Clearance and Creepage according to Subclause 8.9.1 for MOPP IEC 60601-1
In the subclause 8.9.1 of IEC60601-1 what is the meaning of the "highest peak value of the withstand voltage" in the case of applied part MOPP. How to determine the clearance from this value? Does this mean we do not need the table 12 for clearance?
Can we also determine the creepage from table 12 with long term RMS according to this subclause?
Peter Selvey
For MOPP, Table 12 only uses Vdc or Vrms, the peak value does not have any impact (there is a long story and history behind this).
The phrase "long-term" only appears in the informative appendix. Strictly speaking, "rms" needs to have supplementary definition of the time or period in which the averaging is done (since rms = root-mean-squared, it has to be defined over what period is the mean calculation). I could not find anything in IEC 60601-1, but generally for stable repetitive waveforms this is taken to be over one full period of the waveform, during the time in which the circuit is energised. Also for reference, most rms responding instruments use around 1-2s period for the averaging, which should give the same result provided the waveform is stable.
The general standard does not take into account circuits whether or not the circuits are energised continuously. However, some particulars have much lower values in part due to recognition that many functional circuits are not subject to long term stress (e.g. IEC 60601-2-4 for defibrillators).
Hello there
I have a (partly) related question.
In case of the defibrillation shock, IEC 60601-1 clearly states the clearance / creepage distances between the (patient connections of the) the protected applied parts and the rest of a device (>= 4 mm).
However, I could not find any clear statement about the distances between the body itself and other conductive parts of a device?
In our case, the device has no patient connection in the sense of IEC 60601-1. However it has externally accessible charging pads used for charging an internal battery (the charger is not connected in normal operations) .
Could you enlighten me on the clearance / creepage distance that we should consider between the patient's body and these pads, to avoid having to consider the pads as protected applied parts falling under 8.5.5.1 and 8.5.5.2 ?
Is it reasonable to say that according to table 2 of 60664-1, and considering modern biphasic defibrillators between 1.5 and 2 KV, we could consider a clearance of 1 mm ? And if so, what is the probability to find older defibrillators delivering higher peaks in real life?
Or should we be conservative and consider a distance of 4 mm corresponding to a peak of 5 Kv, following the same rationale as developed in IEC 60601-1 Annexe A page 267 for the protected applied parts?
(Of course, the pads as protected against ESD, but although in that case the voltage of the peak is much higher than the defibrillation shock, the duration is also much shorter)
Thanks so much, Francois
Hello
8.4.2c is applicable to the leakage currents (generated by the device itself), which I think is a different case. My question relates to the (external) defibrillation voltage, and the minimal clearance distance required to avoid having to consider the charging pads as protected applied parts falling under 8.5.5.1 and 8.5.5.2, considering the risk that the defibrillation current might traverse the air gap between the patient's body and those pads and consecutively put the device (not the operator) at risk.
H Secondary Circuits, Voltage Test and Clearance/Creepage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
S Some confusion about the creepage and clearance distance? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
N Question on creepage/clearance requirements for HF Active Accessories for 2nd edition 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
R Components in parallel to creepage\clearance IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
H Defib Protected Applied Parts: 4mm clearance/creepage? IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
A IEC 60601 Creepage and Clearance Requirements on PCB IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
A Secondary Circuits, Voltage Test and Clearance/Creepage IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
F MOP (Means Of Protection) - Creepage and Clearance questions IEC 60601 - Medical Electrical Equipment Safety Standards Series 19
R Creepage and air clearance under vacuum conditions IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
N PCB Creepage and Air Clearance on 8 Layer Boards IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
D Creepage and Clearance for high voltage low energy circuits IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
G Creepage and Clearance Distance for MOOP on Secondary Circuit IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
C Creepage and Clearance for CR2032 powered fob for a Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
T IEC 60601-1 Conformal Coating not an acceptable mitigation for creepage and clearance IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
H SOP Template for seeking regulatory clearance - MDSAP Document Control Systems, Procedures, Forms and Templates 6
6 MSA for Calculated Clearance Dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J Leveraging FDA 510k Clearance for International Registrations Other Medical Device Regulations World-Wide 2
M Regulatory clearance pathways for surgical masks/N95 respirators Other US Medical Device Regulations 3
K Completing Design Controls after 510(k) Clearance Other US Medical Device Regulations 11
O Hospital-Developed, In-House Device - FDA Clearance? Other US Medical Device Regulations 19
M Informational TGA presentation: How to submit an effective good manufacturing practice clearance application Medical Device and FDA Regulations and Standards News 0
J China NMPA medical device submission timelines and clearance rates China Medical Device Regulations 2
B 510(k) clearance claim on medical device product packaging Other US Medical Device Regulations 6
M Informational US FDA final guidance – Marketing Clearance of Diagnostic Ultrasound Systems and Transducers Medical Device and FDA Regulations and Standards News 0
C Shipping Medical Devices to US before pre market clearance US Food and Drug Administration (FDA) 1
F Importer and US agent needed after FDA clearance? Other US Medical Device Regulations 2
K ISO/IEC 27000, ISO 15408 and the DSS security clearance (FCL) -- Oh, My IEC 27001 - Information Security Management Systems (ISMS) 0
Ron Rompen Question on 'Class of Fit' - Gage Pin Clearance Manufacturing and Related Processes 2
A 61010-1 Accessible Parts - Limit Values and Crepage and Air Clearance Distances Other Medical Device Related Standards 1
A Infusion Pump - Pre-Clearance Inspections Learnings US Food and Drug Administration (FDA) 4
E Internal clearance distance according to 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R Floor Marking Colors - Clearance Area in front of Electrical Panels Occupational Health & Safety Management Standards 6
M FDA Wall Clearance Requirements For Warehouse 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
S How to determine the Air Clearance for Floated Secondary Circuit IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
V Should the Line Clearance include Machine Setup for current Operation? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
R Distribution of a Device by another company - Questions about 510 (K) Clearance US Food and Drug Administration (FDA) 6
M Employee Transfer, Separation and Clearance Procedure and Forms ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B Line Clearance Failures and Issues ISO 13485:2016 - Medical Device Quality Management Systems 2
P Batch to Batch Change Over Line Clearance Checklist Manufacturing and Related Processes 26
B 510K Clearance Application 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C Procedure for Security Clearance to a security clearance access area Document Control Systems, Procedures, Forms and Templates 5
W Can a CSA-US certificate substitute a FDA 510(k) clearance? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
T List of regulatory steps to obtain market clearance in different countries ISO 13485:2016 - Medical Device Quality Management Systems 4
J Line Clearance - What is the ISO 13485 / regulatory guidance? ISO 13485:2016 - Medical Device Quality Management Systems 6
S Gage pin clearance on close tolerance - Hole size is ?.8746 ? .0001 General Measurement Device and Calibration Topics 9
D Line clearance - Routine components in the prep room for universal use ISO 13485:2016 - Medical Device Quality Management Systems 8
D Interpolation of creepage distance IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
B IEC 60601 - Creepage Distance - Relay that acts as a means of physical mechanical protection Process Maps, Process Mapping and Turtle Diagrams 0
S Creepage distance IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
N Electrosurgical generator with switchable sockets - creepage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
