Clause Interpretations related to AS9100 Implementation
O
Omkar S Rao
Dear Forum members,
We are implementing AS9100 in our organisation. We need help with the following questions.
  1. Clause 7.1 a, Note. - Some of us feel this clause talks about design only and will be applicable only if we are involved in design - we do not have a design function in our org. The second view point is that the Std is mandating that product requirements and quality objectives are to be determined and process must be planned for product realisation.
  2. If 7.1 a, can be excluded ( if applicable as a design specific clause) then will a simple justification of " 7.1 a excluded as we do not have design " will suffice ?
  3. Does embedded software mean only software in the product itself ( like a radar screen) or does it also refer to CAM software used ( I am refering only to the application of and not design of CAM software) for product realisation ?
  4. Can 7.1(f) "maintenance of the product " also refer to packing of the product for despatch?
  5. If we exclude 7.3 , because we do not have product design, but we design fixtures and electrodes for spark erosion of profiles in Aerospace parts - how dow we address this in our QMS ?
  6. Can you site some examples of Statutory and Reguatory requirements for the aerospace industry.( to helps us understand difference between the two words).
  7. During manufacturing if we decide to change a resource and decide to mfg the parts on a more capable resource will we be required to do a First Article again?
  8. What is the difference between Measurement and Monitoring.
Sorin
Re: ISO 9001 vs. AS9100 Interpretations
Those interpretations are for ISO 9001 so it's probably not a good idea to entirely depend upon ISO 9001 interpretations for AS9100 interpretations.
I know that, but AS is like 80%ISO+20%SAE (and whatever the Primes considered as necessary).
From memory, I could be wrong, there are no differences between ISO and AS in regards to OP questions....
Edit: My bad...they are different...sorry for misleading
ISO
7.1 Planning of product realization
The organization shall plan and develop the processes needed for product realization. Planning of product
realization shall be consistent with the requirements of the other processes of the quality management system
(see 4.1).
In planning product realization, the organization shall determine the following, as appropriate:
a) quality objectives and requirements for the product;
b) the need to establish processes and documents, and to provide resources specific to the product;
c) required verification, validation, monitoring, measurement, inspection and test activities specific to the
product and the criteria for product acceptance;
d) records needed to provide evidence that the realization processes and resulting product meet requirements
(see 4.2.4).
The output of this planning shall be in a form suitable for the organization's method of operations.
NOTE 1 A document specifying the processes of the quality management system (including the product realization
processes) and the resources to be applied to a specific product, project or contract can be referred to as a quality plan.
NOTE 2 The organization may also apply the requirements given in 7.3 to the development of product realization
processes.
AS
7.1 Planning of Product Realization
The organization shall plan and develop the processes needed for product realization. Planning of product realization shall be consistent with the requirements of the other processes of the quality management system (see 4.1).
c) required verification, validation, monitoring, measurement, inspection and test activities specific to the product and the criteria for product acceptance;
d) records needed to provide evidence that the realization processes and resulting product meet requirements (see 4.2.4);
e) configuration management appropriate to the product;
1) resources to support the use and maintenance of the product.
alspread
    This clause is NOT for design only and applies to your manufacturing/realization processes.
    No 7.1 a can't be excluded just because you exclude design. in fact, it is difficult to realize how any organization that produces something could possibly exclude 7.1. I know the standard says that elements of section 7 are excludable, but it is hard to imagine exclusion of 7.1
    Embedded software is software included in or embedded in the product. Production software is typically controlled in section 7.5.1.3 and 7.6
    The list you reference includes the term "as appropriate" for each of the items a-f. I don't know anything about your product, but if you are a build to design firm (it sounds like you are) then "use and maintenance" may not apply, or may be "as appropriate" to your QMS.
    Fixtures and electrodes are production equipment and are controlled by 7.5.1.3
    Statutory & regulatory requirements are things like: controls on governement contracts and contract reporting, complying with locals laws and regulations as they affect the QMS,, etc
    That all depends. Usually, yes, but the key term is "when changes occur that invalidate the original results". AS9102 has some better definitions on this, but you should check with your customer to be sure
    Measurement is determining the value or result. Monitoring is comparing that result to a requirement, objective, or expectation.
[/QUOTE]
Good luck
O
Omkar S Rao
Thank you Guys - for taking the time to post your replies. I appreciate it. I shall need your support for the numerous questions that i am sure i will have as we go ahead.
Regards,
Omkar Rao
Please put one question at a time.This would help you to get better inputs.My friend has already helped you but I have question for you.Do you design those fixtures for your own process or for your customers?If you do it for your customers,you would not be able to exclude claus 7.3.
For statutory and regulatory requirements,don't get confused as all are now considered as legal requirements.Example of statutory requirement in aerospace industry for India-Indian Aircraft Act 1937.Regulatory requirements:All civil aviation requirements (CARs) by DGCA.
O
Omkar S Rao
Thank you for giving such a useful input. Where can i get a copy of the CAR and the 1937 act.
Regards,
Omkar Rao
CARs can be downloaded from DGCA web site and you need to purchase the bare act.It would be better if you can let us know about your product and customers,we would be able to assess if you fall under any legal requirements.
wooden nickle
How can a contract manufacturer that has nothing to do with the design function be responsible for 7.1a - quality objectives and requirements for the product? We have no control over any of the noted considerations listed in the standard. Believe me, we do make suggestions, but that is as far as we can go, AS YOU KNOW, THE CUSTOMER IS ALWAYS RIGHT.
C Application of ISO 9001:2015 Clause Interpretations for Service Industries Service Industry Specific Topics 2
M Specific Requirement for Calibration - ISO 17025 Clause 5.6.2 Interpretations ISO 17025 related Discussions 15
R ISO 9001:2008 Clause Interpretations and Clarifications ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
Sidney Vianna ISO 9001:2000 Interpretations: RFI's #16 and 17 - Clause 8.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
B How to satisfy clause 5.7.1.5 process validation for valve production API 6D Oil and Gas Industry Standards and Regulations 13
W IEC 60601-1 clause 8.8.3 - Dielectric Strength IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
B IEC 60601-1 Clause 14.8 - Architecture IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
somashekar Justification for Non-applicable clause at Stage 2, in clause 4. ISO 13485:2016 - Medical Device Quality Management Systems 11
T API SPEC Q1 Clause 5.6.1.2.C).2) First Article Oil and Gas Industry Standards and Regulations 16
A ISO Clause 4.1/4.2 & 6.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
K ISO 9001 Clause 8.3 & 8.6 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J ISO 9001:2015 Clause 8.5.1 Control of Production and service provision - Help with Work Instruction Access ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
P Maximum Mains Voltage (clause 8.5.3) IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
S IATF 16949 - Summary at a glance Clause wise - changes from ISO TS IATF 16949 - Automotive Quality Systems Standard 4
A ISO 14001:2015 clause 4.4 ISO 14001:2015 Specific Discussions 2
M Customer Property - ISO 13485:2016 Clause 7.5.10 ISO 13485:2016 - Medical Device Quality Management Systems 9
D PSW with waiver statement (hold harmless clause) IATF 16949 - Automotive Quality Systems Standard 3
Ashland78 MSA clause or wording needed. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A IT-NETWORK in PEMS Sub-Clause 14.13 for Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
A 60601-1 clause 8.11.3.6 Test Clarification IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
S MSA clause 7.1.5.1.1 - Statistical studies on counting weight scale Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
Thee Bouyyy Internal NCR - API Q1 5.4.2b - API 16C Clause 4.1.3 Internal Auditing 9
L ISO 45001:2018 - Clause 5.4: Consultation and Participation of Workers Process Maps, Process Mapping and Turtle Diagrams 1
V Clause 7.1.3.1 Plant, facility, and equipment planning Lean in Manufacturing and Service Industries 0
J Aluminum anodization as MOP insulation? Clause 8.5.1.1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
V Setup for testing against ISO14708 clause 16 (protection of the patient from herms caused by heat) Other Medical Device Related Standards 0
M IATF16949 Clause 9.1.2.1e - Customer notification related IATF 16949 - Automotive Quality Systems Standard 4
N 60601-2-2 Ed 6 Clause 201.8.8.3.102 - HF instrument leakage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
A ISO 13485 Sterilization Clause Applicability ISO 13485:2016 - Medical Device Quality Management Systems 7
A AS9100D - Clause 8.1 Operation - Coating service company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
T AS9100D Clause 10.2.1g Supplier Corrective Action for each and every nonconformity? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
H AS9100D clause 8.5.1 f) & 8.5.1 g) - Special Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S ISO 9001 Clause 8.2.3 - Review of the requirements for products and services in a Cafe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
C ISO/IEC 17021-1 clause 7.1.2 - Determination of competence criteria Document Control Systems, Procedures, Forms and Templates 2
SANTHSH API Spec. Q1 clause 5.6.1.2 On site evaluation Oil and Gas Industry Standards and Regulations 12
K ISO 13485 clause 8.5.2 'Any necessary CA shall be taken without undue delay' ISO 13485:2016 - Medical Device Quality Management Systems 11
lanley liao How to understand the term 3.1.21 'Servicing' and the clause 5.7.1.2 'Servicing' of API Spec Q1? Oil and Gas Industry Standards and Regulations 19
D Layered Process Audits - FCA 9.2.2 - Exemption Clause? IATF 16949 - Automotive Quality Systems Standard 5
J Scope of ISO 9001 clause 10.2 in the product life cycle ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S MDR GSPR Clause 17 - Software Requirements EU Medical Device Regulations 2
K Contamination Control - Class Is medical devices (Clause 6.4.2 ISO 13485:2016 (E)) ISO 13485:2016 - Medical Device Quality Management Systems 12
