Cleanroom Differential Pressure Monitoring, frequent manual observation
I had a quick question regarding how my job has set up their cleanroom monitoring plan. At the moment, the differential pressure is quantitatively defined once a year during our cleanroom re-certification. In the ISO 14644-2, it says "the pressure differential may be monitored by periodic observation or by automated instrumentation." We don't quantify the pressure ever, but we are supposed to daily check if there is air flow out of the cleanroom grill with our hands. Is that a common practice/ in compliance? Does this require an alert and action limit, and if so, how do we feasibly do that if we don't have much data. I don't necessarily know what they mean by 'periodic observation' and I want to make sure we aren't behind when it comes to how everyone else does it.
Thank you!
indubioush
Here is how we do it. We have a designated person who checks the calibrated pressure gauges every day to see that the pressure cascade is present. We have a log where we down this check to indicate that the pressure is above the minimum specification. We have our pressure gauges calibrated annually. Also, pressure is checked during clean room monitoring. We trend the pressure values through our monitoring data.
Do you have pressure gauges set up so you can see the actual values?
No, we don't have any type of gauge installed. But thank you for letting me know what you do! I am trying to see what seems to be common practice, thus I may try to initiate the change so we match it. Have you heard of a cleanroom without a gauge or equipment to measure pressure?
Differential pressure needs to be monitored for the cleanroom to understand the airflow to avoid any sort of contamination by particulates, and also to understand the pressure cascade between adjacent rooms. Most common are the magnehelic gages but if your clean rooms are not installed with magnehelic gages, you could either install one or can measure the differential pressures using mobile meters.
BradM
Agree with Ajit. If you don’t have anything yet,
I would purchase some pressure transmitters with alarm contacts that could print to a chart recorder. Set the alarm up to operate a red alarm light or something. You could purchase a spare to switch out for calibration.
I know a chart recorder is ancient. :) But wouldn’t require validation like a computer storage program.
Jen Kirley
Quality and Auditing Expert
To add to Ajit and Brad's advice, the chart recorder (yes I know they are ancient technology) leaves you with records supporting the cleanroom's air system is functioning within parameters.
P ISO 14644 Class 8 Cleanroom Air Filter Requirements Other Medical Device Related Standards 4
C Cleanroom - 209E to ISO14644 Other Medical Device Related Standards 2
P Surgical masks ( type IIR) - Cleanroom Requirements EU Medical Device Regulations 3
J Need for a cleanroom in the manufacture of a medical device for a clinical trial EU Medical Device Regulations 4
D Cleanroom Cleaning Products and Storage Other Medical Device and Orthopedic Related Topics 18
chris1price Cleanroom Monitoring Plan - ISO14644-2:2015 - Risk Assessment Other Medical Device Related Standards 3
C Looking for source of silicone contamination in ISO Class 8 Cleanroom Other Medical Device Related Standards 2
I Cleanroom Actions in case of Actions Limit Alarm Qualification and Validation (including 21 CFR Part 11) 3
W How to bring Cardstock into Cleanroom Environments Manufacturing and Related Processes 1
S Looking for ISO Class 8 Cleanroom Cleaning Procedure example ISO 13485:2016 - Medical Device Quality Management Systems 1
D Use of hand cream inside gloves in the cleanroom for medical devices Occupational Health & Safety Management Standards 7
T Converting an ISO Class 8 Cleanroom to ISO 7 Various Other Specifications, Standards, and related Requirements 4
jkuil Cleanroom Equipment and Furniture Engineering Standards Other Medical Device Related Standards 2
T Cleanroom Certification Duration Other ISO and International Standards and European Regulations 1
E ISO Class 8 Cleanroom Qualification Protocol Template Other Medical Device and Orthopedic Related Topics 6
B Cleanroom Control Limits: Cumulative or individual? Statistical Analysis Tools, Techniques and SPC 11
I FDA Cleanroom requirements for class II in vitro medical devices US Food and Drug Administration (FDA) 1
C Cleanroom Disaster Recovery for ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 8
A Guidance for Cleanroom Qualification and Validation relevant for EU and USA ISO 13485:2016 - Medical Device Quality Management Systems 2
E Is Volumetric Air Sampling required for Class ISO 7 Cleanroom ? ISO 13485:2016 - Medical Device Quality Management Systems 1
B How to set Cleanroom Alert and Action Limits as part of Microbiological Evaluation Quality Assurance and Compliance Software Tools and Solutions 8
C What is an acceptable bioburden level or count when working in cleanroom ISO class7 ISO 13485:2016 - Medical Device Quality Management Systems 1
W ISO 14644 Cleanroom Validation - "Operational" Other Medical Device Related Standards 3
E A sink with water in an ISO Class 7 Cleanroom ISO 13485:2016 - Medical Device Quality Management Systems 4
W Thoughts on having Safety Shower in ISO Class 7 Cleanroom ISO 13485:2016 - Medical Device Quality Management Systems 5
C Cost Factors of Iso 8 vs. ISO 8/9 Cleanroom Other Medical Device and Orthopedic Related Topics 2
W Cleanroom Cleaning Agents for cleaning a Class 7 Cleanroom Other Medical Device and Orthopedic Related Topics 9
V Making Solar cells, Module, String - Which Cleanroom Level? Various Other Specifications, Standards, and related Requirements 2
H What is the ISO Class 7 cleanroom requirement on Temperature and Humidity ? Manufacturing and Related Processes 3
J Do I need a Cleanroom to manufacture Medical Devices? ISO 13485:2016 - Medical Device Quality Management Systems 4
C ISO 13485 Class 7 Cleanroom Requirements ISO 13485:2016 - Medical Device Quality Management Systems 7
J Yearly Cleanroom Revalidation Test Requirements - Questions for users clean room ISO7 Qualification and Validation (including 21 CFR Part 11) 5
J ISO 14644 - Monitoring Clean Room Particulates (Class 8 Cleanroom) Other ISO and International Standards and European Regulations 4
D Cleanroom Housekeeping and Personnel Hygiene Audit Checklist Other Medical Device Related Standards 25
C Cleanroom Class 8 (100,000) Particulate Control and Warning Limits Statistical Analysis Tools, Techniques and SPC 1
N Dehumidified (Dry) Cleanroom - Running a Cleanroom at very low RH Manufacturing and Related Processes 23
somashekar Use of Pencil in Class 1000 Cleanroom ISO 13485:2016 - Medical Device Quality Management Systems 12
S Cost Surrounding Cleanroom Construction Manufacturing and Related Processes 4
M Cleanroom Qualification and Standard Cleanroom Audit Checklist Process Audits and Layered Process Audits 6
C Pest Control - FDA approved list of Pesticides to use for Pest Pontrol in a Cleanroom Other Medical Device and Orthopedic Related Topics 10
B Checklist for Housekeeping and Cleaning of Class 10k Cleanroom? Other Medical Device and Orthopedic Related Topics 17
R Cleaning Procedure for a Cleanroom Class 7 & 8 ISO 13485:2016 - Medical Device Quality Management Systems 2
L Cleanroom Requirements for Nuclear Components Assembly Design and Development of Products and Processes 4
L Validation of transfer materials - Bioburden of items from lab into cleanroom Other Medical Device and Orthopedic Related Topics 2
A Cleanroom class in semiconductor Other ISO and International Standards and European Regulations 8
A Particle Counter Results - Interpreting Data for a Class 100,000 Cleanroom Other Medical Device Related Standards 12
H Cleanroom vs. Clean hood - MIL-PRF-38534, Class K (space level) for hybrids Manufacturing and Related Processes 3
H Cleanroom Class for hybrids Manufacturing and Related Processes 6
M Cleanroom Gowning Disposable Lab Coats - Class 8 Cleanroom ISO 13485:2016 - Medical Device Quality Management Systems 4
Ajit Basrur Does anyone have a Cleanroom audit checklist? ISO 13485:2016 - Medical Device Quality Management Systems 12
