Hi all,
I need guidance on validating an ISO Class 7 cleanroom. We are a startup manufacturing an implantable medical device, which will be gamma sterilized after being packaged inside the cleanroom.
Although I’ve read the ISO-14644 standard, I feel overwhelmed by its length and numerous sections. I know the FDA doesn’t mandate a specific cleanroom testing method, I’d like your advice on what tests are truly essential so I can better prioritizing what is really required.
I know that the airborne particle testing is required, and I’ve purchased settling plates to test during the operational state. However, how often should these tests be conducted?
Do we need to always monitor temperature and humidity?
P.S the cleanroom will come with a controller that will monitor the pressure difference and the air changes every 10 seconds.
Other than that what is required to be tested weekly/monthly/annually?
Thank YOU!
Thank YOU!
