Clean room shut down and re-validation or re-qualification?
Ben124
Hi all,
we are considering to invest in to clean room, due to the potential new business. ISO 8 would be enough, for our types of products (injection molding plastic parts).
- So the question is, can clean room be shutted down for month or two (several time per year), If we would not have enough orders to to keep clean room working 24/7? I guess, to have clean room on, only to keep clean room conditions is not cost effectively.
-As well, do we need to do re-validation before every strat up of clean room the same way as validation was done upon initial start up of clean room, including IQ, OQ, PQ? Or only qualificaiton of parameters is enough (Particulate Counts, Pressure Differential, Air Velocity, Temperature, Humidity, Leak Test?
Thank you in advance.
It depends on which CER requirements will be affected by the shutdown. Different clean rooms are constructed differently. You shouldn't have to redo IQ if the equipment will remain as is. Review requirements, create a shut down and start up procedure based on the affected items. If you operate according to plan, and then later find out certain things are not affected, you update your procedure to do less. Ensure your CER is operating as required prior to manufacturing product.
Are you sure it is cheaper to shut it down and start it up vs keeping the HEPA filters going and forgoing monitoring for a while?
Ben124
Thank you for your answer indubioush. Not sure if is cheaper, that is what I want to find out :) . I've heard that energy consumption of HVAC system could very high. Would like to compare cons and pros.
Ben124
So, I guess, it would be much easier for us, if we would have our own monitoring and cleaning, in case of several shut downs per year, than pay third party to do it for us?
It is cheaper to do it yourself. However, there will be startup costs for equipment, and you will have to ensure you have a person who is appropriately trained, especially with microbiology practices.
AgnieszkaSz
From my experience - if you decide to perform the required monitoring, it would be good if you do recovery test at qualification stage. This will tell you how long your HVAC system must work till particle count drops to required level. Then you set up safety margin for HVAC operating to full extent, then add time from recovery test and then operator must take particle count measurements; if they are OK, work can commence. We operate this way - but our cleanrooms are down for no longer than 7 days in a row. No problems so far (6 years in operation).
S Reintroduce packaging component/med device from white room back to class 7 clean room Manufacturing and Related Processes 1
S Wooden Pallets in Production Clean Room Food Safety - ISO 22000, HACCP (21 CFR 120) 5
S Clean room not part of my certification ISO 13485:2016 - Medical Device Quality Management Systems 3
V Manufacturing requirements for respiratory ventilators - clean room required? Medical Device and FDA Regulations and Standards News 6
C Clean room injection molding, raw material mixing requirements ISO 13485:2016 - Medical Device Quality Management Systems 2
C Raw material Mixing / Preparation for clean room class C injection molding Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
A Construction of an ISO 8 Clean Room - ISO 14644-1 Manufacturing and Related Processes 2
P ISO 5 Pharmaceutical clean room design Process Maps, Process Mapping and Turtle Diagrams 2
O Clean room performance qualification (pq) - How many times can I do each test? Manufacturing and Related Processes 8
O Localized clean room dust extraction system coupled in HVAC - Manufacturing solid dosage form Manufacturing and Related Processes 9
I Clean room recovery program Other Medical Device and Orthopedic Related Topics 1
M ISO 7 Clean Room Requirements? ISO 13485:2016 - Medical Device Quality Management Systems 4
M Scarf in Clean Room instead of Hair cover? Manufacturing and Related Processes 8
M What are ISO 7 Clean Room Requirements Manufacturing and Related Processes 0
S Should the primary drug containers be molded in ISO Class 7 clean room? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 6
S ISO 7 and 8 Clean Room Cleaning Other Medical Device Related Standards 2
S New clean room change submission - FDA Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
A Sterile Garbage Bag for Clean Room Manufacturing and Related Processes 6
D What should an ISO 14644 Clean Room PQ (Performance Qualification) look like? Manufacturing and Related Processes 3
N ISO 14644-1 Clean Room Occupancy State Validation Requirements Manufacturing and Related Processes 3
S What is the minimum pressure differential required for ISO Class 8 Clean Room? ISO 13485:2016 - Medical Device Quality Management Systems 3
V Not using gloves in Clean Room Class 8 (ISO 14644) Manufacturing and Related Processes 21
M Bioburden testing for Class 10000 (Grade C) clean room ISO 13485:2016 - Medical Device Quality Management Systems 1
L How do I set a limits to cfu in an ISO class 7 Clean Room? ISO 13485:2016 - Medical Device Quality Management Systems 2
L Clean Room Monitoring Plan Other Medical Device and Orthopedic Related Topics 6
L AS9100 7.5.2 Special Processes - Clean Room Apply? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
G Clean Room Classification for Contact Lens Packaging ISO 13485:2016 - Medical Device Quality Management Systems 4
A Clean Room as a Controlled Environment - Requirements ISO 13485:2016 - Medical Device Quality Management Systems 12
D Do I need to test "as built" for an expanded ISO Class 8 Clean Room ? Other Medical Device Related Standards 2
S What are air changes are required for ISO Class 8 Clean Room? US Food and Drug Administration (FDA) 2
A Clean Room Qualification Regulatory Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
L FDA Inspection of Clean Room Processes 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
somashekar Determination of Clean Room Class for Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 1
E Do I need to audit the supplier supplying mop heads for our Clean Room ? ISO 13485:2016 - Medical Device Quality Management Systems 8
M What should be in an SOP for a Machine Operation - LAF Bench in our Clean Room ISO 13485:2016 - Medical Device Quality Management Systems 3
P Clean Room Calibration (Validation) Other ISO and International Standards and European Regulations 4
C Recommended Sealing for Granite Top in a Clean Room US Food and Drug Administration (FDA) 1
L ISO 14644 Class 7 Clean Room Requirements Training Presentation Training - Internal, External, Online and Distance Learning 2
K SPC to apply for Particle in Clean Room Class 100 Statistical Analysis Tools, Techniques and SPC 7
V Updated Clean Room Classification Table of ISO 14644 Other ISO and International Standards and European Regulations 2
N Clean Room Validation and Certification Methods and Definitions ISO 13485:2016 - Medical Device Quality Management Systems 2
S Clean Room Training for Manufacturing Operators (Personal Hygiene, Gowning, etc.) Other Medical Device and Orthopedic Related Topics 4
J Yearly Cleanroom Revalidation Test Requirements - Questions for users clean room ISO7 Qualification and Validation (including 21 CFR Part 11) 5
V AHU (Air Handler Units) and Clean Room References Qualification and Validation (including 21 CFR Part 11) 3
B Hospital Operating Room Regulations - Separate Entrances for Clean and Dirty Supplies Hospitals, Clinics & other Health Care Providers 4
J ISO 14644 - Monitoring Clean Room Particulates (Class 8 Cleanroom) Other ISO and International Standards and European Regulations 4
B Building a Class 10,000 Clean Room Manufacturing and Related Processes 2
A Identifying the Clean Room Requirements for a Medical Device in US and EU ISO 13485:2016 - Medical Device Quality Management Systems 3
G Is Microbiological Monitoring required for Clean Room? Other Medical Device Regulations World-Wide 8
R Clean Room Validation Requirements ISO 13485:2016 - Medical Device Quality Management Systems 7
