CNC Software Validation requirements as per ISO 13485:2016
As per ISO 13485:2016, software validation is required. In our manufacturing process we use lots of CNC machines (Computer Numeric Controlled). Do these CNC's fall under the requirement of software validation? If so can you guide me with suggestion on how to go about.
Many thanks!
Marcelo
Many thanks!
Yes, they can fall under. Please see ISO 80002-2 for guidance.
mihzago
I imagine that you would validate the CNC machines as part of the process validation (sec. 7.5.6) and the software used by CNC would be validated together.
Many thanks!
Yes. The CNC program causes the part to be made, you check the part to print. If the part conforms, you've just validated the CNC program. Most folks do a "first item" inspection. That's your validation record.
Sidney Vianna
Post Responsibly
Are you referring to section 7.5.6 of ISO 13485:2016?
It depends. The ISO 13485 standard states that the need for validation of the process exists when the resulting output cannot be OR IS NOT verified by subsequent monitoring or measurement...
If the machined parts are thoroughly inspected after the NC processing, technically, you would not need to validate anything as, typically, the output can be measured/inspected.
If you plan on NOT inspecting some of the characteristics, then it makes sense for you to "validate" the NC program. In the aerospace sector, this is typically accomplished with a First Article Inspection.
yodon
Software validation is a bit of a different beast. The standard cites a requirement for software validation in multiple places, including 4.1.6 (general requirement for software validation in support of the QMS), 7.5.6 (for software used in production and service provision), & 7.6 (software used in monitoring & measurement).
The standard allows (of course) a risk-based approach to software validation (commensurate with the risk).
I agree with others who indicated the CNC software should be validated. I don't disagree that doing a first article would support software validation but there's more to software validation than just "happy path" use. For example, is the software sufficiently controlled from unauthorized change? There may be other considerations specific to CNCs and potential (mis)use.
You should consider establishing a Validation Master Plan to drive your software validation efforts and establish your risk-based approach.
Sidney Vianna
Post Responsibly
Should is not the same as a requirement (shall). I already explained how ISO 13485:2016 makes a determination if a NC software needs to be validated or not. A simple (NC) machined part which undergoes 100% inspection means that the NC SW is not required to be validated. Obviously, the organization can (and should) go beyond and above the minimum requirements, but, whenever discussing about a standard (such as ISO 13485), I think it is important to identify what is a requirement and what is a nice to have feature.
As for unauthorized change of validated software, software revision re-validation, revision control, in my opinion, that all falls outside of the validation aspect and more along the lines of configuration management, data control, etc...
ScottK
Not out of the crisis
I'm with Andy and Sidney.
I've spent most of the last 15 years in sites with CNC machines in the med device world and we did not explicitly validate the CNC software because we qualified the equipment (IQ/OQ/PQ) and performed inspection - first piece, in-process, final. Software qualification was part of the IQ/OQ/PQ
So we verified the product to meet the requirements.
R CNC OTS Software Validation Separate from full IQ/OQ/PQ for 21CFR Part 820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
B SPC Software Selection for use in a CNC Machine Shop - InfinityQS and Lighthouse Quality Assurance and Compliance Software Tools and Solutions 3
M Commercially available software solution for the control of our CNC programs. Records and Data - Quality, Legal and Other Evidence 3
A CNC Mill and Lathe - Validation Manufacturing and Related Processes 2
B IQ/OQ/PQ of CNC Milling Machine Qualification and Validation (including 21 CFR Part 11) 2
GreatNate Qualifying a CNC machine Manufacturing and Related Processes 3
F AS9100D Process Matrix for a small cnc machine shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S Machine Setup for a CNC Machine Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
R Process Validation on CNC Lathe and Milling machining process Design and Development of Products and Processes 1
S Need Continuous improvement Suggestions - Small (30 of us) all-CNC machine shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
A ISO 9001 Control of Production Equipment - CNC Machines ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
C O-Ring Groove Measurement Method in CNC Machined Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
D OQ, PQ Requirement for Aerospace? Recently purchased CNC AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S FMEA for CNC Manufacturing FMEA and Control Plans 9
J CNC Machine Tool Calibration - 6 dof Calibration Interferometers General Measurement Device and Calibration Topics 1
V Ultrasonic NDT on CNC Product made of Stainless Steel General Measurement Device and Calibration Topics 2
M AS9100 Control of CNC programs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Quality Assurance Plan template for CNC Milling Industry AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
H Control plan example format for CNC machining activities FMEA and Control Plans 3
H FMEA sample for complete CNC machining process FMEA and Control Plans 1
L Caliper Calibration Standards - One for CNC and one for Sheet Metal? General Measurement Device and Calibration Topics 9
C Equipment Qualification of a CNC Mill Center ISO 13485:2016 - Medical Device Quality Management Systems 5
P Internal Audit of CNC Programing Internal Auditing 3
S CNC Machining Process Validation for Prototypes ISO 13485:2016 - Medical Device Quality Management Systems 1
A Are CNC Program Backups Required by TS 16949? IATF 16949 - Automotive Quality Systems Standard 3
G Sampling Plan for Inspection of Metal Parts after CNC Machining Inspection, Prints (Drawings), Testing, Sampling and Related Topics 34
P Machine Shop Tool Crib Procedure - Tooling for CNC mills Quality Tools, Improvement and Analysis 1
bobdoering Capability of new CNC machines Capability, Accuracy and Stability - Processes, Machines, etc. 32
V CNC Probe Qualification and DME Interface General Measurement Device and Calibration Topics 4
B CNC Machining Shop still heavily relies on First Piece and Final QC Inspection Manufacturing and Related Processes 5
A Engineering Production Skills Matrix for Assembly or CNC Machinists Management Review Meetings and related Processes 6
V CNC Process Validation Cpk Ppk & In-Process Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
S Receiver Gages vs. CNC CMM Checks Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
E Error Proofing to prevent Length Short - CNC Turning Process Manufacturing and Related Processes 4
A Examples of a Scope Statement - CNC Machining, Sheet Metal Fabrication, Assembly ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C Collecting SPC Data Electronically? CNC Lathes, CNC Mills and CNC Grinders Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
K Probe on CNC machine - Inspecting on cnc machine tools vs. CMM Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
R Verify Accuracy for Validation of CNC Starrett Vision System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B SMED in a vertical CNC Lathe Workstation consisting of 3 similar machines Lean in Manufacturing and Service Industries 2
Q Operational Qualification of a CNC machine ISO 13485:2016 - Medical Device Quality Management Systems 4
P CNC machine validation for Contract Manufacturer of medical devices Qualification and Validation (including 21 CFR Part 11) 1
D In Process Inspection Frequency and Documentation - CNC lathe/mill work Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
C Machined Parts PFMEA - Example of a CNC produced part PFMEA wanted FMEA and Control Plans 1
N Lot Capability - Forging -> CNC Machining -> Heat treatment -> Packaging Statistical Analysis Tools, Techniques and SPC 3
M Calculating OEE Performance Measurement for a CNC Plasma Cutter Manufacturing and Related Processes 19
C CNC Machine Operational Qualification Recoverability Testing Other Medical Device and Orthopedic Related Topics 1
B Is a work instruction mandatory - CNC machine ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
A CNC Program and Revision Control procedure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
A AS9100 7.5.1.3 Control of .... Numerical NC/CNC Machines Programs. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
