Client's Order Dock Inspection before Shipping
L
luciano.rossato
Hello there!
My name is Luciano and I work at a warehouse of a metalwork company at Gravata?, near Porto Alegre, Rio Grande do Sul, Brazil. This is my first topic, so I hope I'm posting it at the right place.
My company is having some issues on the quantity sent to one of our clients. Sometimes, it?s more than ordered; others, it?s less. Since our picking process is divided by client, my first attempt was checking how the picker for this client was doing his job. Did not found anything unusual but still, I started double-checking the order from this client before shipping. The thing is, the problem persisted and I'm starting to suspect of the client's receiving process.
Since asking the client to double or even triple-checking could be aggressive and I can't be sure that our counting is 100% right (since it's human made), I was thinking about implementing a more automatic-fail-proof process for this dock inspection: using a weighing scale to check the weight of each box and keep a record of what it's being shipped to the client.
That way, I would have a more accurate information of what I'm sending to the client and could be more emphatic when divergences occur.
What Elsmar Cove think about this?
Thank you all in advance!
Jeff Frost
Weight count would be one method but even so there will also be some measurement error possible. The simplest method would be to talk to your customer about what you have implemented and then ask how they are going it. If possible, go and see how they are doing it.
insect warfare
QA=Question Authority
Welcome to the Cove, luciano.rossato! :bigwave:
Asking your client to perform multiple inspections may not add any value to your relationship with them. In fact, it may make things more tense. Seeing as they are a client of yours, you want their processes to be just as efficient as yours are.
If you suspect that this client could be the source of your issues, set up an on-site audit of that supplier's receiving processes (if it is within your capabilities). This is commonplace for many companies who have these types of issues with their suppliers. If you can, also review their contractual obligations to see what you actually require of them as a supplier. Verify if their process controls are working (you will know if they're not), and be sure that you can accurately trace their records backwards to your own facility. If you find serious issues with their controls, you can use the results of your evaluation to determine if they need to be replaced by a more capable supplier (or to flex a little business muscle to leverage better practices from them).
From your post, I doubt there is any pilferage going on in-transit, but it would still be a good idea to check your transportation carrier's controls as well. Your responsibility to provide good product (at the right time and in the right quantity) should not end at your shipping dock door.
Brian :rolleyes:
P
PaulJSmith
Welcome to The Cove, Luciano!
Our company had a similar problem a few years ago, just before I came here. They implemented a triple check of every order shipped, and added me in as a fourth layer about a year ago. Now, every completed order gets an initial check by the technician who finished and packaged it, then another check by a second technician, then the Production Manager checks it, then the Quality Manager (me) checks it. We all sign off that everything is present and correct before the shipping cartons are sealed and shipped. It may seem like overkill, but we no longer short anything to our customers. It's amazing how many times one or two sets of eyes will miss something.
My point is, it's really first and foremost incumbent on you as the supplier to ensure you are doing everything you can to ship the correct order. If it takes three or four different people to review the order, then so be it. You won't have to do this very long before you see where the errors are occurring.
As to the idea of weighing the cartons, that may work, too. It also may end up being a bigger headache than you have now. If your product is always shipped in known quantities and there is no deviation in the packaging, your cartons should have the same weight every time. If not, you'll probably find yourself opening and counting anyway.
Just be sure your own process is correct before questioning that of your customer. As Brian said, that route may not be the best for your business relationship.
Bill McNeese
Good responses from eveyone. I think Jeff gave you some good advice. Ship an order and be there when it arrives at the customer to see what they do. Compare it to what you think you shipped. As far as in house .....
I would be beware of having too many people checking the order. Having two people responsible for the same thing means no one is. If you pick that path, make sure the people checking do not know what the other person found out.
For example, suppose you and I are checking an order. You check it first and sign off on it. I check it second and then sign off on it. Another order arrives. It is a tough day, late you want to go home. You are checking that order. You do it a little more quickly than normal - avoid getting home late plus you know I will check it as I always do and I am wonderful. :)
I get the order to check - I know you do a great job on this. So, I want to go home. I just sign off. Order goes out without really being checked. Maybe we get lucky, maybe we don't.
Lesson: if you have multiple checks, make sure they are independent - this means they do not know what anyone else found out.
Suppose you and I are both 90% accurate. We both check an order independently. What are the possible outcomes:
We both agree: .9 x .9 = .81
One says yes, one says no: 2(.9*.1) = .18
Both say no and are wrong: .1*.1 = .01
So 81% of the time we agree that the order is correct; 18% we disagree - order is stopped; 1% of the time we agree the order is correct when it isn't.
We go from 10% wrong to 1% wrong by having independent checking. Nice improvement.
So, if you must use multiple checks, please make them independent. And sometimes you must do that. But in the meantime, work on the process. And share your results with the customer.
L
luciano.rossato
Thank you all for the great answers! That was quite exciting. :thanx:
Triple-checking, or even quadruple, could be a solution, but probably we would need to hire more people to do this. It would take a lot of time and since we work with milk run and are a quick response supplier, things have to be fast. From my boss perspective, hiring more people, for now, is not an option. I also tend to think like Bill and prefer to avoid too many people handling the parts. The valour added, in my situation, is not compensated by the cost involved. :(
I'm aware that the scale method could not be a 100% failure-proof, since I could have different packages and all, but at least would be a more accurate registry of what is leaving the warehouse. We would keep the weight of each box history and if the client complain about any specific part, we would be able to verify what we sent not just with human-made data, but also with machine-made ones. Besides, would be a good tool for the pickers to check their job.
I must confess that I'm a little bit worried about people relying too much in the weight and not giving much attention to the counting in the future. I'll have to think about how I will introduce this process here and document it properly to avoid problems.
About the suggestions of asking for an audition at the client's receiving process. Would be a good way of discarding an error at the client process, but since my company have a history of shipment problems (got this from my boss, it's just my first month working here), I would like to have more accurate data before making this move and showing that I'm suspecting of them. As Brian and PaulJSmith said, I'm assuming that I must be sure of my process before checking for other reasons. And also, from what I understand of my company until now, they are just starting to implement a more serious approach of auditions and quality processes, so probably asking for an audition now would be awkward. Besides, a visit is already being planned for me to know our client. I'll use this opportunity to do what Jeff said and audit them (and at the same time me), but in a quiet way.
About Brian's remark on transportation, I also doubt that there is any problem, but indeed, I can't discard this possibility.
Bill's analysis using simple probabilistic was quite an insight. I totally forgot that I could use this kind of approach to get better sight of my options. :frust:It's time to put in use all that learning in Econometrics.
Also, like many of you suggested, I'll start to have a more direct contact with the client's receptor, informing what we are doing. The guy that does this now is the operational leader of the warehouse and sometimes the information is lost in its way.
Thanks again!
C Client Order Data Error Tracking ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Can a Contract Manufacturer "release" product on behalf of client to the market? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
T Client Communication - SaaMD company Misc. Quality Assurance and Business Systems Related Topics 3
S Moving from client-server to cloud-based, is that a new submission? Medical Information Technology, Medical Software and Health Informatics 3
J Medical Device Registration in Argentina - Client asks us to provide “European FSC” Other Medical Device Regulations World-Wide 4
S Client Audit Question - Entitled to see all of our documents in an audit? General Auditing Discussions 4
S Contract Packager or Repackager? And can client assume responsibility? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
M Auditing processes followed by employees placed on client's site Internal Auditing 4
D Definition Client - How does the government define their clients? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 1
N Any comment, if a supplier raise an NCR to the Client? Oil and Gas Industry Standards and Regulations 5
Q Drawings from Client - ISO 9001:2008 Clause 4.2.3 or 7.5.4? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Best Method of Auditing an Installation Process at a client job-site ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Howard Atkins Rules 4th Edition Areas of Impact for Client Consideration IATF 16949 - Automotive Quality Systems Standard 1
Ajit Basrur Credit Suisse - Advertising Client Campaign Coffee Break and Water Cooler Discussions 1
C OHSAS 18001 and a site visit - All our work is on client sites Occupational Health & Safety Management Standards 4
N Client Request for Reference Equipment Calibration Certificate General Measurement Device and Calibration Topics 3
C ISO 13485 - Client Specific Validation and CE Marking CE Marking (Conformité Européene) / CB Scheme 3
L ISO9001:2008 - Applicable clause for sending incompetent crew to client Service Industry Specific Topics 7
L Client that refuses to help - How to handle ? Misc. Quality Assurance and Business Systems Related Topics 5
I When the client seems to get involved in functions of our organization Quality Manager and Management Related Issues 6
S Should Client Controlled Procedures be Controlled Internally by us as well? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
T Medical Device Software Verification & Validation for Client Specific Configurations Design and Development of Products and Processes 2
Q Managing Internal and Client Complaints ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q Sales, different products/path to client, should be pictured each in Process Maps? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
B QCP (Quality Control Plan) from client with EN 10204 type 3.1 Material Certificates Various Other Specifications, Standards, and related Requirements 2
Q How to Audit the Client Quality System - Product Failure caused by no Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Q Maintenance Schedule with Client in my Procedures? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q Content and Details of a Client (Customer) Claim Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Client requires to witness an Internal Audit of our Sub-Contractor Internal Auditing 4
D How to implement Control of Employee Access to Client Data IEC 27001 - Information Security Management Systems (ISMS) 2
D Classification of Client (Customer) Complaints ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
C CB Client Contract Agreement - Identifying nonconformances - AS9100 Registrars and Notified Bodies 7
I In ISO 9001:2008 - Can we show an Internal Department as our Client/Customer ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
V ISO 9001 Consultant + Welding Inspector for Same Client - Conflict of interest? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Howard Atkins # Rules 3rd Edition Areas of Impact for Client Consideration IATF 16949 - Automotive Quality Systems Standard 1
L Client asking for us to perform VDA 275 - VDA questions VDA Standards - Germany's Automotive Standards 1
Sidney Vianna ANAB Accreditation Council Drafts Client Bill of Rights ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 2
F Document Control of client-specific instructions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
SteelMaiden Scrap Trader Kidnapped? UK scrap trader kidnapped by Chinese client World News 5
S Construction Projects - Client & contractor - System compatibility issues Quality Manager and Management Related Issues 4
M Service Level Agreement between Software Vendors and Client - Need help Urgently Software Quality Assurance 5
H Can the documents supplied by the client categorised as customer property?? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
CarolX Which BitTorrent Client do you use? After Work and Weekend Discussion Topics 18
D Can an unsatisfied client withhold the consultant's fee? Consultants and Consulting 14
A Net Promoter Score (NPS) for Analyzing the Client Satisfaction Misc. Quality Assurance and Business Systems Related Topics 3
J As a consultant, have you ever fired a client? If so, when? Consultants and Consulting 54
A Should I use "Client" or "Customer" in my documents? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
D Can both the Client and the Candidate be the Customer in a Recruitment scenario ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
P Architect's Client Doesn't Know What He Wants - Contract Review Process Contract Review Process 17
D Auditing Ethics - Lead Auditor solicited client for training General Auditing Discussions 6
