sensor Chip Manufacturing and Related Processes 3
Marc Gas-turbine Engine on a Chip Drives Laptops After Work and Weekend Discussion Topics 0
Marc Silicon-based chip that can produce laser beams - Major computing advancement After Work and Weekend Discussion Topics 0
J Siemens pick and place machine for chip placement - Utilization - Splicing Lean in Manufacturing and Service Industries 4
Marc Intel releases is WiMax chip - And Rewrites History After Work and Weekend Discussion Topics 1
