Cmk is defined as a Capability Index for a Stable Machine
SteveT
Could someone please describe to me what statistical index Cmk is, what it means, and how to calculate it.
Many Thanks SteveT
F
freeda
Cmk is defined as a capability index for a stable machine. It uses the same formula as Ppk.
Cmk is a short term study of a machine capability. Whereas Ppk is a short run study for a process.
Don Winton
I do not know about Cmk, but Cpmk is defined as:
Cpmk = (USL – LSL)/(6*(sqrt(StandardDeviation^2+(mean – T)^2)))​
Where T = Target Value.
This link http://www.asq.org/pub/jqt/past/vol32_issue4/qtec-440.pdf gives some additional info. This is a PDF file, so you will need Acrobat Reader to access it.
Hope this helps.
Regards,
Don
I was better but I got over it.
Don Winton
...what it means...
Ooops. Forgot. Cpmk is used when the tolerances are not symmetric about the target.
Regards,
Don
N
narfeldt
Ain't Cmk=revised rates of machine capability and calculates by the formula:
Cmk = 2((UTL-Mean)/(Xmax-Xmin))
Cmk = 2((LTL-Mean)/(Xmax-Xmin))
Cmk = the lowest value of above formula
Is this incorrect?
/Best wish Narfeldt
[This message has been edited by narfeldt (edited 07 June 2001).]
T Calibration or Verification -> Cm and Cmk, etc. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
M How is the Cmk and Cpk calculated? Statistical Analysis Tools, Techniques and SPC 0
G Function in french called "numbre de posage(s)" - CMK Question Quality Tools, Improvement and Analysis 3
K Excel Spreadsheet Template to calculate Cmk (Machine Capability) wanted Capability, Accuracy and Stability - Processes, Machines, etc. 2
Q Machine Capability Study - Cpk (Cmk) of an R/F testing machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
L Fastening Process Cmk study - Bolt Torque Statistical Analysis Tools, Techniques and SPC 1
L Multi-fixtures in one CNC lathe - How to do Cmk study? Statistical Analysis Tools, Techniques and SPC 6
F MCA calculation - problem with Cm Cmk and boundaries Capability, Accuracy and Stability - Processes, Machines, etc. 1
M Cmk (Machine Capability) - Case study Capability, Accuracy and Stability - Processes, Machines, etc. 5
C Gauge R&R Studies Bad, but Process has a Cmk of over 7 IATF 16949 - Automotive Quality Systems Standard 8
S A question about Cpk and Cmk - Can we use Cpk to replace Cmk? Capability, Accuracy and Stability - Processes, Machines, etc. 1
V Machine short term capability study with Cmk index in automotive industry Capability, Accuracy and Stability - Processes, Machines, etc. 3
Q Confused about the machine capability index Cmk Capability, Accuracy and Stability - Processes, Machines, etc. 1
D Tool Approval Process - Should we be using Cmk for tool validation Statistical Analysis Tools, Techniques and SPC 2
A Acceptance criteria for Cmk (machine capability index) Statistical Analysis Tools, Techniques and SPC 3
H Some questions about Cmk and Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 2
B I am confused, which Cmk value should I take and use? Statistical Analysis Tools, Techniques and SPC 6
M How to Conduct a Machine Capability (Cmk) Study Statistical Analysis Tools, Techniques and SPC 27
C Evaluating software that measures Ppk, Cmk, Cpk, PPI, etc. Capability, Accuracy and Stability - Processes, Machines, etc. 4
S Cmk and Cpk - When will we need to calculate Cmk? Machine Capability Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Cpk, Cmk in Electronic Assembly (Process Capabiity) Capability, Accuracy and Stability - Processes, Machines, etc. 4
B Any ideas on setting up Capability Study spreadsheet in Excel? (CPK/CMK formulae) Excel .xls Spreadsheet Templates and Tools 4
K Cmk - What is the difference between an R&R study and Cmk? Statistical Analysis Tools, Techniques and SPC 4
D Can anyone enlighten me as to what exactly Cm / Cmk are? Statistical Analysis Tools, Techniques and SPC 1
M Cmk calculation - Small plastic parts using injection-moulding machine Statistical Analysis Tools, Techniques and SPC 2
J Example of a defined procedure for carrying out Material Review Board (MRB) Manufacturing and Related Processes 0
J Action Not defined in procedure - NC - Incoming inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
J Controlled information versus defined documents / records ISO 13485:2016 - Medical Device Quality Management Systems 3
M Is there any pre-defined Control plan format/template acc. VDA? VDA Standards - Germany's Automotive Standards 0
C Design and implementation of process audits as defined within IATF 16949 IATF 16949 - Automotive Quality Systems Standard 2
T No Defined Shelf Life/Expiration Date - Disposable single-use, non-invasive, non-sterile Other Medical Device Regulations World-Wide 2
S How are Medical Device Components and Subassemblies defined? ISO 13485:2016 - Medical Device Quality Management Systems 1
Mikishots Definition Defined - Definition and meaning of "defined" Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 10
E Defined Roles in Small Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
P Validation of Processes - What is meant by 7.5.6 (a) - Defined Criteria for Review ISO 13485:2016 - Medical Device Quality Management Systems 7
J Measuring Leakage Currents with IEC 60601 defined Measurement Device (MD) IEC 60601 - Medical Electrical Equipment Safety Standards Series 15
R Technical Files Sampling Rule defined in NBOG 2009-4 EU Medical Device Regulations 2
J What results need to be defined in IATF 16949 Clause 8.3.4 IATF 16949 - Automotive Quality Systems Standard 3
J Deformation specification not defined in print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S How others have defined "reaudits"? 21 CFR Part 820.22 Internal Auditing 1
R Property - What is defined as Property in ISO 14971 ISO 14971 - Medical Device Risk Management 4
C AS9100 Requirement Definition - Defined vs. Documented AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
X Are defined roles and responsibilities mandatory for ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Root Cause of 'Supplier Evaluation Not defined' Nonconformance and Corrective Action 15
J Is painting considered a Special Process as defined by ISO 9001 7.5.2? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
sagai Preventive Action vs. Corrective Action as defined by 21CFR820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
A How is Segregation of Duties defined in the IT World? IEC 27001 - Information Security Management Systems (ISMS) 4
Q Must Support Processes have defined KPI's (Key Performance Indicators)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K What constitutes (is defined as) as a Medical Device? Other Medical Device and Orthopedic Related Topics 3
