"Closing Out" Corrective and Preventive Actions
Q
QA_Scot
Hi All,
I have a number of issues where corrective actions have been raised to address external audit findings. One of the Audit finding requires every single analytical method to be updated- There are over 100!
Do I wait for all methods to be updated and approved ? If so, I will have a corrective action request open for over 12 months perhaps longer due to staff shortages.Any advicewould be appreciated as we have another external Audit coming up in July. I would really like to have a proposed plan of action.
If the C&PA/CAPA/CAR is "closed out" how do you ensure that all actions are implemented. In addition, any preventative action which may require monitoring over a prolonged period of time.
Thanks in advance.
QA_Scot.
Marc
Fully vaccinated are you?
Re: "Closing Out" Corrective and Preventative Actions
I can only comment on one aspect of your post: "If the C&PA/CAPA/CAR is "closed out" how do you ensure that all actions are implemented." Hopefully others will help out with your question as well.
Corrective Action(s) are Closed Out by Verification of Corrective Action(s) taken. This is the last step in the Corrective Action process. You may want to look at 8-D forms as they have the "standard steps" in the Corrective Action process. For all intents and purposes they are sequential.
How you verify the Corrective Action is Effective depends upon what the specific problem was. You have to determine what criteria to use to be able to be confident that your corrective action does, in fact, work (is *effective*). This helps to verify that what you determined to be the "Root Cause" was the *real* root cause. DISCLAIMER: This is not 100%, always true - True Root Cause of a nonconformance can be elusive in some cases.
Preventive Actions are part of the corrective action process where one looks at other processes and products which the root cause of the corrective action indicates may be affected.
You might want to take a look at The 8-D system. This is an old presentation and this slide really doesn't address the output (well, I guess in step 7 - Prevent Recurrence) where a corrective action system outputs what I consider an input into the Preventive Action system. I consider it a Preventive Action input because (for example) it *may* be a process issue where although other products may not yet have exhibited the failure mode, if not corrected possibly will - Different products made by the same process.
Just some thoughts.
P
PaulGr
Hi QA_Scot,
It seems you are looking for some sort of trick to hide a corrective action that takes over 12 months to solve? I would suggest following the basic approach of Marc (above) and prepare an answer for future audits why it is acceptable that this specific corrective action takes over 12 months...
Cheers, Paul
trainerbob
I guess I don't understand what is meant by "every single analytical method to be updated". Who is requiring this. Is this a major or a minor from a CB?
Jen Kirley
Quality and Auditing Expert
I also want to know more details.
Which standard were you being audited to?
What was wrong with the analytical method, which causes over 100 of them to be noncompliant - what exactly is the nature of their noncompliance?
As has been stated, corrective action requires all of the needed "corrections" are made. But verifying effectiveness wants more from us. To be effective there needs to be some action taken to address the questions
1) Why did this happen in the first place?
2) Why did this thing manage to go along without detection?
These are to be addressed through a root cause analysis that determines the independent variable(s) - that which permanently changes the outcome, in this case the non-compliant condition of these analytical methods.
Without more details I'm afraid I can't offer anything better than this.
Ajit Basrur
I think the poster refers to the analytical method verification or validation from the Pharmaceutical industry !
QA Scot, can you pl tell us more on the nature of those analytical methods ? Are they inhouse developed or Pharmacopeial methods ?
Saratogasix
I am seriously struggling with a Verification of effectiveness right now. The problem was a very limited situation that had occurred once in our company's history. A Quality Board recommendation outside of it's standard field action determnination was not implemented in a timely manner. I have fixed the gap in our process map but how do I prove effectiveness? It will only be utilized or tested maybe once in the next 10 years. I can't leave the CAPA open until it gets proven and I can't think of a way to simulate a scenario. Any suggestions?????
Sidney Vianna
Post Responsibly
Why not? That's another paradigm that needs questioning... If the corrective action is product specific, then you CAN'T verify it's effectiveness until next time. If it is only exercised once every 10 years, you are safe.....everybody will forget the issue....:tg:
Where is the requirement that state that a corrective action implementation has to be verified for effectiveness within 1 month, 6 months, 2, 5, 10 years?
Stijloor
I am seriously struggling with a Verification of effectiveness right now. The problem was a very limited situation that had occurred once in our company's history. A Quality Board recommendation outside of it's standard field action determination was not implemented in a timely manner. I have fixed the gap in our process map but how do I prove effectiveness? It will only be utilized or tested maybe once in the next 10 years. I can't leave the CAPA open until it gets proven and I can't think of a way to simulate a scenario. Any suggestions?????
This is a classic example of a situation that happens at a very low occurrence level. Based on this you can determine recurrence very unlikely and close the CAPA.
Stijloor.
Why was formal corrective action deemed necessary to begin with? It seems that your company has painted itself into a corner with its CA requirements. You should be able to close the thing out now on the basis of the problem being an outlier that doesn't merit formal CA. If you can't do that, your system is at fault.
C Recurring Nonconformance - Missing Deadline for Closing a Corrective Action Problem Solving, Root Cause Fault and Failure Analysis 14
Q Closing Out a Corrective Action - Strictly what is an Evidence? Nonconformance and Corrective Action 8
A Closing CARs (Corrective Action Requests) due to Process Change ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Nonconformance for not closing an NC (Corrective Action) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
L Criteria to Establish a Relevant Due Date for Closing Corrective Actions Internal Auditing 8
A Benefits of Improving Lead Time on Closing Supplier Corrective Action Requests Preventive Action and Continuous Improvement 3
T Closing Out Corrective Actions and Verifying their Effectiveness ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
SteelMaiden Closing internal audit corrective action requests Internal Auditing 9
S Corrective Actions - Specifically closing out and verifying effectiveness Nonconformance and Corrective Action 30
F Closing a finding before closing meeting General Auditing Discussions 14
S RMAs & Closing Complaints ISO 13485:2016 - Medical Device Quality Management Systems 7
Z US Manufacturing Site Closing, device manufactured elsewhere Medical Device and FDA Regulations and Standards News 1
T Closing out CAR while waiting for design change Nonconformance and Corrective Action 12
J Any diverging opinions regarding audit findings or conclusions must be resolved no later than the closing meeting ISO 13485:2016 - Medical Device Quality Management Systems 13
R Major nonformance finding was given during a closing meeting of a ISO9001 certification audit General Auditing Discussions 76
W Closing of Stage 2 Audit Nonconformances AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
qualprod Closing Out Negative Issues in Context and Interested Parties ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Our local sterilizer is closing - Record Retention Question 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Wes Bucey Closing in on my Diamond Jubilee Covegratulations 0
R Closing out an API/ISO QMS Audit Nonconformance - Magnetic Particle Examination Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J Internal Audits - Closing Audit Deficiency Reports (ISO 13485) Internal Auditing 4
N Timing for Closing High FMEA RPN Items FMEA and Control Plans 4
A One site of multi-site company closing - Quality transfer issues Quality Manager and Management Related Issues 7
M Closing of a Non Conformance Nonconformance and Corrective Action 5
M Process for closing complaint records after a period of inactivity? Quality Manager and Management Related Issues 2
S Having a hard time closing CAR/ PAR Nonconformance and Corrective Action 13
L How many ISO Standards are there and time allowed for Closing NCs? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T Effectively Closing 8D from Suppliers Supplier Quality Assurance and other Supplier Issues 4
C Re-Verification of Nonconforming Product prior to closing our DMR AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
R Save Obsolete Documents in Plant Closing? Document Control Systems, Procedures, Forms and Templates 15
Marc Geocities is closing today - RIP - 1995 to 2009 After Work and Weekend Discussion Topics 1
P Contract Exit & Plant Closing Procedures - Examples needed Process Maps, Process Mapping and Turtle Diagrams 2
M My site is closing When should I inform my Registrar ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A 'Woolies' (Woolworth's) may be closing - for good Coffee Break and Water Cooler Discussions 13
B Should we perform Equipment final calibration-Operations closing ISO 13485:2016 - Medical Device Quality Management Systems 8
P Looking for a Closing Document Template/Sample (Project Management) Six Sigma 3
D Facility Closing - Continue Surveillance Audits? IATF 16949 - Automotive Quality Systems Standard 15
J Bad news for Spain. Delphi anounced yesterday the closing of Delphi Cadiz Plant World News 17
C Ford Motor Philippines Is Closing? Ford Cuts Jobs Around the World World News 0
A Does anyone conduct opening & closing meetings for their internal audits? Internal Auditing 19
Marc Ford - Elimination of 30,000 salaried jobs - Closing of 10 North American factories World News 0
Marc Flash memory closing in on hard drives? After Work and Weekend Discussion Topics 3
M Factory Closing its Doors - What are Visteon - Ford Exit PPAP requirements? APQP and PPAP 7
B NADCAP Rejection Response to Root Cause Analysis and Corrective Action. Nonconformance and Corrective Action 1
A Final quality control corrective actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
T Continual Improvement as Result of Corrective Action? Preventive Action and Continuous Improvement 32
3 Non-conformance Register vs Corrective Action Register ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
D Northern Ireland Field Safety Corrective Actions (FSCA) UK Medical Device Regulations 5
A Corrective Actions and the 5 why's Training - Internal, External, Online and Distance Learning 2
A Corrective Action Training ISO 13485:2016 - Medical Device Quality Management Systems 1
