Closing out an API/ISO QMS Audit Nonconformance - Magnetic Particle Examination
roneljdsilva
Hey guys,
it's been a while since I've last posted here and hope you all are keeping well fellow professionals in quality.
I am currently closing out findings from my last API/ISO QMS audit and I am having problems coming up with a solution to as follows:
The QC inspector performing magnetic particle examination (MPI) did not use a light source to ensure light intensity was over 1000 lux while performing the examination. Using a light source is also a requirement of our procedure. Now the question the reviewer is asking is why the procedure hadn't been followed and that corrective action has to include additional controls.
How do you ensure inspectors carry all required equipment prior to performing their examinations?
I've been struggling to come up with a practical control measure to satisfy this requirement and I need my fellow covers expertise.
In advance,
:thanx:
Ron
AMIT BALLAL
Re: Need help closing out an audit nonconformance!
Hi!
This issue seems of human error. I also faced same issue in past.
Root cause can be:
Although procedure is available which specifies the steps to be followed, it was missed by the inspector to follow some steps. This is because, there is no error proofing available to prevent such incidence due to human error.
Probable corrective action:
Modify the procedure and incorporate the sequence to be followed to make it a SOP. It should specify steps to be followed (Standardized sequence) in detail.
Reason behind that is, if we follow a standardized sequence (Following a SOP) - such problems of missing can be prevented.
If no. of checks to be provide are more, you can also use a checklist thereby preventing missing of any check.
Corrective action to be written:
Standard sequence has been defined and incorporated in SOP i.e. to be followed during magnetic particle inspection. This shall be followed by each inspector performing the test, so that the problem of missing of any check can be prevented.
Or
A checklist has been prepared which specifies checks to be done prior to magnetic particle inspection. This shall be used by each inspector performing the test, so that the problem of missing of any check can be prevented.
Identify what applies to your organization. This is just an example.
I hope this helps!
Thanks,
Amit
yodon
I'd be a bit hesitant in writing new SOPs / WIs, etc., until I understood things better. For example, why didn't they use a proper light source? Is it really necessary? Is it available? Did they know they were supposed to use one and just ignored it? Are they being pressed for time and it takes too long to set up?
I can think of a number of elegant solutions but they may not even be appropriate given the possible circumstances.
Sidney Vianna
Post Responsibly
Your process HAS TO BE user friendly; otherwise it becomes too restricting for the operators. You can not seriously expect the operators to check the light intensity during each inspection. That will make their jobs too slow and inefficient.
The recommended times and frequency for the check of the UV light intensity is to be performed when a new bulb is installed, at startup of the inspection cycle, if a change in intensity is noticed, or every eight hours of continuous use. Regularly checking the intensity of UV lights is very important because bulbs lose intensity over time. In fact, a bulb that is near the end of its operating life will often have an intensity of only 25% of its original output.
Source.
AMIT BALLAL
If it is a human error such as missing:
Add the checkpoint of lux level (Process characteristics) in your magnetic particle inspection report format, so that same can be checked and chances of missing can be eliminated.
If you can tell us the primary cause, we'll be help you in better way.
Thanks,
Amit
E
evocube
Either make the inspector carry a Calibrated light source meter OR what I have done in the past is verify the light source (flashlight) meets the minimum requirements for the code and "certify" the light source for a certain interval. LED (UV and white) lights annually. Mercury vapor/UV 3-6 months depending on if it is field or lab use.
F Closing a finding before closing meeting General Auditing Discussions 14
S RMAs & Closing Complaints ISO 13485:2016 - Medical Device Quality Management Systems 7
Z US Manufacturing Site Closing, device manufactured elsewhere Medical Device and FDA Regulations and Standards News 1
T Closing out CAR while waiting for design change Nonconformance and Corrective Action 12
J Any diverging opinions regarding audit findings or conclusions must be resolved no later than the closing meeting ISO 13485:2016 - Medical Device Quality Management Systems 13
R Major nonformance finding was given during a closing meeting of a ISO9001 certification audit General Auditing Discussions 76
W Closing of Stage 2 Audit Nonconformances AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
qualprod Closing Out Negative Issues in Context and Interested Parties ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Our local sterilizer is closing - Record Retention Question 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Wes Bucey Closing in on my Diamond Jubilee Covegratulations 0
J Internal Audits - Closing Audit Deficiency Reports (ISO 13485) Internal Auditing 4
C Recurring Nonconformance - Missing Deadline for Closing a Corrective Action Problem Solving, Root Cause Fault and Failure Analysis 14
N Timing for Closing High FMEA RPN Items FMEA and Control Plans 4
A One site of multi-site company closing - Quality transfer issues Quality Manager and Management Related Issues 7
M Closing of a Non Conformance Nonconformance and Corrective Action 5
M Process for closing complaint records after a period of inactivity? Quality Manager and Management Related Issues 2
S Having a hard time closing CAR/ PAR Nonconformance and Corrective Action 13
L How many ISO Standards are there and time allowed for Closing NCs? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q Closing Out a Corrective Action - Strictly what is an Evidence? Nonconformance and Corrective Action 8
T Effectively Closing 8D from Suppliers Supplier Quality Assurance and other Supplier Issues 4
C Re-Verification of Nonconforming Product prior to closing our DMR AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
A Closing CARs (Corrective Action Requests) due to Process Change ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q "Closing Out" Corrective and Preventive Actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
A Nonconformance for not closing an NC (Corrective Action) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
L Criteria to Establish a Relevant Due Date for Closing Corrective Actions Internal Auditing 8
A Benefits of Improving Lead Time on Closing Supplier Corrective Action Requests Preventive Action and Continuous Improvement 3
R Save Obsolete Documents in Plant Closing? Document Control Systems, Procedures, Forms and Templates 15
Marc Geocities is closing today - RIP - 1995 to 2009 After Work and Weekend Discussion Topics 1
P Contract Exit & Plant Closing Procedures - Examples needed Process Maps, Process Mapping and Turtle Diagrams 2
M My site is closing When should I inform my Registrar ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A 'Woolies' (Woolworth's) may be closing - for good Coffee Break and Water Cooler Discussions 13
B Should we perform Equipment final calibration-Operations closing ISO 13485:2016 - Medical Device Quality Management Systems 8
P Looking for a Closing Document Template/Sample (Project Management) Six Sigma 3
D Facility Closing - Continue Surveillance Audits? IATF 16949 - Automotive Quality Systems Standard 15
J Bad news for Spain. Delphi anounced yesterday the closing of Delphi Cadiz Plant World News 17
C Ford Motor Philippines Is Closing? Ford Cuts Jobs Around the World World News 0
A Does anyone conduct opening & closing meetings for their internal audits? Internal Auditing 19
Marc Ford - Elimination of 30,000 salaried jobs - Closing of 10 North American factories World News 0
Marc Flash memory closing in on hard drives? After Work and Weekend Discussion Topics 3
M Factory Closing its Doors - What are Visteon - Ford Exit PPAP requirements? APQP and PPAP 7
T Closing Out Corrective Actions and Verifying their Effectiveness ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
SteelMaiden Closing internal audit corrective action requests Internal Auditing 9
S Corrective Actions - Specifically closing out and verifying effectiveness Nonconformance and Corrective Action 30
lanley liao How to understand correctly the requirements of API monogram products Oil and Gas Industry Standards and Regulations 0
lanley liao Are there guidelines for application of all API monogrammal product? Oil and Gas Industry Standards and Regulations 2
U API License Agreements Oil and Gas Industry Standards and Regulations 2
U API Spec Q1 - 5.6.1.2 C (3) - Design software Oil and Gas Industry Standards and Regulations 3
R American Petroleum Institute - Becoming an API Auditor Professional Certifications and Degrees 2
B There is an estimated date of release of API Q1 10th edition? Oil and Gas Industry Standards and Regulations 8
