CNC Process Validation Cpk Ppk & In-Process Inspection
Validation2011
Hi all,
New to the forum!
Hopefully you can help.
Currently validating a CNC process. Have competed prelimary capability studies based on 3 batches of 50 parts. Have got good cpk and ppk vales for the process (all above 2.57).
We are hoping to start validation of the process next week. All protocols are compete.
Problem is that we have in process inspection sheets (1 in 30 parts), however once the process is up and running we hope to run unmanned for up to 3 hours (100 parts).
I presume we need to validate based on an inspection frequency of 100 parts ? But we are currently not sure that we will be able to run for this period of time unmanned (based on 50 parts it looks good).
My question, Can we validate the process and ignore the in process inspection data for the moment? And when we do run the 3 batches of 250 parts for validation and prove capability over X number of part finalise our in process inspection sheets at this point instead?
Basically, will finalising our in process inspection sheets after validation as opposed to before validation void our validation effort?
Hope you can help!!
Many thanks
Validation2011
bobdoering
Stop X-bar/R Madness!!
Re: Process Validation cpk ppk & in process inspection
Are you doing CNC machining? What are the tolerances? Is it turning or milling? I suggest reading this link before going too far down the wrong road.
It is possible to tell how long a CNC machining process can go without adjustment, and therefore pick a sane measurement frequency - but it requires performing a correct study. I am afraid you did a traditional study, and you will not get to the right process control doing that if you are doing precision machining.
E
erinpristel
Trying to implement X hi/ Low R charting for our small machine shop. (4 machinists). We are currently AS9100C Certified and I need to know if this is going to be acceptable for an audit in place of traditional SPC - of which we all know is of little value. But thinking to myself .........AS9100 only specifies that we use statistically sound practices if I am correct? Please let me know if I am wrong. Also another issue; determining the sample frequency as to when to measure and record to collect enough data for it to be reliable. How do I do this using the data I collect until I can get a grip on the process using the charts?
bobdoering
I would hope that would be the case. Otherwise, the AS9100C certification would not be of much value - forcing one to use statistically invalid process control.
Here is the key. You should have at least 7 data point between adjustments. There should be no adjustment until you hit a control limit (75% of the tolerance). The only thing that would trump that is surface finish (if your finish exceeds the surface finish callout before you hit the control limit, then you need to further tighten your control limits). The other trump is the range chart - if you see a sudden jump in the range chart, then your tool is too worn and is approaching failure. That tool may not last until you hit the X hi/lo control limits - in which case they will need tightened.
R Process Validation on CNC Lathe and Milling machining process Design and Development of Products and Processes 1
S CNC Machining Process Validation for Prototypes ISO 13485:2016 - Medical Device Quality Management Systems 1
F AS9100D Process Matrix for a small cnc machine shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
H FMEA sample for complete CNC machining process FMEA and Control Plans 1
E Error Proofing to prevent Length Short - CNC Turning Process Manufacturing and Related Processes 4
D In Process Inspection Frequency and Documentation - CNC lathe/mill work Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
A Process Capability study of CNC Machining Process Capability, Accuracy and Stability - Processes, Machines, etc. 3
D CNC Machining Lathe Process Aspects & Impacts Miscellaneous Environmental Standards and EMS Related Discussions 3
B CNC test pieces for milling and turning - I need to run a process capability study General Measurement Device and Calibration Topics 2
S Precontrol and Process Capability - CNC Lathes that run small batches - Short Runs Statistical Analysis Tools, Techniques and SPC 12
H FAI Requirement After Moving CNC Machine? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
validationspec How to Validate the Automated Processes (CNC Lathe and Milling)? ISO 13485:2016 - Medical Device Quality Management Systems 5
A CNC Mill and Lathe - Validation Manufacturing and Related Processes 2
B IQ/OQ/PQ of CNC Milling Machine Qualification and Validation (including 21 CFR Part 11) 2
GreatNate Qualifying a CNC machine Manufacturing and Related Processes 3
S Machine Setup for a CNC Machine Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
R CNC Software Validation requirements as per ISO 13485:2016 Other ISO and International Standards and European Regulations 8
S Need Continuous improvement Suggestions - Small (30 of us) all-CNC machine shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
A ISO 9001 Control of Production Equipment - CNC Machines ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
C O-Ring Groove Measurement Method in CNC Machined Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
D OQ, PQ Requirement for Aerospace? Recently purchased CNC AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S FMEA for CNC Manufacturing FMEA and Control Plans 9
J CNC Machine Tool Calibration - 6 dof Calibration Interferometers General Measurement Device and Calibration Topics 1
V Ultrasonic NDT on CNC Product made of Stainless Steel General Measurement Device and Calibration Topics 2
M AS9100 Control of CNC programs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Quality Assurance Plan template for CNC Milling Industry AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
H Control plan example format for CNC machining activities FMEA and Control Plans 3
L Caliper Calibration Standards - One for CNC and one for Sheet Metal? General Measurement Device and Calibration Topics 9
C Equipment Qualification of a CNC Mill Center ISO 13485:2016 - Medical Device Quality Management Systems 5
P Internal Audit of CNC Programing Internal Auditing 3
A Are CNC Program Backups Required by TS 16949? IATF 16949 - Automotive Quality Systems Standard 3
G Sampling Plan for Inspection of Metal Parts after CNC Machining Inspection, Prints (Drawings), Testing, Sampling and Related Topics 34
P Machine Shop Tool Crib Procedure - Tooling for CNC mills Quality Tools, Improvement and Analysis 1
bobdoering Capability of new CNC machines Capability, Accuracy and Stability - Processes, Machines, etc. 32
V CNC Probe Qualification and DME Interface General Measurement Device and Calibration Topics 4
B SPC Software Selection for use in a CNC Machine Shop - InfinityQS and Lighthouse Quality Assurance and Compliance Software Tools and Solutions 3
B CNC Machining Shop still heavily relies on First Piece and Final QC Inspection Manufacturing and Related Processes 5
A Engineering Production Skills Matrix for Assembly or CNC Machinists Management Review Meetings and related Processes 6
R CNC OTS Software Validation Separate from full IQ/OQ/PQ for 21CFR Part 820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
S Receiver Gages vs. CNC CMM Checks Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
M Commercially available software solution for the control of our CNC programs. Records and Data - Quality, Legal and Other Evidence 3
A Examples of a Scope Statement - CNC Machining, Sheet Metal Fabrication, Assembly ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C Collecting SPC Data Electronically? CNC Lathes, CNC Mills and CNC Grinders Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
K Probe on CNC machine - Inspecting on cnc machine tools vs. CMM Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
R Verify Accuracy for Validation of CNC Starrett Vision System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B SMED in a vertical CNC Lathe Workstation consisting of 3 similar machines Lean in Manufacturing and Service Industries 2
Q Operational Qualification of a CNC machine ISO 13485:2016 - Medical Device Quality Management Systems 4
P CNC machine validation for Contract Manufacturer of medical devices Qualification and Validation (including 21 CFR Part 11) 1
C Machined Parts PFMEA - Example of a CNC produced part PFMEA wanted FMEA and Control Plans 1
