Color Coding of Tools for 5S - The Visual Workplace
Dean Frederickson
#11
Re: Color coding of tools for 5S
You can cover the whole tool if you like and then cut away where you do not want it. As far as wrench size, yes it will cover it and you won't be able to read the size, just cut the plasti dip from the size area.:cool:
P
palmer
#12
I had to apply a thin base coat because it wouldn't brush on in a thick coat to cover initially. It has proven to be difficult to apply with subsequent applications and has proven to want to cause lumps. I imagine with more coats it will fill and smooth.
I've considered placing the material in a pan and dipping the tool into the pan of this material to create a smoother application.
Or maybe I'm just not capable of applying it correctly. DOH! :lmao:
Jen Kirley
Quality and Auditing Expert
#13
I read that about 10% of males are color blind. Does it apply to anyone who would be using this system?
P
palmer
#14
The basis of the system is to identify what machine the tool belongs to. If it is found at another machine it should raise the question, why? Does that machine need one of those tools.
Places like automotive factories use color coding for identifying paths or color andon signs and lights to identify issues.
Other companies use color hardhats to identify who or where the worker is/belongs. The same goes for uniforms.
I have not heard of an issue with not knowing what color is which....
P
palmer
#15
One of my suppliers has provided some Krylon spray paint for color coding of the tools. We have applied a primer coat to help with adhesion and then a color over it. So far so good.
One thing I like about this application is that you can read the tool size and there is virtually no limit to the number of colors you can use....
I'll let you know how this works as well....
BTW, thanks for the responses, it helps having a forum like this to get ideas from others who are doing similar things.:thanx::thanks:
P
prototyper
#16
Have you thought of coloured electrical cable ties?
I have used them to for colour coded gauge calibration due dates where stickers, etc., wouldn't stay on the gauge.
They are quick and very cheap!
P
palmer
#17
How wide are they? Do they come in different widths? Remember, this is to help create a visual workplace so you should be able to walk up to a machine and see the tools on the toolboard and what color belongs there. Plus. we want to color code brooms, shovels, etc...
P
prototyper
#18
They go from around 2mm up to around 7mm wide. You may be able to get bigger ones?
P
palmer
#20
Reopening an old wound:rolleyes:
On some of the tools that we painted the paint won't stick very well:confused:
It seems like different brand tools have a different chrome that paint won't adhere to. We have bead blasted, wire wheeled, sand papered and still can't get to stick. Once the tool is banged on something it breaks the paint shell and starts flaking off.:mad:
We want a significant amount of the tool covered so it is easliy viewable.
Heat shrink tubing is too expensive. Paint on rubber coating doesn't seem to apply in a smooth even coat.
Any ideas?:frust:
J Color coding Standard? Color Coding Raw Metals in a Small Machine Shop Lean in Manufacturing and Service Industries 5
C Is there a Solid Waste Standard Segregation Color Coding Miscellaneous Environmental Standards and EMS Related Discussions 7
J SSQR-01 Vision Requirements- Color Blindness AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
Marc Visual Inspection - Color Vision Coffee Break and Water Cooler Discussions 15
D IMDS for Like Components (Interior Plastic, Leather/vinyl Armrest, etc.)other than Color APQP and PPAP 1
D Requirements for the dimensions / color of medical device labels - Software as a Medical Device IEC 62304 - Medical Device Software Life Cycle Processes 2
M Informational Work in progress at the FDA for biological evaluation – Color Hazard and RISk calculator (CHRIS) Medical Device and FDA Regulations and Standards News 0
S Device name change and label color change EU requirement? Other Medical Device Regulations World-Wide 6
erozas2003 Color test on molded plastic parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S Testing (Evaluation of) and Verification of Employee Color Vision Human Factors and Ergonomics in Engineering 19
C ISO 7010 m002 mandatory action - Color requirements on Packaging IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
J Paint Color Standards Manufacturing and Related Processes 5
V Query on PA66+GF15% - Color variation (Natural to Yellowish) problem Manufacturing and Related Processes 20
L Color measurements R&R: what's wrong with white? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
K Color to be used for the Packing box Symbols Other Medical Device Related Standards 2
R Paint Color Control Manufacturing and Related Processes 6
S Organisms postive to Wellcolex? Color Salmonella Test Kit US Food and Drug Administration (FDA) 1
S Labeling Symbols for EU - E.g. EN980 - Dimension, color, font, etc. Other ISO and International Standards and European Regulations 6
optomist1 Error Mistake Proofing Color Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
B ISO 3864-4 Symbol Color Regulations Other ISO and International Standards and European Regulations 4
M Molded Component Color Tolerance Specification Manufacturing and Related Processes 6
A Reporting of Design Changes (Color Change Only) EU Medical Device Regulations 5
K Black Anodize Color Specification per MIL Spec Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R AC 7120 Vision and Color Blindness Testing AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
somashekar How do you specify color tolerance ... Manufacturing and Related Processes 6
QMMike Color Measurement (Monitoring) during Processes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K How do I autofill cell color based on other cells' color in Excel? Excel .xls Spreadsheet Templates and Tools 11
Steve Prevette Color Coded SPC Dashboards The Reading Room 0
D MSA (Measurement Systems Analysis) on Visual Color Check IATF 16949 - Automotive Quality Systems Standard 13
W Approximation of a Gardner color value to the APHA Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Color Coded Shirt System on our Shop Floor Lean in Manufacturing and Service Industries 18
T Enclosure Flammability Rating of Molded-In Custom Color Liquid Concentrates IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
R 5S Red Tag and ISO Procedure Red Tag - Tag Color Conflict Document Control Systems, Procedures, Forms and Templates 7
1 What device to use to measure LCD display devices color/brightness General Measurement Device and Calibration Topics 3
B Calibration Interval of Munsell Color Charts General Measurement Device and Calibration Topics 3
J Master Color Plaque recommended sources Quality Tools, Improvement and Analysis 16
B Color Individual Points on a Control Chart? Using Minitab Software 7
G Organoleptic (Color, Odor, Taste, Texture, etc) lexicon? General Measurement Device and Calibration Topics 8
V Color Assessment Cabinet - Calibration IATF 16949 - Automotive Quality Systems Standard 1
P Color Cross Reference - PMS and NCS colors samples Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
D Need suggestions for a mobile Spectrophotometer (a.k.a. color meter) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Proud Liberal Color Evaluation of Tinted Transparent Plastic Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
CalRich How to display color chips - Injection molding color verification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
Ajit Basrur Color Codes for different gases Manufacturing and Related Processes 2
S Phenolic Resin - Colour Variation - Will oxidation change its color? Manufacturing and Related Processes 4
Wes Bucey Big Brother! - Even in your color laser printer After Work and Weekend Discussion Topics 15
M Color Codes and visual floor marking - Are there any Standards? Manufacturing and Related Processes 11
E How to specify Paint or Plastic Color - Pantone or Manufacturer Specification? Manufacturing and Related Processes 15
B TS16949 Clause 7.1 in plastic pellet 'color mixing' and color compounding' process IATF 16949 - Automotive Quality Systems Standard 1
S Color Management - Confirming Color for Injection Molded Plastic Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
