@Junn1992
I wanted to know your opinion, the CER will only be updated in case the new risk detected changes the Benefit/Risk ratio, is that correct?
In other words, if control measures can be implemented for the detected risk, so that its severity and frequency can be considered as acceptable, I understand that it would not be necessary to update the CER, since the benefit/risk ratio did not change, is that so?
Thank you,
