CO2 Incubators - Equipment Qualifications in addition to Calibration
Metron
Our Metrology department performs the equipment qualifications in addition to the calibrations.
Currently our CO2 incubators are qualified at 37 Degrees and 5% CO2. continuous changes by the user is now required.
What is required to maintain control and still allow the processes to continue?
An example of change is to set the incubator to 36 Degrees 8% followed by 32.5 degrees at 0% and 38 degrees with 2% CO2 . Several other points may also be required. All of this is scheduled to occur over about a week to 10 days. Currently we issue a change Control and perform calibrations and full qualifications(empty ,loaded, open door, power failure) for each set point change.
This seems extreme and causes up to a month of process halt until the change control and the new qualification documents are signed by QA. in my 30 years of performing these tests we have not had a single failure that was temperature or CO2 related. This causes my question of why do we do this?
There must be a logical and more cost effective way to change a set point of an incubator and still remain compliant to GMP and FDA regulations. I welcome any suggestions as i cannot find any detailed regulations requiring these actions.
Ronen E
Problem Solver
Moderator
Re: Equipment qualifications in addition to Calibration - CO2 Incubators
Hello Metron and welcome to the Cove :bigwave:
I'm not sure I fully understand the intended use. What are these incubators used for? What does the user interface allow? Does it have user-operable controls for temperature and CO2 percentage? What is the declared tolerance around set targets? Etc.
If you want to change the device from a single set point to user-controlled, I'd go for a formal change under change control / design control and then verify and validate that the user-operated control works as expected.
Metron
Thanks for responding,
These are standard Thermo incubators easily front panel controlled.
thank you for the suggestion it helps for some of my issue.
the difficult part is justifying in an audit that the incubator is in a qualified state per FDA and GMP regulation. Currently with each set point change, I issue a Change Control, re-perform full qualifications(empty ,loaded, open door, power failure)and this is very time consuming and costly to our client.
Do you have any suggestions that may ease the pain of this current practice?
Ronen E
Problem Solver
Moderator
Honestly, I don't understand the problem. I am assuming that this is a Medical Device and that the applicable regulations (what you refer to as "FDA and GMP") are those that apply to Medical Devices. If it's not a Medical Device, could you please clarify as what sort of entity it is regulated?
If it is indeed a Medical Device, I don't understand the regulatory basis for your practice. If the device has a user-accessible control panel, the device's performance should be validated once when a design change occurs (eg extension of temperature range capability). That validation should cover all possible/allowable user interventions (excluding perhaps abnormal use, ie deliberately and conciously going against issued instructions). Changing a parameter target via user-accessible controls, in line with manufacturer issued instructions, is not considered a design change.
I am not familiar with any specifics of incubators regulation (eg Special Controls, if any exist) so if there is such regulation, or some related FDA guidance, that dictates your current practice, could you please call it out so that I could have a look and maybe better understand your situation?
Cheers,
Ronen.
Metron
Sorry for the confusion, let me start with what we have and what we now need.
We currently have a Thermo model 3910 Co2 incubator.
It was initially qualified at the parameters of 37+/-2 degrees and 5%+/-2% for CO2.
Now multiple points are needed to be used for the new processes.
Our QA is requiring each needed set point needs to be qualified (empty ,loaded, open door, power failure). I am looking to see if anyone has a different take and an alternate action. I am unable to find a specific regulation, only that the Incubator must be kept in a qualified state. Any suggestions?
Ronen E
Problem Solver
Moderator
Instead of qualifying individual set points I would validate the entire range through qualifying the extremes and some representative points in between. DOE techniques can be used to reduce the number of individual runs required for covering the entire range(s). Once this has been done you could completely drop the individual qualifications as long as the device design is not changed and the validated range is not exceeded.
Perhaps I still don't fully understand you; hopefully some other forum participants will contribute their angle.
Cheers,
Ronen.
M NIST Standard for CO2 Monitor Calibration General Measurement Device and Calibration Topics 5
R EMS Programme Target is Reduction in CO2 Emission Miscellaneous Environmental Standards and EMS Related Discussions 5
O 1kg Dry Ice(Compressed CO2) = what CO2E/MetricTon Miscellaneous Environmental Standards and EMS Related Discussions 2
Strange Juan Freezers fridges Incubators Calibration Labels General Measurement Device and Calibration Topics 12
H Regarding external surface temperature limit requirement for lab incubators. CE Marking (Conformité Européene) / CB Scheme 2
T International Reference or SOP for the Thermal Validation of Incubators, Cold Rooms General Measurement Device and Calibration Topics 2
M Calibration of Benchtype Laboratory Ovens and Incubators General Measurement Device and Calibration Topics 9
V PQ parameters for computer system validation of configurable software of laboratory equipment Qualification and Validation (including 21 CFR Part 11) 0
I Design Verification Testing on Non-Validated Equipment ISO 13485:2016 - Medical Device Quality Management Systems 2
E Class II ME EQUIPMENT and subclause 8.9.1.12 IEC 60601 - Medical Electrical Equipment Safety Standards Series 10
H MTBF industry average for manufacturing automated equipment Manufacturing and Related Processes 0
M Master / Guideline Matrix for measuring equipment Manufacturing and Related Processes 4
K Equipment IQ/OQ/PQ required when you have 100% product inspection? ISO 13485:2016 - Medical Device Quality Management Systems 2
K ISO9001 - Measurement Equipment records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
K ISO 17025 Query Relating to Monitoring of Equipment ISO 17025 related Discussions 3
R Medical equipment selection for refurbishment US Food and Drug Administration (FDA) 1
R CE Certification / PED Certification - Pressure Equipment CE Marking (Conformité Européene) / CB Scheme 4
H DIN 12880:2007-05 Clause 7.2 Test Equipment Description CE Marking (Conformité Européene) / CB Scheme 0
B Painted surface of a protective Class I equipment. CE Marking (Conformité Européene) / CB Scheme 1
K What are the differences between the certificates required for home and medical medical equipment? US Food and Drug Administration (FDA) 1
B ISO 13485 Qualification of R&D Equipment Qualification and Validation (including 21 CFR Part 11) 1
R EU 2017-745 - Dental Equipment CE Marking (Conformité Européene) / CB Scheme 4
T Need advice on what inspection equipment to buy. General Measurement Device and Calibration Topics 2
Q What is considered "Multimedia equipment" (60601-1-2 section 7.1.3) IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
V Is it required to recalibrate reference- standard instruments after equipment qualification General Measurement Device and Calibration Topics 0
armani Monitoring and measuring equipment for occupational health and safety purposes Occupational Health & Safety Management Standards 10
P Type of MSA study according to measurement equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Rene Minassian Control of (TMME) Testing and Measurement Equipment Oil and Gas Industry Standards and Regulations 2
M Cameras and Visual Inspection Equipment General Measurement Device and Calibration Topics 3
JoeRandom11 Question about Customer Supplied Equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
C Equipment IQ and OQ ISO 13485:2016 - Medical Device Quality Management Systems 9
D PPE (Personal Protective Equipment) in the UK CE Marking (Conformité Européene) / CB Scheme 1
D Recommendations for equipment used to validate cold storage units General Measurement Device and Calibration Topics 3
T PFMEA vs MFMEA or DFMEA on equipment/machinery FMEA and Control Plans 19
E Brass in medical equipment Other Medical Device and Orthopedic Related Topics 5
G QSB+ : capability of measurement equipment IATF 16949 - Automotive Quality Systems Standard 15
M Gage R&R automated test equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Developing our custom test methods and test equipment US Medical Device Regulations 5
E Compressed air quality in ME equipment (used in OR) IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
M ISO 17025:2017 Clause 6.4 - Measuring Equipment Validity ISO 17025 related Discussions 2
W Strategy for determining which components from a system should be "ME EQUIPMENT" -- home healthcare environment IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
M Do i need to have equipment validation if 100% testing is completed? Qualification and Validation (including 21 CFR Part 11) 6
K Brazil (INMETRO) for Medical Electrical and IVD Equipment? Other Medical Device Regulations World-Wide 4
Y Creating Equipment qualification protocol Qualification and Validation (including 21 CFR Part 11) 2
R Suggest modern equipment/instrument for plastic bottle inspection? Quality Tools, Improvement and Analysis 1
S Certification of equipment after move General Measurement Device and Calibration Topics 14
B Building my own measurement equipment General Measurement Device and Calibration Topics 3
J Process Capability - Determining the process capability of certain equipment Lean in Manufacturing and Service Industries 6
W Classes and Applied Part IEC60601 Electromedical Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A PPAP Alternate Equipment IATF 16949 - Automotive Quality Systems Standard 10
