CMM Inspection of Profile Tolerance
Thetree
I have a request from a customer to inspect the following (note:units are inches)
:evidence:
------I have a picture for this but due to forum rules I am not allowed to post it. Can anyone help?-------
:evidence:
Datum A is the face of the .305 diameter and there is a .285 hole through. There is no true definition of the location of the 16.000 R. Is it acceptable to assume tangency? If that is the case, does it allow for any step between the 16.00 radius and the .6615 diameter? I would assume it would allow for .0015 step. Also, would you consider the .305 diameter to be a part of the profile? There is an abrupt change in direction here, but the .305 is only shown basic and is not dimensioned anywhere else.
I am being asked to inspect this on our starrett manual CMM with apogee software and I am not confident at all in my ability to get an accurate reading due to short chord length of large radius and small datum face.
Any help would be appreciated.
Moderator Note: Added in edit: See picture in post #4.
Stijloor
:evidence:
:evidence:
Without a drawing, it's very difficult to advise you.
I will PM you.
Thetree
If anyone could help with at least the interpretation of the drawing, I would appreciate it. Thanks, Dan
Stijloor
The profile tolerance applies from tangent point to tangent point.
{From the edge on the .305 basic diameter to the end of the (2.38) reference dimension (The 2.38 should actually be basic too)}
The actual profile must be located within the .003" tolerance zone.
The .003" means equally disposed about true profile.
(.0015 up and .0015 down from true profile.)
Flats and reversals are permitted within the profile tolerance zone.
So a "step" at the end is permitted.
This interpretation is per ASME Y 14.5 with a disclaimer that we can not see the entire drawing.
Thetree
I was unsure about whether or not tangency could be assumed. With the 2.38 not being basic, the radius is under defined unless I can assume tangency. Thanks, Dan
Michael_M
The .305 diameter and the length (1.670) are basic so those define 'where' the profile must fit along with the actual radius.
As Stijloor said above, the profile must fall within +/- .0015 off any true (perfect) point.
Thetree
The question stands that I would like to know if tangency can be assumed. With the 2.38 being reference it does not control the feature and it could be .25 long and still hold the 16.00 radius and .305.
The 1.67 basic is not the length but the location of an internal feature. I should have removed that for clarity.
Thanks, Dan
J Outsourced CMM Measurement Inspection Service and ISO 17025 ISO 17025 related Discussions 14
W Frequency fo CMM Inspection - Sub Contract Machining of Forgings Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Blade Inspection - Does anyone use blade scaning software for a CMM or laser scanner? Design and Development of Products and Processes 3
L Contract CMM Inspection Companies and Costs Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
J TP-2 Pressure Settings - CMM Machine for Inspection of Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
D CMM Software ease of use and inspection of gears - Questions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
V CMM Inspection Layouts vs ISO 17025 Clause 7.6.3.2 Requirements ISO 17025 related Discussions 5
R Inspection of Diameters on a CMM (Coordinate Measuring Machine) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
S CMM Inspection Approach: Teach CMM geometry by manual probing or program from nominal Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
R CMM Machine upgrade - Ways to reduce CMM inspection cycle time Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
D Comparing Variation - A CMM and an On-Line Inspection Station Statistical Analysis Tools, Techniques and SPC 6
J Just accredited!!! CMM Dimensional Inspection Laboratory General Measurement Device and Calibration Topics 8
D Quality Software - Multiple Use - CMM Data, Inspection Sheets, etc Quality Assurance and Compliance Software Tools and Solutions 4
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C CMM Granite too hard General Measurement Device and Calibration Topics 4
A Cg, Cgk and GRR of a CMM Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Marco Bernardi MMC & LMC modifiers and CMM measuring techniques like diameter least squares and circularity or minimum/ maximum diameter Calibration and Metrology Software and Hardware 5
L In house calibration - Our CMM's are outside certified can I use them to certify our standards General Measurement Device and Calibration Topics 4
M Honeywell CMM's - Why Honeywell will no longer sell their manuals Federal Aviation Administration (FAA) Standards and Requirements 2
Marco Bernardi Plane measurement with a 3D touch machine like a CMM. Calibration and Metrology Software and Hardware 3
Marco Bernardi Diameters measurement with 3D touch machine like a CMM Calibration and Metrology Software and Hardware 4
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
V Recording CMM dimensional results on CFG-1003 APQP and PPAP 3
G Measuring customer parts on a CMM - How many decimals to report to the customer? ISO 17025 related Discussions 28
J CMM Accuracy Formula General Measurement Device and Calibration Topics 3
J Manual Vision CMM Calibration General Measurement Device and Calibration Topics 7
D CMM Room cleanliness requirements ISO 17025 related Discussions 7
P IATF 16949 MSA Studies for CMM machines IATF 16949 - Automotive Quality Systems Standard 3
D Can a Mill be used as a CMM? General Measurement Device and Calibration Topics 2
Ron Rompen Best Practices in CMM Correlation Studies General Measurement Device and Calibration Topics 3
B Zeiss CMM Calypso output to Excel or CSV file Help Inspection, Prints (Drawings), Testing, Sampling and Related Topics 17
J CMM Probe Certification General Measurement Device and Calibration Topics 1
S Opinions on the "Best" CMM for High Accuracy Machining General Measurement Device and Calibration Topics 9
P Getting ready for Boeing's AC7130 requirement for suppliers using a CMM AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J CMM Uncertainty Calculation Question - Deviations Measurement Uncertainty (MU) 9
K "Verification of Calibration" - CMM arm General Measurement Device and Calibration Topics 6
P CMM Equipment Validation and Qualification Approach ISO 13485:2016 - Medical Device Quality Management Systems 11
M Gage R&R with CMM 1X1X10 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
T CMM measurement and usage in the Automotive Industry Calibration and Metrology Software and Hardware 2
P CMM measurement using 2D drawings Calibration and Metrology Software and Hardware 1
M Translating and Rotating Rules when programming or measuring with a CMM Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
4 Quality vs Production on CMM Set Up Requirements Manufacturing and Related Processes 1
G Approval of Jigs (work holding devices) for CMM Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
J How to Retrofit an old, manual CMM Calibration and Metrology Software and Hardware 5
O Camio Output Control - Programming on Camio 4.6 CMM Software Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
F Comparison of 2 CMM machines using Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
R ISO - Clause 7.5.1.3 - CMM Software Program Validation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
