Clean room performance qualification (pq) - How many times can I do each test?
Olgamargarita
Dear all, How many times can I perform eah test of PQ?
filter integrity,
filtration,
air changes per hour,
differential pressures,
temperature,
humidity,
counting of non-viable particles and
control of viable particles
thanks
Olga
Olgamargarita
It depends on ISO Class of clean room, Risk Analysis and what is outlined in your validation master plan (VMP).
See this document from World Health Organization as it relates to vaccine manufacturing - they recommend 20 days (page 40)
http://apps.who.int/iris/bitstream/handle/10665/64465/WHO_VSQ_97.02.pdf?sequence=2
Thank you, I am interested to know how many times I have to perfom each test (for example, how may times or during how many hours I have to monitor temperature) in order to performace to quality in Class room Class D (ISO8), please
filter integrity,
filtration,
temperature,
humidity,
Ninja
Looking for Reality
Not sure what industry you are in...it would be helpful...BTW, do you mean "Grade D" which equates to ISO 8, or 100K?
For my Class 100K rooms (similar to ISO 8), we did this once per year...as directed by the outsourced company who did it.
Each room tested too about an hour stem to stern...
For a totally different industry, the risks, and thus the frequency, might be wildly different (like 20 days in Ajit's post).
I was in electronic materials, but not assembly.
Note that Temp and Humidity (and everything else you list) are not required parts of ISO8...though your process needs may have added them...they are functional means to an end...the air.
My living room in my house passes ISO8...we don't have kids or pets...
Olgamargarita
I work at laboratory which manufacture pharmaceutical product - solid dosage forms, this clean room is Class D, this is the same ISO 8, the only way to show is Class D is performig tests. you talk about frecuency which is set by laboratory taking into account many factor. I want to know if it is neccesary to do 1 or 3 integrity test to hepa filter which is located in UHA or ducts in order to pass performed qualification.
Olga
Ninja
Looking for Reality
Got it...that's why I asked about your industry...
I am not current on requirements in Pharma or medical...only electronics and electronic assembly. The requirements are likely different outside of the base ISO8 requirements...
Ajit Basrur
filter integrity,
filtration,
temperature,
humidity,
There are no hard coded requirements and you can define based on your risk analysis. Typically, 3 days intensive monitoring to cover all shifts should be satisfactory. Having covered all parameters could be part of OQ, the 3-days monitoring could cover differential pressures, temperature, humidity, non-viable and viable.
BradM
Hello there!
Simply, the task before you is to provide and assure clean air. So there are a lot of things mixed below:
How you provide clean air and suitable environment:
filter integrity,
filtration,
temperature control
humidity control.
How you verify suitable environment is maintained:
counting of particles
differential pressure indicator
temperature monitoring
humidity monitoring.
So, you start with a properly engineered room with gown room. Depending on the class the room was designed for, there should be sufficient filters and adequate air changes per minute/hour.
As long as the air flow is suitable, filters work like they should, environmental system is working fine, positive air pressure is maintained, and clean room guidelines are followed, the air should be clean. The appropriate parameters are then verified with the particle counters, differential indicator, and temp/RH monitoring.
Calibration of the counters, indicator and temp/RH indicators should follow an analysis of the instrument performance. Usually I would recommend once or twice a year. They can be performed when there is a planned clean-room shutdown.
Filter maintenance can depend on a lot of factors including time since last change, how much filters are moved around and such, and cleanliness of the incoming air.
If you have continuous particle monitoring, I would perform calibration and maintenance every six months or a year, unless you can find an industry requirement that would supercede that. If you're having alarms, lose positive pressure, etc., you might have to perform it more frequently.
Olgamargarita
Thnak you so much BradM, your commets are very useful for me, I have acknowledgement that filter integrity must be perfom for verifying environonment once a year, it is correct? I work in manufacturing lab of tablet.
Thanks,
Olga
D What should an ISO 14644 Clean Room PQ (Performance Qualification) look like? Manufacturing and Related Processes 3
S Clean Room Class ISO 8 EU Medical Device Regulations 3
S Reintroduce packaging component/med device from white room back to class 7 clean room Manufacturing and Related Processes 1
B Clean room shut down and re-validation or re-qualification? Other Medical Device Related Standards 6
S Wooden Pallets in Production Clean Room Food Safety - ISO 22000, HACCP (21 CFR 120) 5
S Clean room not part of my certification ISO 13485:2016 - Medical Device Quality Management Systems 3
V Manufacturing requirements for respiratory ventilators - clean room required? Medical Device and FDA Regulations and Standards News 6
C Clean room injection molding, raw material mixing requirements ISO 13485:2016 - Medical Device Quality Management Systems 2
C Raw material Mixing / Preparation for clean room class C injection molding Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
A Construction of an ISO 8 Clean Room - ISO 14644-1 Manufacturing and Related Processes 2
P ISO 5 Pharmaceutical clean room design Process Maps, Process Mapping and Turtle Diagrams 2
O Localized clean room dust extraction system coupled in HVAC - Manufacturing solid dosage form Manufacturing and Related Processes 9
I Clean room recovery program Other Medical Device and Orthopedic Related Topics 1
M ISO 7 Clean Room Requirements? ISO 13485:2016 - Medical Device Quality Management Systems 4
M Scarf in Clean Room instead of Hair cover? Manufacturing and Related Processes 8
M What are ISO 7 Clean Room Requirements Manufacturing and Related Processes 0
S Should the primary drug containers be molded in ISO Class 7 clean room? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 6
S ISO 7 and 8 Clean Room Cleaning Other Medical Device Related Standards 2
S New clean room change submission - FDA Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
A Sterile Garbage Bag for Clean Room Manufacturing and Related Processes 6
N ISO 14644-1 Clean Room Occupancy State Validation Requirements Manufacturing and Related Processes 3
S What is the minimum pressure differential required for ISO Class 8 Clean Room? ISO 13485:2016 - Medical Device Quality Management Systems 3
V Not using gloves in Clean Room Class 8 (ISO 14644) Manufacturing and Related Processes 21
M Bioburden testing for Class 10000 (Grade C) clean room ISO 13485:2016 - Medical Device Quality Management Systems 1
L How do I set a limits to cfu in an ISO class 7 Clean Room? ISO 13485:2016 - Medical Device Quality Management Systems 2
L Clean Room Monitoring Plan Other Medical Device and Orthopedic Related Topics 6
L AS9100 7.5.2 Special Processes - Clean Room Apply? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
G Clean Room Classification for Contact Lens Packaging ISO 13485:2016 - Medical Device Quality Management Systems 4
A Clean Room as a Controlled Environment - Requirements ISO 13485:2016 - Medical Device Quality Management Systems 12
D Do I need to test "as built" for an expanded ISO Class 8 Clean Room ? Other Medical Device Related Standards 2
S What are air changes are required for ISO Class 8 Clean Room? US Food and Drug Administration (FDA) 2
A Clean Room Qualification Regulatory Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
L FDA Inspection of Clean Room Processes 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
somashekar Determination of Clean Room Class for Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 1
E Do I need to audit the supplier supplying mop heads for our Clean Room ? ISO 13485:2016 - Medical Device Quality Management Systems 8
M What should be in an SOP for a Machine Operation - LAF Bench in our Clean Room ISO 13485:2016 - Medical Device Quality Management Systems 3
P Clean Room Calibration (Validation) Other ISO and International Standards and European Regulations 4
C Recommended Sealing for Granite Top in a Clean Room US Food and Drug Administration (FDA) 1
L ISO 14644 Class 7 Clean Room Requirements Training Presentation Training - Internal, External, Online and Distance Learning 2
K SPC to apply for Particle in Clean Room Class 100 Statistical Analysis Tools, Techniques and SPC 7
V Updated Clean Room Classification Table of ISO 14644 Other ISO and International Standards and European Regulations 2
N Clean Room Validation and Certification Methods and Definitions ISO 13485:2016 - Medical Device Quality Management Systems 2
S Clean Room Training for Manufacturing Operators (Personal Hygiene, Gowning, etc.) Other Medical Device and Orthopedic Related Topics 4
J Yearly Cleanroom Revalidation Test Requirements - Questions for users clean room ISO7 Qualification and Validation (including 21 CFR Part 11) 5
V AHU (Air Handler Units) and Clean Room References Qualification and Validation (including 21 CFR Part 11) 3
B Hospital Operating Room Regulations - Separate Entrances for Clean and Dirty Supplies Hospitals, Clinics & other Health Care Providers 4
J ISO 14644 - Monitoring Clean Room Particulates (Class 8 Cleanroom) Other ISO and International Standards and European Regulations 4
B Building a Class 10,000 Clean Room Manufacturing and Related Processes 2
A Identifying the Clean Room Requirements for a Medical Device in US and EU ISO 13485:2016 - Medical Device Quality Management Systems 3
G Is Microbiological Monitoring required for Clean Room? Other Medical Device Regulations World-Wide 8
