Cleaning instructions for our non sterile, single use products
Annro
Hi :bigwave:
I have recently been asked for cleaning instructions for our non sterile,single use products.My first thought was are they reusing them, which they don`t. Could anybody tell me if you have to provide these instructions for non sterile single use products, if so a little bit of advice on how i go about it would help.
Thanks:thanx:
somashekar
Re: 13.6 ESSENTIAL REQUIREMENTS
Hi Annro.
Welcome to the COVE.
What device is your's ?
Who asked you .... The customer ? of the NB auditor ?
How does it go about getting handled during the production, and finally before your packaging, do you have a stage to clean it ?
When you agree that the device you make has to be both effective and safe, are you doing anything about possible / probable contamination of your device before it gets packed ?
Depending upon what type of device it is, you may have to consider this final cleaning stage that will disinfect and clean the device.
Clinically clean is a catchy word that is often used in your situation. Is your device clinically clean ?
As an example, we have a cable accessory that we make. It passes through various hands of various operators. Though we have established a clean and hygienic environment and workforce. we do have a final clean and inspection stage just before the pouch packing. This in our case is as simple as giving a good wipe with a soft tissue dabbed in IPA.
Ronen E
Problem Solver
Moderator
I agree, it really depends on the intended use. You are required to provide the user with all information that is required for safe use.
Annro
Hi Somashkar
The Device is silicone nasal splint and the customer has asked for this. Their process when having purchased non sterile products is to put them through a washer disinfector before sterilization ,they want verification that they can do this with our product. We provide sterilization instructions with the product but have not been asked before for the washer disinfector.
The product is done in a class 8 clean room, washed and dryed before packaging.
Thankyou for your reply Somashekar
Ronen E
Problem Solver
Moderator
So I gather that you (the manufacturer) do not deem such additional pre-sterilization cleaning & disinfection necessary, and by face value it seems reasonable to me. Hence, it comes down to your customer's C&D process not harming the splint. My natural instinct would be that this should have been part of their selection and qualification process, before qualifying your product. However, the commercial situation could be such that you'd want to volunteer performing such a verification / validation for them and providing a final report.
I wouldn't go as far as a mini-research to develop the most appropriate C&D method (which you deem unnecessary anyway), but it's really a mater of commercial relationship rather than a technical / regulatory issue, IMO.
Cheers,
Ronen.
somashekar
Hi Somashkar
A very important product related information in medical devices is the information about terminal sterilization process and the method used. This is a very important piece of information for the pre-sterilized device manufacturer to select the material, method and the final cleaning process as well as the work environment. All these will keep in check the challenge to the sterilization process. Please can you begin to look on these lines now. Better late then never.
Ronen E
Problem Solver
Moderator
But the OP has clearly stated:
We provide sterilization instructions with the product...
So as far as the unsterilized product manufacturer is concerned, the methods to ensure proper pre-sterilization cleanliness are already implemented in-house, and the instructions for matching sterilization are provided to the downstream buyer. The fact that a customer insists on adding an extra process (that may be redundant) has nothing to do with the manufacturer fulfilling their responsibilities.
D Cleanroom Cleaning Products and Storage Other Medical Device and Orthopedic Related Topics 18
A Reprocessing, Cleaning, Disinfection and Sterilization Validation EU Medical Device Regulations 4
R 510(k) Biocompatibility vs Cleaning Validation Other Medical Device Related Standards 4
M Cleaning Process after laser marking on orthopaedic implants Other Medical Device and Orthopedic Related Topics 3
John Broomfield Cleaning plastic from our oceans - The Ocean Cleanup Venture Sustainability, Green Initiatives and Ecology 29
E Cleaning Validation Process of Non-Sterile Implants and Instruments Other Medical Device Related Standards 2
E Labware cleaning validation protocol example Qualification and Validation (including 21 CFR Part 11) 1
A Cleaning plastic parts for sterilized medical devices ISO 13485:2016 - Medical Device Quality Management Systems 15
C Documenting Cleaning Production Lines in Medical Device Pkg facility ISO 13485:2016 - Medical Device Quality Management Systems 1
C Documenting Cleaning Production Lines in Medical Device Pkg facility 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
C Documenting Cleaning Production Lines in Medical Device Pkg facility 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D ISO 13485 production cleaning requirements of reusable devices ISO 13485:2016 - Medical Device Quality Management Systems 2
P Production Line Pump Cleaning Validation Method Question Qualification and Validation (including 21 CFR Part 11) 0
S ISO 7 and 8 Clean Room Cleaning Other Medical Device Related Standards 2
I Material for PUW used to cleaning Other Medical Device and Orthopedic Related Topics 1
I Implantable medical device cleaning validation Other Medical Device Related Standards 3
S Looking for ISO Class 8 Cleanroom Cleaning Procedure example ISO 13485:2016 - Medical Device Quality Management Systems 1
P Cleaning and Disinfection Validation Sample Size of 3? Other Medical Device Related Standards 2
O Cleaning API Rotary Shoulder Connections Working Mates exposed to Outside Weather General Measurement Device and Calibration Topics 1
R Cleaning validation for Molding Tools? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
P Best Method of Cleaning of Thread Ring Gages Calibration Frequency (Interval) 5
E Cleaning Validations for Reusable Products - ANSI/AAMI TIR30:2011 Requirements Other Medical Device Related Standards 3
C Small Cast Iron Part Cleaning Manufacturing and Related Processes 7
S Cleaning Fluids and RoHS2 Declaration Requirements RoHS, REACH, ELV, IMDS and Restricted Substances 2
A Cleaning of Medical Device Storage Areas ISO 13485:2016 - Medical Device Quality Management Systems 1
N Using Ozone as a Cleaning Agent in Purified Water Manufacturing and Related Processes 2
R Best Practices in the Control of Cleaning Materials Document Control Systems, Procedures, Forms and Templates 1
W Production Equipment Cleaning Protocol Example Needed Other Medical Device and Orthopedic Related Topics 2
V Standard for Cleaning and Washing Metal Stampings Other ISO and International Standards and European Regulations 2
W Cleanroom Cleaning Agents for cleaning a Class 7 Cleanroom Other Medical Device and Orthopedic Related Topics 9
G ISO 17664 Reusable Low Risk Medical Device Cleaning Other Medical Device Related Standards 2
B Isopropyl Alcohol cleaning of Peek Optima ISO 13485:2016 - Medical Device Quality Management Systems 5
N Seeking information on use of Byotrol Cleaning Chemicals in Pharma Industry Manufacturing and Related Processes 1
S Glass Bead Blast Cleaning Spec TT-C-490 Rev D Various Other Specifications, Standards, and related Requirements 1
L Can I produce Cosmetics and Household Cleaning Products in the same Facility? US Food and Drug Administration (FDA) 4
L Nutritional, Cosmetics and Cleaning Products in Same Facility Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
G Sampling Plan - Sample Size Justification for a Bottling Cleaning Process Validation Qualification and Validation (including 21 CFR Part 11) 2
M Cleaning Resuable Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 11
I Cleaning Validation for Durapore Tape Cutting Machine EU Medical Device Regulations 2
R Cleaning Validation Protocols for a Pharmaceutical Company Qualification and Validation (including 21 CFR Part 11) 2
S Using 93 % alcohol for cleaning Printer Head Manufacturing and Related Processes 2
E Ultrasonic Cleaning of Orthopedic Implants - Detergents and Frequency - How? Other Medical Device and Orthopedic Related Topics 3
Sidney Vianna Cleaning up the Global Compact: Dealing with Corporate Free Riders Sustainability, Green Initiatives and Ecology 2
M Cleaning of Orthopaedic Implants before Sterilization ISO 13485:2016 - Medical Device Quality Management Systems 15
M Demineralized (DM) Water Specifications - Cleaning Orthopaedic Implants Quality Manager and Management Related Issues 4
F Airport Internal Audit Checklist (Cleaning, Project Process, Maintenance, etc) Internal Auditing 3
S Cleaning Validation NOEL and MACO - Non Human Products Design and Development of Products and Processes 2
J Equipment for Cleaning various materials over a Wide Area Manufacturing and Related Processes 5
I Validation of Ultrasonic Cleaning Process for Basic Tools & Buffing Compound ISO 13485:2016 - Medical Device Quality Management Systems 5
T Cleaning Industry Management Standard (CIMS) Various Other Specifications, Standards, and related Requirements 4
