CMM Qualifying Sphere Calibration
K
KosmoQA
OK guys,
Can anyone tell me whether or not a CMM calibration sphere needs to be calibrated on a yearly basis? This is a question that has arisen a few times here at my location. We even asked a customer's auditor and he wasn't sure himself. The CMM is calibrated yearly, but does the sphere on which its styli are qualified need calibration as well?
Kosmo
From my experience, minimal wear takes place during use. With my CMM, I had the sphere calibrated once when new, and put a 5 year calibration period, with an annual inspection to check for damage/rust/misuse.
Paul
P
prabhudvp
cmm sphere
Hi
The cmm sphere is solid built and does not wer out
One can schedule calibration based on cost and use
it shold be calibrated if some body drops it or hit while loading the parts & fixtures
also take care by holding good cloth,paper to avoid scratches
if you record your calibration reports, study the variation and
convince the auditor for revised calibration peroide
regards
Prabhu
sarasheed
The Sphere is used to check the actual diameter of Stylii and inter relation between other stylii.The accuracy/calibration of the CMM as a whole is done with the help of Slip Gauge Test.If there is any variation in the diameter of the Sphere,it will be revieled in the Slip Gauge Test.This Slip Gauge Test,if carried out periodically,will automatically reviele the inaccuracy in the CMM incuding the inaccuracy due to Sphere.
If the accuracy in Slip Gauge Test is in acceptable limits,one need not worry about the calibration of the sphere.
We have procured Zeiss CMM WMM-850 in 1986 and so far we have not calibrated the Spheare but we are calibrating the complete CMM with Slip Gauge Test annually and the accuracy of the machine is with in specified limits.
sarasheed
K
KosmoQA
Would a "Slip Gauge Test" be performed during the annual calibration, or is it another type of test?
CalRich
Seems like the "slip gauge test" would be a verification activity, not part of the calibration.
Our lab regularly calibrates CMM spheres for a number of companies. Seems they have this done separate of the CMM calibration.
gard2372
Kosmo,
With our CMM sphere, we had the initial cal cert form the OEM. If your CMM is calibrated annually, and you're daily probe cal's are done off of your sphere then you will want to track any deviations from the original circuferential profile of the sphere periodically. Depending on what your QMS manual states, often an organization can determine the intervals or even the allowable tolerance limits from original manufacture of the cal spheres.
I suggest you try www.cmmtalk.com they have a lot of info for programmers and operators of CMM and CNC machining shops like yours and registration is free. I pasted your question into their calibration forum, and these are the responses I received....
A CMM calibration sphere needs to be calibrated on a yearly basis? This is a question that has arisen a few times here at my location. We even asked a customer's auditor and he wasn't sure himself. The CMM is calibrated yearly, but does the sphere on which its styli are qualified need calibration as well?
gard2372
Posted - 3/16/2006 7:00:28 AM
Plowboy
Posted - 3/16/2006 7:54:27 AM
Typically - NO - but it all depends on what your quality manual states and how big a pain your auditor wnats to be.
Most spheres are not calibrated after they are made.If they are damaged they are replaced and life goes on.
cmmguy
Posted - 3/16/2006 9:28:05 AM
Master balls should be recal'd, but not necessarily on an annual basis. As plowboy pointed out, if they are damaged, then they should be chucked in the can.
Master sphere size in important to the measurement of features of size but not location. The Spheres can grow over time, depending on how they are made. And the new low wear stylii will wear the ball as you touch the same locations evertime you qualify your tips. And if you do Scanning probe qualification, you really are rubbing that sphere alot.
Calibrate it every two years and no one will complain. (You would calibrate your setting rings, wouldn't you??)
thenettrainer
Um, er . . . . Absolutely! :)
I suppose there are instances where a shop does no "close" tolerance work, and has a CMM becasue a customer requires it, that kinda thang. However . . .
A sphere not only "grows" over time, it also loses it's "perfect" form. It's not unusual for a calib sphere's Form to change by several 10ths over the course of a year or two.
But isn't the issue really . . . . "Is my sphere any good??" Not "Will I be questioned or rejected in an audit?"
The cost of having a sphere inspected and certified is about $50. Hmmmm.
You're running a machine that cost the company around $100K. You expect reliable data from the machine. Right?
Spend the $50. :yes:
In my experience, this is a "possible" proceedured you might consider.
Spend a few bucks, and buy a 2nd calib sphere. (Assuming you've had one already for let's say a year or more) Put the new sphere into service. By ser. no., etc. So it's in your quality system.
Send the old one to a lab, get it recertified. Then put it away for a year. (Dip it in the protective "goop" is you need to, and put it in a well controlled temp environment till next year.)
Next year, send the newer one to be recertified. Put the old one back into the system.
Alternate each year. It'll only cost ya about $50 a year! :mg:
One other point to consider . . . What is the "climate" in your CMM area? If the temp/humidity is closely maintained, you'll have less of an issue. Why?
Because that sphere expands and contracts with the slightest temp change. And being a sphere, the molecules don't always "go back" to exactly where they were when at optemp.
FYI: I know if i were to ask 500 "savvy" people what the temp variation of a CMM room should be, I'd get over 99% telling me it had to be within 4 degrees. Well . . .
That might be true for "inspection rooms", etc. That's the allowable, acceptible temp range for measuring parts. And the tem can vary that 4 degrees over the course of any day. But . . .
For a CMM to function properly . . . . repeat perfectly . . . . Stay "in tune" . . . all of it's "parts" working correctly, the total amount of acceptible temp variation is . . . .
0.7 (7 10ths) of a degree over any 8 hour period!
If you machine/room, etc. varies more than that, best guess is . . . . if you do close tolerance work . . . . Spend the $50! :whip:
sarasheed
It is better to ask the manufacturer of the CMM weather to calibrate the Sphere or not.The actual size of sphere is measured before sending the machine to the customers and same actual value of the sphere is fed in the software used for measurement and we ,as users,can not correct these valve in the sofrware.If we find some variation in the diameter of the spheare during calibration ,we can not take any decision.
sarasheed
Hershal
Metrologist-Auditor
I would say yes, the sphere should be calibrated. However, if used only for the qualification, then depending on frequency and how it is stored, you may be able to go to a 2 year schedule.
If you send it for calibration, I recommend talking to Oak Ridge National Lab (the actual cal lab is managed by Y12). They have the ability to calibrate it, or may make an alternative suggestion if their schedule is full.
Hope this helps.
Hershal
A Qualifying a CMM Star Probe - Brown/Sharpe CMM Model Gage 2000 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
Nihls MSA Study Type 1 (CMM) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C CMM Granite too hard General Measurement Device and Calibration Topics 4
A Cg, Cgk and GRR of a CMM Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Marco Bernardi MMC & LMC modifiers and CMM measuring techniques like diameter least squares and circularity or minimum/ maximum diameter Calibration and Metrology Software and Hardware 5
L In house calibration - Our CMM's are outside certified can I use them to certify our standards General Measurement Device and Calibration Topics 4
M Honeywell CMM's - Why Honeywell will no longer sell their manuals Federal Aviation Administration (FAA) Standards and Requirements 2
Marco Bernardi Plane measurement with a 3D touch machine like a CMM. Calibration and Metrology Software and Hardware 3
Marco Bernardi Diameters measurement with 3D touch machine like a CMM Calibration and Metrology Software and Hardware 4
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
V Recording CMM dimensional results on CFG-1003 APQP and PPAP 3
G Measuring customer parts on a CMM - How many decimals to report to the customer? ISO 17025 related Discussions 28
J CMM Accuracy Formula General Measurement Device and Calibration Topics 3
J Manual Vision CMM Calibration General Measurement Device and Calibration Topics 7
D CMM Room cleanliness requirements ISO 17025 related Discussions 7
P IATF 16949 MSA Studies for CMM machines IATF 16949 - Automotive Quality Systems Standard 3
D Can a Mill be used as a CMM? General Measurement Device and Calibration Topics 2
Ron Rompen Best Practices in CMM Correlation Studies General Measurement Device and Calibration Topics 3
B Zeiss CMM Calypso output to Excel or CSV file Help Inspection, Prints (Drawings), Testing, Sampling and Related Topics 17
J CMM Probe Certification General Measurement Device and Calibration Topics 1
S Opinions on the "Best" CMM for High Accuracy Machining General Measurement Device and Calibration Topics 9
P Getting ready for Boeing's AC7130 requirement for suppliers using a CMM AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J CMM Uncertainty Calculation Question - Deviations Measurement Uncertainty (MU) 9
K "Verification of Calibration" - CMM arm General Measurement Device and Calibration Topics 6
P CMM Equipment Validation and Qualification Approach ISO 13485:2016 - Medical Device Quality Management Systems 11
J Outsourced CMM Measurement Inspection Service and ISO 17025 ISO 17025 related Discussions 14
M Gage R&R with CMM 1X1X10 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
T CMM measurement and usage in the Automotive Industry Calibration and Metrology Software and Hardware 2
P CMM measurement using 2D drawings Calibration and Metrology Software and Hardware 1
M Translating and Rotating Rules when programming or measuring with a CMM Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
4 Quality vs Production on CMM Set Up Requirements Manufacturing and Related Processes 1
G Approval of Jigs (work holding devices) for CMM Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
J How to Retrofit an old, manual CMM Calibration and Metrology Software and Hardware 5
O Camio Output Control - Programming on Camio 4.6 CMM Software Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
F Comparison of 2 CMM machines using Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
R ISO - Clause 7.5.1.3 - CMM Software Program Validation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Stated Accuracy of Portable CMM Arm and Real World Use Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
K Gage R on a 10 Piece Sample with a CMM using Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Does anyone know anything about the Mitutoyo MACH V CMM? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
T CMM Inspection of Profile Tolerance Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
B Result of a Flatness MSA on a CMM Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
V CMM plane construction method types and accuracy differences for measuring Pos Tol Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
B MSA result on parts measured with a CMM Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
M MCOSMOS - Monitor your CMM load time Quality Assurance and Compliance Software Tools and Solutions 2
G Update Numerex Air Bearing CMM? Capability, Accuracy and Stability - Processes, Machines, etc. 6
F How to get Honeywell APU CMM manual and CFM56-5B & 7B CMM manual Federal Aviation Administration (FAA) Standards and Requirements 7
Marc CMM Training at NIST - August 28-29, 2013 General Measurement Device and Calibration Topics 1
