schnuer
The issue has often come up where I work about the best way to perform inspections on our parts. Without getting to technical there are two opposing views: either
1.) write a complete and thorough program (in "edit mode") based on the nominal geometry of a part
-this takes (at best 30%) more time than option #2
-programming time can be minimized by piecing together segments of previously written code
-logic contained in the permanent record is easy to follow and review in case of measurement error/verification purpose
-allows for program to be easily reused, documented, debugged and modified in the future
or
2.) teach the CMM the geometry ("in learn mode") by manually probing on all the required features and report out the callouts requested by Engineering
-alleviates the need for rigidly defining the print geometry before inspecting the part
-probings are not vectored properly, ie. normal to the surface and chance of measurement error and/or inconsistency is much higher
-the sequence of commands used in the measurement session can only be saved as an informal record because each probing point is not individually defined, ie. the commands are executed by the operator
-if someone questions the measurement or the technique you don't have a definite record of how things were done, and you could end up remeasuring a different way each time:
Fortunately, I've built up my reputation enough to have a little sway in this, but pressure to squeeze the timelines is always a factor.
or
